Re: 440 head bolt leaking coolant [Re: JohnRR] #1406402
03/24/13 09:42 AM
03/24/13 09:42 AM
wisconsin usa
moretork03 Offline OP
wisconsin usa
under the valve cover
Re: 440 head bolt leaking coolant [Re: moretork03] #1406403
03/24/13 11:38 AM
03/24/13 11:38 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Its past tomorrow , did you pull the bolt and find coolant in the hole ? Put the pressure tester on without the bolt and look for the leak ?
Re: 440 head bolt leaking coolant [Re: JohnRR] #1406404
03/24/13 01:20 PM
03/24/13 01:20 PM
wisconsin usa
wisconsin usa
got to go on the road for work for a week or two so will be on it when I get back, I will chime back in on what I find out and thanks for the help!
Re: 440 head bolt leaking coolant [Re: moretork03] #1406405
04/04/13 07:01 PM
04/04/13 07:01 PM
wisconsin usa
wisconsin usa
well, coolant was definitely coming thru bolt hole on pressure test, sealed with permatex #2 just like the haynes manual says and leak is gone. not sure of the whys or why nots but
Re: 440 head bolt leaking coolant [Re: moretork03] #1406406
04/05/13 11:27 AM
04/05/13 11:27 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Good that you got the leak stopped.
Hopefully the bigger issue of WHY there is coolant coming up that hole doesn't get worse.
then there is the torque aspect, I don't know how the torque value of the bolt is changed by the use of permatex vs. oil.
But as long as your happy with the result I guess that is all that really matters :
Re: 440 head bolt leaking coolant [Re: JohnRR] #1406407
04/05/13 11:33 AM
04/05/13 11:33 AM
I wish you the best but I ain't holding my breath
Re: 440 head bolt leaking coolant [Re: RapidRobert] #1406408
04/05/13 01:11 PM
04/05/13 01:11 PM
dogdays Offline
dogdays  Offline
Welcome to the Optimist's Club!
R.
Re: 440 head bolt leaking coolant [Re: dogdays] #1406409
04/05/13 04:44 PM
04/05/13 04:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
R.
I'm trying
Re: 440 head bolt leaking coolant [Re: JohnRR] #1406410
04/06/13 12:14 AM
04/06/13 12:14 AM
wisconsin usa
wisconsin usa
well, ran it pretty hard today = 6800 rpm and still not leaking.guess I"ll find out for sure at the track come the end of may
