440 Street Motor Build advice needed #1406328
03/21/13 09:56 PM
03/21/13 09:56 PM
wi
steve63 Offline OP
steve63  Offline OP
wi
I am putting together a plan for a 90% street motor for my 69 RR, the for sure things are:
1. 69 440 Block, is .030 over already, needs to go .o4o over
2. Alum 6 Pack intake
3. Must look stock
4. Pump Gas
Going in a 69 Roadrunner, all stock weight, with an automatic and 4.10 Dana
My thoughts:
1. Block Bored .040 over, main studs
2. 440 source stroker kit, 4.25 stroke, 7.10 rod, 27cc dish for just under 10-1 static comp.
3. Stealth Heads, unsure about the cnc or not
4. Isky Iron Rockers, I have them already
5. Mopar .528 Solid Cam
6. Stock 402 pan w/tray
The goal is as much pump gas hp/tq, on a budget, looking stock under the hood.
My rational is:
By the time I have my stock steel crank checked, resize the original rods or buy replacements, buy pistons, rings, bearings..and have it balanced.....I will be well over $1000, and the whole crank, rods, pistons, etc. balanced from 440 source is $2000
By the time I have my heads checked, valve job, springs, etc., it would be close to $600 or more, the stealths are $1000 complete
The .528 Mopar cam has gotten good reviews with exhaust manifolds
I am undecided as far as manifolds versus headers.....I want the stock look, but I know I would be giving up a lot of hp/tq by going with manifolds.
My main questions are:
Will mainstuds be fine with the stock caps on a 10-1 or less street motor, or should I use billet caps ?
Should I get the cnc stealth heads ? They are $1000 more, but they have been checked out by Modern Cyl. Head so I would assume they would be near bolt on.
Will the .528 cam be optimal for good street manners, or maybe too small for a 512 ci ?
If I use headers, would there be a much better choice of cam ?
Would 1 7/8 headers be fine, or 2" ?
Any advice, critisisms are welcome//// Thanks
Re: 440 Street Motor Build advice needed [Re: steve63] #1406329
03/21/13 10:09 PM
03/21/13 10:09 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I would port the heads and run 2 inch headers with the larger inches. The cam might be a bit small with the stroker as well, it is pretty mild with a 440. I would also sacrifice the stock look for a 2 or 3 quart bigger oil pan.
Sheldon
Re: 440 Street Motor Build advice needed [Re: steve63] #1406330
03/21/13 10:24 PM
03/21/13 10:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Sounds like you`re willing to go Modern cnc heads so step up the cam a bit say a 560-580 lift 245-250 dur. @ .050 and have an easy on valvetrain streetable torque monster......... Stock caps here forever w/ARP studs. I like headers on everything so if that`s the plan listen to the above post on the rest..............
Re: 440 Street Motor Build advice needed [Re: steve63] #1406331
03/21/13 11:19 PM
03/21/13 11:19 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
3. Must look stock
4. Pump Gas
My thoughts:
My rational is:
Couple of things....
Spend a few dollars and have that block sonic checked. If its good, then go .055 over. The piston/ring choices are more favorable.
Forget about the 402 pan and go with the 70-71 street hemi pan. Leave the oil pickup 3/8"
-Def let an experienced head guy MCH or Porter set up the geads for you.
-That cam is NOT a good choice for that motor or for manifolds. You need to decide that at this point before doing anything else manifolds/headers.
-Def do the stroker.. You are correct about the economics of it. But dont think that cheap stuff will work out of the box. many of those cranks need to be ground even though they are new. Figure it in to the cost.
MB
Re: 440 Street Motor Build advice needed [Re: RUNCHARGER] #1406332
03/21/13 11:19 PM
03/21/13 11:19 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Sheldon
put on the 6qt hemi pan and go with a larger cam .
Re: 440 Street Motor Build advice needed [Re: JohnRR] #1406333
03/21/13 11:40 PM
03/21/13 11:40 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
That .528 cam in your 500+ inch motor will be lame and tame like grandma's 318. Don't be afraid to put a good size cam in a big stroker motor. For your engine, a 260 duration @ .050 cam is considered mild and will still have great drivability and have a crapload of bottom end grunt. Spend some money and time on getting the heads to move some air. Go with the 2" headers and 3" dual exhaust to let that beast breathe.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 440 Street Motor Build advice needed [Re: HPMike] #1406334
03/22/13 01:01 AM
03/22/13 01:01 AM
wi
steve63 Offline OP
steve63  Offline OP
wi
3. Must look stock
4. Pump Gas
My thoughts:
My rational is:
MB
I was looking at the Muscle Motors web site, they offer the same stroker "kit", balanced, for the same price as 440 source, and he makes a convincing case, stating that everything is checked to be almost a drop-in deal.....anyone have any experience with them ?
The 528 mopar cam was thought of because andyf on here had good results with exhaust manifolds.
The 402 pan, Iron Rockers, and 1 7/8 headers were for budget reasons as I already have them.....if this will be mostly street driven, probably never see over 6000 rpm....with a six pack set-up.....relatively low (<10-1) comp. so there should be no fear of detonation.......are the stock main caps ok ?
How about the heads ? Should I spend the extra $1000 for the cnc versions ?
Re: 440 Street Motor Build advice needed [Re: steve63] #1406335
03/22/13 01:24 AM
03/22/13 01:24 AM
Buy the best heads you can get, use the newer 6 quart street hemi 440 6 pak oil pan with the 6 pack 3/8 pick up Increase the compression ratio up to 10.5 to 10.75 to 1 I did that on Oregon non ethanol pump gas and that worked well, 687 HP at 6500 RPM on a DTS engine dyno at 4300 Ft above sea level The six paks rock once you get them dialed in Big motors love big air, cylinder heads, camshafts, intakes and carbs, exhaust all help the motor breath, be ready for some serious HP and Torque Probally a real tire spinner also
Re: 440 Street Motor Build advice needed [Re: Cab_Burge] #1406336
03/22/13 08:29 AM
03/22/13 08:29 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Yes the stock main caps are fine Just use quality studs and have it line honed.
The CNC'd Stealth's would definitely help with the air flow demand of the stroker.
Use the 6 quart Hemi oil pan and sell off the 402 to offset the cost.
Camshaft, well this is where you need to decide what YOU want out of the motor. Do you want a sleeper idle, a little exhaust rumble or something more racy. Hydraulic, solid or roller. Decide on your exhaust, headers or manifolds and have a specialist help you select one tailored to your specific application want's and needs. Don't use the .528 "just because you have it".
Re: 440 Street Motor Build advice needed [Re: roadhazard] #1406337
03/22/13 08:43 AM
03/22/13 08:43 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Here is advice you don't want to here. Put the motor back to stock as much as you can. A 4.25 crank and rods is dumb for any 90% street driven motor. The cam you can put in a nice comp high energy cam around .510 to .530 and have a nice torque motor that will burn the tires up on the street. Or you can do what these guys want and have a gas drinking ill idleing /smelly street car that will need to be worked on every day.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: 440 Street Motor Build advice needed [Re: slippery440] #1406338
03/22/13 08:54 AM
03/22/13 08:54 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
You are joking, right??
The reality is that strokers are THE way to go for street motors...The main reason is to get these engines to run on pump gas, you take the compression out. To get the lost power back, the easiest thing to do is add inches. And if you dont really have stock stuff thats "ready to go", then the cost difference is neglgible. Truth is there is practically nothing that will give you the same "bang for the buck" that making the engine bigger will.
And where is it written that a stroker cant have good idle quality and street manners and be maintenance free??
MB
Re: 440 Street Motor Build advice needed [Re: steve63] #1406339
03/22/13 09:11 AM
03/22/13 09:11 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Think about the Milodon "Road Race" oil pan, it fits up in the K, has better oil control and higher capacity than the Hemi pan.
Re: 440 Street Motor Build advice needed [Re: HPMike] #1406340
03/22/13 09:16 AM
03/22/13 09:16 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
What are your goals? The 528 is a good cam for a stock stroke 440 and logs, but as mentioned if you are going big you might want more. Is this some kind of "FAST" car thing? You can have a stock looking engine and still run headers. You are giving up 40-50 HP. Do you still have the factory crank? If so you might just want to build the 440 and save some $. The 1st motor in this car was a .030 10.5:1 440, ported closed chamber heads, 528 solid (lashed tight), 1.5 roller rockers, 6-pack and 1 3/4" headers. It ran great, as soon as the outboards were craked the tires would go up in smoke. Now if all you have is the block and need the crank and whatnot, then yeah might as well go bigger.
Coming soon!!!!
Re: 440 Street Motor Build advice needed [Re: Mr.Yuck] #1406341
03/22/13 09:23 AM
03/22/13 09:23 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Don't change the main caps. Lot of extra expense and hassle for nothing.
2011 Drag Pak Challenger
Re: 440 Street Motor Build advice needed [Re: steve63] #1406342
03/22/13 09:29 AM
03/22/13 09:29 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
MB
Mike has built a bunch of Stroker engines for FAST so he knows what he is talking about , though I wouldn't go out to .055 , at that point the block is done, if something happens and you need to go to the next oversize you have to buy another block , but have it sonic checked anyway and sleeve any cylinder that needs it.
AndyF did have good results with the .528 but that was with an engine with 40 less cubes, call Dwayne Porter for a cam.
Get the heads CNC'd , the heads as delivered do not flow as well as claimed.
Build it to 10.5 compression and it will be fine on pump premium.
The fact that you say ... it will be mostly ... you want to go with the bigger pan, sell the 402.
I've used Muscle Motors in the past , great guys , you won't be disappointed.
Re: 440 Street Motor Build advice needed [Re: steve63] #1406343
03/22/13 09:51 AM
03/22/13 09:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
My 2 cents... if your gonna stroke it get the heads
CNC'd... its gonna need the added air flow otherwise
the head would be the restriction point... with the
4.10 gear you dont need a dual plane intake so get
a single plane(a dual plane will help add low end torque
so if you dont plane on reving it too high go with
the dual)... the cam needs to be larger than your choice
due to the cubes(strokers like duration) and base the
lift on the head flow... stock caps are fine but
use studs... keep the cyl pressure down so you can
run on junk street fuel... with this your gonna fry
tires at will... so buy stock in goodyear
there are some decent exhaust manifolds out there
but a header would be better(a 2" pri tube).. with
the manifolds you might be giving up 20hp in normal
driving and maybe 30 hp total at revs
EDIT
Cancel all the intake info... I forgot you want to
run your tri-power set up
Re: 440 Street Motor Build advice needed [Re: slippery440] #1406344
03/22/13 11:18 AM
03/22/13 11:18 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
This does seem a bit odd to me also...............Been beating on small and big blocks for years ALL of which see lots of street and a few passes here and there and my latest 470 is no different and VERY streetable AND depedable w/only valve adjustements every few months. I actually said to pick a medium cam by my standards but the sky`s the limit and your desires and budget also play a big role. Lots of different ways to go and me, well I go as close to all out as I can for the combo and my n/a street car is crazy fun on the street and surprises many at the track. You`ll figure it out................
Re: 440 Street Motor Build advice needed [Re: MR_P_BODY] #1406345
03/22/13 11:31 AM
03/22/13 11:31 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
PM member phj426, Paul bought my old 508 RB a few years back, been driving it ever since (I think he went on the Hot Rod power tour with it last year) and he runs a 6-pack on it and he LOVES it. He wrote me saying he more than kept up with a new ZL1 (which is the blown ZL1 6.2 litre 565 horse 6 speed one).... and that was with friends and a loaded trunk and highway gears. And he's running factory 440 Magnum manifolds too ans it's in a 72 Road Runner so it's no 'Welter weight' to begin with That motor runs a set of Best Machine ported Iron stage V's on it.
The 4.25 stroke in a mild 9.75-10.5:1 motor with decent heads is an AWESOME driver and gets no worse mpg (if built sensibly) than a factory 440.
My present 517 Max wedge low deck (that I replaced that 508 with) was about a 100+ hp upgrade from the 508 (all above 4800 rpm or so -about the same but no more mid-range torque you need for cruising) but it's still extremely streetable.
I'll be happy to help you with the combination, I reckon I knowz a little 'bout strokers.
WIZE
In Car:
Re: 440 Street Motor Build advice needed [Re: Thumperdart] #1406346
03/22/13 12:31 PM
03/22/13 12:31 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
I reread his post and he preaty much wants to spend the money for a stroker kit.I would not put the 4.25 crank in because you really don't need that big and extra cost of machining the block and mabe a external oil pump. Cam is wrong and the intake is a bad choice and the stealth heads are ok but spend the money for ported because anything less is a waste plus add more money for valve springs and retainers to match the cam.You will need new push rods. The Isky iron rockers are ok but there is better choices in rollers. Any thing bigger than 1 7/8 headers you will have a fitment problem unless they are very exspensive headers.Stock manifold would be a waste because you have way to many cubes to put all the exhuast out stock manifolds. Stock oil pan is OK because you will never spin this thing so long that it will suck all the oil out. I race mine weekly and have never lost oil pressure. You said budgit it better be a good size one. Once you go down the road of aftermarket it gets exspensive.
Dom your car is going more and more to a light weight race car that is kind of streetable.My junk weighs 3,250 race weight and has all of 446 cubes with junk first run Stealth heads and a .625 roller cam and KB junk pistons and has well over 300 runs and has been 10.50s set on kill.Why do you and all the other guy think you need 500 plus cubes to go fast? I just need to add Nitrous add I would give you a tough race.
What ever happened to rebuilding a 440 and adding good heads and cam? Seams to me everyone is getting penis envy and has to go bigger than the other guy.
You have a great car but answer me this how many miles did you put on it last year and how many trips to the track did you make?
Re: 440 Street Motor Build advice needed [Re: slippery440] #1406347
03/22/13 01:04 PM
03/22/13 01:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
KINDA streetable? Come on now............... This heap is so streetable it`s funny and I figured when I started to lighten it that these statements would arise and remember; 9.79 of the trailer, 100 unleaded, street tires, exhaust and a bit over 3200...........peace! This last year because I moved and my car`s in a shack(photos to come) I drive it a lot less because it`s a b$%^h to get it in and out of the prison it`s now in. You will see a serious Thumper next time out and soon after, some REAL heads and a bigger cam and very low 9`s to follow..............
