replacement vacuum adv. unit
#1405967
03/21/13 06:10 AM
03/21/13 06:10 AM
Posts: 79 Germany
JS23U
Germany
Hi all, I wonder if the vacuum advance unit on my Mopar electric distributor (the one with the orange box) is bad. Question: Is there any replacement on the market that has the same advance and is adjustable with the Allen wrench? Which one should I buy? Mopar doesn't seem to offer any parts, just the whole dist... It is for a 440 engine.
Thanks Jens
Re: replacement vacuum adv. unit
[Re: JS23U]
#1405968
03/21/13 11:32 AM
03/21/13 11:32 AM
Posts: 1,008 wv
Dartcuda
wv
[Re: JS23U]
#1405969
03/21/13 11:56 AM
03/21/13 11:56 AM
RapidRobert
What's making you think it's bad? Borrow a vacuum pump & see if it will hold vacuum. All of em I've ever seen, the slope starting point is adjustable with the 3/32" allen wrench & you can solder strips of feeler gauge on the back side on the pod on either side of the notched arm to limit the arms' travel into the pod to limit the total if need be. Yes NAPA will have a selection & a can with 8 on the arm might be a good choice but one with more ain't a problem if you are willing to tune it with the strips.
[Re: JS23U]
#1405973
03/21/13 07:47 PM
03/21/13 07:47 PM
RapidRobert
Yeah I'm surprised that they both have the same total & that just the set tip in point is different especially since you do have a fair amount of adjustment there with the 3/32" allen wrench. Me I'd order both if I was overseas tho they do tend to be about as trouble free an item as you could ask for. Good luck with your project!
[Re: JS23U]
#1405975
03/22/13 09:57 AM
03/22/13 09:57 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
The german shop told me that the mounting bracket is different between VC-187 and 188. Is that possible?
Depends on application,some have a locating tab for the cap,some do not.Same for the plate,some have pin on arm,others on plate.
[Re: 62maxwgn]
#1405976
03/22/13 04:43 PM
03/22/13 04:43 PM
RapidRobert
I thought it was not right that both would have the same total so I called my parts house & they have a VC-188 on hand & it is stamped 10L. They dont have a 187 on hand to physically check & he checked the SMP site & said no spec info was given.
[Re: RapidRobert]
#1405977
03/23/13 09:33 AM
03/23/13 09:33 AM
Posts: 531 Virginia
JimG
Virginia
Robert:
It is my understanding that you can shorten the slot with JB Weld and a paper clip, but that might be an urban legend. ![](/ubbthreads/images/graemlins/grin.gif)
[Re: RapidRobert]
#1405984
03/24/13 07:52 PM
03/24/13 07:52 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
STANDARD VC187 ADVANCE STARTS 10.5 MAX ADV 8 DEGREES -10.5 15.5 HG
I'm a bit confused. is the arm stamped 8 or 10.5
I saw 9L one one web site for the VC187
