Page 2 of 12 1 2 3 4 11 12
Re: 65 Coronet AWB build [Re: a12superbee] #1404652
03/19/13 05:44 AM
03/19/13 05:44 AM
the Netherlands
Mr4Speed Offline
Mr4Speed  Offline
the Netherlands
Take-Yr-Hat-Off
Or something like that.
in other words, i take my hat off for you sir. Very very nice work!!!
Re: 65 Coronet AWB build [Re: Mr4Speed] #1404653
03/20/13 10:48 PM
03/20/13 10:48 PM
Western Md.
skicker Online happy OP
"The Champ"
skicker  Online Happy OP
"The Champ"
Western Md.
Add all the little panels that end up being one panel. Now is when it would be nice to own an English wheel.
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #1404654
03/20/13 10:51 PM
03/20/13 10:51 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
Then start replacing the numerous panels in the trunk floor.
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #1404655
03/20/13 10:55 PM
03/20/13 10:55 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
The new passenger side trunk floor pan tied into the new rear frame rails. Pic is from underneath. Here's where you try to make it look like the factory installed it.
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #1404656
03/20/13 10:56 PM
03/20/13 10:56 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
This the new floorpan tied into the new rear rails and the new trunk drop-off panel.
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #1404657
03/20/13 11:00 PM
03/20/13 11:00 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
Right rear spring shackle mount tied into new frame rail.
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #1404658
03/20/13 11:05 PM
03/20/13 11:05 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
Last one for now. This is the beginning of the new b pillar supports at the back of the roof. These used to be maybe 4" tall, back when the wheel well was in the stock location. Now its more like 10" or so.
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #1404659
03/31/13 09:20 PM
03/31/13 09:20 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
Another panel added to the rear roof supports.
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #1404660
03/31/13 09:22 PM
03/31/13 09:22 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
The final two panels added. Now all you have to do is make the other side match this one.
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #1404661
03/31/13 09:24 PM
03/31/13 09:24 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
Then fabricate the panel to attach the trunk hinge braces to the floor.
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #1404662
03/31/13 09:28 PM
03/31/13 09:28 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
Rear roof pillar and trunk support completed on the right rear.
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #1404663
04/01/13 09:34 AM
04/01/13 09:34 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
My name suggestion "Wallet Crusher"
Awesome work, very nice pics. You've got some great metal working talent, keep up the progress.
Re: 65 Coronet AWB build [Re: NV69B7RR] #1404664
06/24/13 02:54 PM
06/24/13 02:54 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
I have made a small amount of progress but have only a couple pics to show. I managed to pick up a 65 A-100 straight axle and decided to widen the front frame rails out to the centerline spring pad dimension of 35 5/8". I used all new 2x3 tubing from the front bumper to just inside the front of the leaf spring perches. I also managed to pick-up a pair of Anson 3 1/2" aluminum slots which will keep the offset from the wider straight axle front end very similar to what the original track width on the front was with the K frame and control arms. I just broke ground for a new shop, so making any progress soon is doubtful.
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #1404665
06/24/13 03:00 PM
06/24/13 03:00 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
The new 2x3 frame rail in the center of the car has a dimension of 51 1/2" from the leaf spring hanger to the 3.2 degree angle. The new front rail will be 54" and will be installed 5 1/2" below the bottom of the frame at the existing radiator support mount. This is where a digital level becomes a very handy tool to have.
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #1404666
06/24/13 03:07 PM
06/24/13 03:07 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
When finished the 2 rails pictured above will be in line and have an angle of 3.2 degrees up to attach to the bottom of the frame at the radiator support. I will be installing new floor pans so as to not have to repair the removal of all of the factory spot welds at the front frame and torsion bar cross-member.
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #1404667
06/25/13 09:55 AM
06/25/13 09:55 AM
Indiana
drodg Offline
drodg  Offline
Indiana
Looking good. I have owned three 1965 Coronet 500's and love the car as one of my favorites of all time. I will be excited to see how this unfolds.
Re: 65 Coronet AWB build [Re: drodg] #1404668
06/25/13 11:15 AM
06/25/13 11:15 AM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
WOW!!! that is incredible work!
Joey
Re: 65 Coronet AWB build [Re: jake4cars] #1404669
06/25/13 12:16 PM
06/25/13 12:16 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
Very Cool !
Where in Western Maryland are you ?????
Re: 65 Coronet AWB build [Re: belv2vert66] #1404670
06/27/13 02:32 PM
06/27/13 02:32 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
Cumberland...
I have this cool old skool roll-bar but have decided to go with a full perimeter cage instead.
...FAFO...
Re: 65 Coronet AWB build [Re: skicker] #1404671
01/10/14 11:11 PM
01/10/14 11:11 PM
Western Md.
"The Champ"
"The Champ"
Western Md.
I know it has been a while since I have followed up on this but that is why they are called projects. I've managed to get some trim holes welded up and finished fabbing up a trunk floor panel with new bead rolls to align with the existing ones. Thanks to finding a parts car in New York I have all the front sheet metal I need to get back into this thing pretty hard again. I also managed to score a really nice non dash pad dash frame.
...FAFO...
