oil leaking out of new coil. why ? #1404568
03/18/13 08:41 PM
03/18/13 08:41 PM
detroit,michigan
ctsuperbee Offline OP
detroit,michigan
hi guys, i installed new flame thrower coil on newly rebuilt eng. and ran car for first time breaking in cam 20-30 min. car ran fine and quit. oil leaking out of new ign coil made wire greasy and fell off. why would a new coil leak ? aftermarket 45000 volts flame thrower. i had same issue a few years back on a 440 6 pk motor and never did figure it out. do i need the inline resistor on the negative side ? i had it in when this happened this weekend. thanks
Re: oil leaking out of new coil. why ? [Re: ctsuperbee] #1404569
03/18/13 08:46 PM
03/18/13 08:46 PM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
Actually the oil filled aftermarket coils don't hold up laying sideways...You need the epoxy filled versions when mounting horizontal...
Re: oil leaking out of new coil. why ? [Re: ctsuperbee] #1404570
03/18/13 08:56 PM
03/18/13 08:56 PM
tighten up the screw down in the tower & that should stop the leak. Sometimes people get lazy/indifferent/overwhelmed on a fast moving assembly line
Re: oil leaking out of new coil. why ? [Re: screamindriver] #1404571
03/18/13 09:29 PM
03/18/13 09:29 PM
Western Oregon
bull Offline
bull  Offline
Western Oregon
Some coils are not designed to be mounted horizontally and will therefore leak if not mounted upright. If you still have the packaging take a look at the fine print and I would guess it says something about that. What I got was a black MSD Blaster 2 and peeled the label off it before mounting it in the stock position. Can't recall now if it's oil-filled but MSD said it could be mounted either way. Other than the missing date code and Mopar symbol it looks stock... and it's not leaking.
1968 Charger 383/2bbl/4spd (1 of 74) 1994 Dakota Sport 3.9L/AT/2WD 2003 Durango SLT 4.7L/AT/4X4 Yes, all Dodges and nothing else
Re: oil leaking out of new coil. why ? [Re: bull] #1404572
03/18/13 11:27 PM
03/18/13 11:27 PM
WV
JohnH Offline
JohnH  Offline
WV
If it quit running the coil may be shot.
Re: oil leaking out of new coil. why ? [Re: ctsuperbee] #1404573
03/18/13 11:52 PM
03/18/13 11:52 PM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
Take it back...
The round type, traditional coils use oil for cooling and it should not leak... Yes, it is best to mount vertically if possible for equal distribution of the internal oil..
Just my $0.02..
Re: oil leaking out of new coil. why ? [Re: Sinitro] #1404574
03/19/13 12:06 AM
03/19/13 12:06 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Did you run it without the ballast resistor specified by the coil manufacturer and cook the coil and now it's leaking?
Re: oil leaking out of new coil. why ? [Re: Sinitro] #1404575
03/19/13 12:13 AM
03/19/13 12:13 AM
Take it back...
Just my $0.02..
All the stock 383 and 440 as well as the 440 6 pak motors and 426 Street Hemi had the coils mounted sideways
Re: oil leaking out of new coil. why ? [Re: RapidRobert] #1404576
03/19/13 11:25 AM
03/19/13 11:25 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
tighten the screw they quit leaking!
Re: oil leaking out of new coil. why ? [Re: Dodgem] #1404577
03/19/13 01:21 PM
03/19/13 01:21 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have a red MSD Blaster 2 coil painted black mounted in my stock six pack mounting bracket laying on it side & have never had a problem with it yet.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: oil leaking out of new coil. why ? [Re: screamindriver] #1404578
03/19/13 01:54 PM
03/19/13 01:54 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
What's the country of origin?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: oil leaking out of new coil. why ? [Re: ctsuperbee] #1404579
03/19/13 03:07 PM
03/19/13 03:07 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Because it's cheap chinese junk , call whomever you bought it from and get another one. I have a flamethrower from back when they were USA made , a few years later i bought one and it was made in china , I sent it back without even opening the package and bought an MSD Epoxy filled coil , it was made in USA , but I think now MSD is now outsourcing also ...
Good luck...
Re: oil leaking out of new coil. why ? [Re: Rug_Trucker] #1404580
03/19/13 03:08 PM
03/19/13 03:08 PM
JohnRR Offline
JohnRR  Offline
Re: oil leaking out of new coil. why ? [Re: screamindriver] #1404581
03/19/13 03:11 PM
03/19/13 03:11 PM
JohnRR Offline
JohnRR  Offline
The Flamethrower I bought back in '99 , USA made , I mounted horizontal and it never leaked a drop. It's been sitting in a box in my basement since 2000, I'm sure laying on it's side , I'll have to see if it's leaking ...
Re: oil leaking out of new coil. why ? [Re: JohnRR] #1404582
03/19/13 06:39 PM
03/19/13 06:39 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
On the same vein, can one mount the Accel Super Coil
horizontally? (the big yellow finned one) I've looked at the web site, but no info....thanks
Joe
Re: oil leaking out of new coil. why ? [Re: JohnRR] #1404583
03/19/13 11:04 PM
03/19/13 11:04 PM
Harrisburg, Pa.
Harrisburg, Pa.
I'm sure it's more a case of poor quality craftsmanship than anything...I went through the ordeal a few years ago when I was using the horizontal mounting bracket and had leaking pig...Then started checking into it...Why would a manufacturer even give a disclaimer on how the coil is mounted ??? Obviously they know there's a problem with the design... Then acted like I should have known all along about it...
Re: oil leaking out of new coil. why ? [Re: jlatessa] #1404584
03/20/13 10:29 AM
03/20/13 10:29 AM
30 years ago I did (& no ballast ) & never missed a beat, ymmv
Re: oil leaking out of new coil. why ? [Re: jlatessa] #1404585
03/20/13 12:11 PM
03/20/13 12:11 PM
Rug_Trucker Offline
Rug_Trucker  Offline
Joe
I had one in '77, vertical was what it said to do! I didn't run 2 resisters and it burned out my '77 model Direct Connection chrome box.
Re: oil leaking out of new coil. why ? [Re: JohnRR] #1404586
03/20/13 12:18 PM
03/20/13 12:18 PM
Rug_Trucker Offline
Rug_Trucker  Offline
Chineeeeez? I have a Blaster II been running sideways for years. I heard they had some junkers.
Re: oil leaking out of new coil. why ? [Re: Rug_Trucker] #1404587
03/20/13 01:23 PM
03/20/13 01:23 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Yes, vertical on the Accel super coil, got a reply back from them....
"Your request (#9830) has been deemed solved.
Scott, Mar 20 09:29 (EDT):
Hello,
We recommend installing and mounting the 140001 coil vertically. Mounting this coil in any other position could cause a "dry spot" on the coil windings that prevents proper cooling of the coil.
Please let us know if you need additional help.
Thank you,
-Scott"
