Re: Roller rockers for my stealth heads??? [Re: 70satelliteguy] #1404516
03/20/13 05:03 PM
03/20/13 05:03 PM
'Source super stealths require offset rockers on the intake side I believe. Can you use any brand or are you locked into using Sources' house brand?
Re: Roller rockers for my stealth heads??? [Re: RapidRobert] #1404517
03/20/13 05:24 PM
03/20/13 05:24 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Where do you see SUPER stealth ?
Re: Roller rockers for my stealth heads??? [Re: JohnRR] #1404518
03/20/13 05:53 PM
03/20/13 05:53 PM
Double R I am hijacking the thread. You got a problem with that
Re: Roller rockers for my stealth heads??? [Re: RapidRobert] #1404519
03/20/13 05:56 PM
03/20/13 05:56 PM
JohnRR Offline
JohnRR  Offline
Re: Roller rockers for my stealth heads??? [Re: RapidRobert] #1404520
03/20/13 06:41 PM
03/20/13 06:41 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
any brand .650 offset intake
Re: Roller rockers for my stealth heads??? [Re: CSK] #1404521
03/20/13 07:09 PM
03/20/13 07:09 PM
Thanks bro, Been debating whether to step up to them as a bare set is only $200 more than a set of the regular (bare) stealths & I already have a new set of 2.14/1.81 valves
Re: Roller rockers for my stealth heads??? [Re: RapidRobert] #1404522
03/20/13 07:40 PM
03/20/13 07:40 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I thought source didn't sell their regular stealth heads "bare" anymore, just the super stealths were available bare?
Re: Roller rockers for my stealth heads??? [Re: DaytonaTurbo] #1404523
03/20/13 09:32 PM
03/20/13 09:32 PM
$399 ea bare for the regular stealths & $499 ea bare for the super stealths
Re: Roller rockers for my stealth heads??? [Re: RapidRobert] #1404524
03/21/13 12:42 PM
03/21/13 12:42 PM
dogdays Offline
dogdays  Offline
RR, the only reason you want bare heads is so you can use those 3/8" stem valves you have lying around. Time to move on! 5/16 or 8mm stems have much less mass and don't block the airflow as much.
R.
Re: Roller rockers for my stealth heads??? [Re: dogdays] #1404525
03/21/13 12:48 PM
03/21/13 12:48 PM
RR, the only reason you want bare heads is so you can use those 3/8" stem valves you have lying around. correct. Time to move on! cant, budget constraints. 5/16 or 8mm stems have much less mass and don't block the airflow as much. I agree but on this street app I'll be fine .
Re: Roller rockers for my stealth heads??? [Re: RapidRobert] #1404526
03/21/13 01:05 PM
03/21/13 01:05 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You'll have more in machining costs to open the guides & install larger ID bronze guides than if you'd bought complete heads...
Re: Roller rockers for my stealth heads??? [Re: 1_WILD_RT] #1404527
03/21/13 01:09 PM
03/21/13 01:09 PM
My plan was to have my buddy open the guides & he's pretty reasonable (I'm seeing his sister) but do I have to use bronze guides or do they already come with bronze guides or ???
Re: Roller rockers for my stealth heads??? [Re: RapidRobert] #1404528
03/21/13 01:15 PM
03/21/13 01:15 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
It may have enough material to be opened up, we're only talking .032 but if the guide winds up to thin you'll be doing guides...
Re: Roller rockers for my stealth heads??? [Re: 1_WILD_RT] #1404529
03/21/13 01:28 PM
03/21/13 01:28 PM
Alright I'll at least give 'Source a call & see if they have a problem with me opening em up. thank you for the addit'l info guys & I'll do what I need to do to get em right
Re: Roller rockers for my stealth heads??? [Re: RapidRobert] #1404530
03/21/13 08:27 PM
03/21/13 08:27 PM
Idaho
LaRoy Engines Offline
Idaho
There shouldn't be any problem opening the Stealth or S/Stealth guides for 3/8 valves as the guide outside diameter is over .540".
Re: Roller rockers for my stealth heads??? [Re: LaRoy Engines] #1404531
03/21/13 10:07 PM
03/21/13 10:07 PM
That's good to hear
