Re: T&D rockers-- INDY 360-2
[Re: instigator]
#1402271
03/14/13 03:14 AM
03/14/13 03:14 AM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
The rockers I saw on Indy sb heads used smaller single shaft with larger diameter collars where they meet the pedestals on the heads
Sorry, I didn't follow your post...you answered my later question....thanks also!
anyone know a good place to order them up.
Order directly form T&D. I don't know of any one that is a DEALER that could give you a discount. Their Customer Service and Knowledge is top notch. I have dealt with them twice and will always go to them for rockers.
Make sure you ask them about what options are available for the rockers you looking at. They have options that aren't listed anywhere. Like shot-peening, roller-tip oiling through the arm, and few others. Usually at Minimal or NO charge.
[Re: b1dartsport]
#1402274
03/14/13 03:30 AM
03/14/13 03:30 AM
Posts: 1,090 north cakalaky
instigator
north cakalaky
That would be awesome...timkens for side thrust and bushing for radial movement on the shaft.....
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: instigator]
#1402276
03/14/13 11:01 AM
03/14/13 11:01 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Yeah.. as said/shown they offer the 2 types of rocker set up.... single shaft for stock oiling.. and the multi small shafts but this must use push rod oiling.. I have both set ups on different SB that I have
[Re: instigator]
#1402278
03/14/13 08:46 PM
03/14/13 08:46 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Anyone know if any machine work needs to be done to Indy 360-2 heads for T&D rockers to work...Do the T&D rockers have smaller shafts...any details would be great....I'm somewhere around 220psi closed/ high 400's open on a smith machine lifters/solid flat tappet...want to put some street miles on the motor and may worry to much with the Indy rockers.....What do yall think???
Did you have problems with the INDY rockers not holding there lash? I ran mine on the dyno for about eleven runs and each one I had to re adjust the lash. Drove me nuts. Flat mechanical with schubeck lifters.Matt
[Re: b1dartsport]
#1402280
03/15/13 09:06 AM
03/15/13 09:06 AM
MattW
Ontario Canada
I ran mine with a Crane solid roller and Crane super pro lifters,Smith Bros 3/8 pushrods,checked lash all the time because I am anal with that stuff. Never had one go out of adjustment.
I've tried to set it. Wonder if I was doing something wrong or bad adjusters?
