T&D rockers-- INDY 360-2
#1402251
03/13/13 11:38 PM
03/13/13 11:38 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
Anyone know if any machine work needs to be done to Indy 360-2 heads for T&D rockers to work...Do the T&D rockers have smaller shafts...any details would be great....I'm somewhere around 220psi closed/ high 400's open on a smith machine lifters/solid flat tappet...want to put some street miles on the motor and may worry to much with the Indy rockers.....What do yall think???
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
Re: T&D rockers-- INDY 360-2
[Re: instigator]
#1402253
03/14/13 12:02 AM
03/14/13 12:02 AM
Posts: 795 Glendale Az
Darryls-Demon
Glendale Az
If you are going to use this style T@D set up you need to have the pedistials milled off, it is a very nice setup I wish my BB had this setup also.
[Re: Darryls-Demon]
#1402254
03/14/13 12:34 AM
03/14/13 12:34 AM
instigator
north cakalaky
The T&D 8120 rockers for the indy heads seem to be single shaft....maybe they use some form of mounting bushing to run a smaller diameter shaft so they can have a bearing in the rockers....anyone know...if not I'll give them a ring in the morning.
[Re: instigator]
#1402255
03/14/13 12:48 AM
03/14/13 12:48 AM
Posts: 52,972 Romeo MI
MR_P_BODY
The single shaft ones do have a smaller diameter shaft but have a bushing over the shaft where they mount to the head
[Re: SB449VALIANT]
#1402267
03/14/13 02:49 AM
03/14/13 02:49 AM
instigator
north cakalaky
so they seem to offer a couple styles....standard single shaft or mini shafts on a steel machined plate...the 2nd way definetly seems like quite a bit of work.........so B1, what form of bushing/bearing are on the single shaft units?..do they oil through the head?
[Re: instigator]
#1402269
03/14/13 03:02 AM
03/14/13 03:02 AM
Posts: 982 western pennsylvania
b1dartsport
The set I have oil through the head,but I was told you could order pushrod oiling no change in price or fitment. They come completely assembled,like Ersons, I have never taken one off the shaft. I am not sure if they are bushed or have roller bearings.
