Page 1 of 3 1 2 3
440 MPG? #1401941
03/13/13 12:24 PM
03/13/13 12:24 PM
Paris, Tx
mopartruckguy Offline OP
Paris, Tx
Who has some real world numbers from a 4x4 with 33"/35" tires and a 440 with 400+ HP. What could a fellow expect the mileage to be on a motor of this caliber?
Re: 440 MPG? [Re: mopartruckguy] #1401942
03/13/13 12:33 PM
03/13/13 12:33 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
probably around 6-8mpg would be my guess.
Re: 440 MPG? [Re: chrisf] #1401943
03/13/13 12:45 PM
03/13/13 12:45 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Back in the early 80's, I had a '75 Ramcharger with a stock 440, 3.55 gears and 33" tires. That thing got 8 MPG whether it was towing or not towing.... Certainly was no rocket but it had nice torque. With a little more horsepower as you have mentioned and some compression, I still doubt you'd ever get over 10 MPG.
Re: 440 MPG? [Re: superwrench] #1401944
03/13/13 03:29 PM
03/13/13 03:29 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
My old 86 W250 with a 440, 4 spd, 285/75/16s and 4.10s got terrible mileage. Less than 8 mpg in most cases. However, I never expected it to get very good with a 850 double pumper on it. I didn't care what it got, just as long as it ran good. If you want mileage, you need to go diesel.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 440 MPG? [Re: 71yelladustr] #1401945
03/13/13 05:02 PM
03/13/13 05:02 PM
pana illinois
bigblock4x4 Offline
bigblock4x4  Offline
pana illinois
i have a 78 3/4 ton with a 440 that gets around 6,it has a loose converter,4.10's and 35"tires,i use an 800 holley,10.0 to 1,nice cam ported heads,prolly makes 450-475 horse maybe.
Re: 440 MPG? [Re: bigblock4x4] #1401946
03/13/13 05:12 PM
03/13/13 05:12 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Almost all 4wds with 3spd autos no matter what motor got 10 or less that I've seen.
I had a 400/727 3.23 295/50s and got 11.4 when driving easy and 4.6 when getting on it and it was a very mild motor. Don't plan for more than 10mph. Plus its a truck with a flat nose
Re: 440 MPG? [Re: 76dodgeboy] #1401947
03/13/13 06:12 PM
03/13/13 06:12 PM
foristell mo
serano Offline
serano  Offline
foristell mo
10 on a good day-78 400 runs 11 with a tailwind,8 usually
Re: 440 MPG? [Re: serano] #1401948
03/13/13 09:33 PM
03/13/13 09:33 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
My 93 Ramcharger with the rebuilt mild 440 was getting 8-10 mpg on average.
This was with a 727, 34" tires, 4.10 gears. 95% highway use. Never drove it over 60mph.
It now waiting for the remainder of a 518 OD swap.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 440 MPG? [Re: hp383] #1401949
03/13/13 10:25 PM
03/13/13 10:25 PM
Paris, Tx
Paris, Tx
Sounds like 7 to 8 is a pretty average number. Thanks everyone.
Re: 440 MPG? [Re: mopartruckguy] #1401950
03/14/13 09:30 AM
03/14/13 09:30 AM
scratchnfotraction Offline
all though not a 4x4,my 88-440/727/3.91sg with 29x15x15 M/Ts got a flat 10 mpg.
swaped in 3.23 with a new q-jet/performer RPM intake and picked it up to 13 mpg.
hoping a 2.76 gear will net me a couple more for 15-16 mpg. then I could drive to the next town over for more gas.
I gave up on mpg in a 4x4 muself.
Re: 440 MPG? [Re: scratchnfotraction] #1401951
03/14/13 10:26 AM
03/14/13 10:26 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
My "truck" (motorhome) .... was getting 12 or so ....with a TQ and Streetmaster intake(way better UPgrade from the OEM garbage) .... but later on - with a new-tech cam, head work, exh work, going from a 4.56 to a 3.73 gear and more compression(flat top pistons) it will get 16 ....and I have been challenged on that .... two people have bet me it can not be done .... so I have two bets - a total of 3500$ !
Re: 440 MPG? [Re: dOc !] #1401952
03/14/13 02:16 PM
03/14/13 02:16 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
doc can you give us some more info. i'd like to hear how you get that big whale to nail that mileage down.
Re: 440 MPG? [Re: chrisf] #1401953
03/14/13 08:41 PM
03/14/13 08:41 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
NO real trick there cf ... just keeping the MPH around 60(the MH is a pretty AERO piece) ..... and putting on a better fuel delivery combo .... that being a TQ and a StreetMaster intake. THEN playing with the metering rods
Now my 16 mpg mark is NOT going to be an average of say a trip from MI to FL ... it will be with a measured 1 gallon container ...and will be run on-the-flat.
HONESTLY .... I think that it will be closer to 18
...with the new cam, compression, SP2P intake and the gear change.
Re: 440 MPG? [Re: dOc !] #1401954
03/15/13 01:06 PM
03/15/13 01:06 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I dont see a big camper getting 16-18 if the trucks with a 318-360 barely pull that with 3.23grs. Good luck
Re: 440 MPG? [Re: dOc !] #1401955
03/16/13 01:32 AM
03/16/13 01:32 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
What kind of motorhome are talking about? The 24' over cab style or the raised roof extended van style? BIG DIFFERENCE in weight!
I do believe you can get 18-20 out of a 440, I did it back in the 90's with my 79. For 2 weeks I drove it to work and made sure I stayed away from the floorboards with the gas pedal. I did average 20 MPG! I just don't know about an over the cab style MH!? But I'm all ears.
Re: 440 MPG? [Re: 77ProStreet] #1401956
03/17/13 11:29 AM
03/17/13 11:29 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
My 78,000 mile 74' Ramcharger with the unmolested 440, fulltime 4 wheeldrive gets 9mpg. The only time I've checked it is during the cold weather. I've had a tough time not modifying the motor, I know I can make it better.Dave
Re: 440 MPG? [Re: quickd100] #2912720
04/21/21 01:07 AM
04/21/21 01:07 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Is this worthy of additional chat ?
Re: 440 MPG? [Re: dOc !] #2912933
04/21/21 02:39 PM
04/21/21 02:39 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
My 1980 W150 shortbox had a 440 auto w/3.73 gears and 35" tires got 8 mpg & 1985 W350 440-4speed w/4.10s and 235/85R16's gets about 8
Re: 440 MPG? [Re: 500ciDuster] #2912984
04/21/21 03:47 PM
04/21/21 03:47 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
What are the driving conditions?
8 mpg ? ... only a apimp from the least coast of Florida could continue dealing with those conditions!
Re: 440 MPG? [Re: dOc !] #2912990
04/21/21 04:06 PM
04/21/21 04:06 PM
Atlanta, GA
mgoblue9798 Online content
mgoblue9798  Online Content
Atlanta, GA
I am up for it. But, you already know what I am up to. Was it 440 or 413 you were running to get 12mpg? That is pretty impressive for an RV.
My 413 heads are going to the machine shop tomorrow to get cleaned, magged, and shaved. Then it will be time to get after the chambers with some roloc grinding discs.
I am thinking about just doing a basic clean up of casting flash and overhangs between the port and exhaust valves. There is a BIG overhang in the runner just behind the bottom of the pressed in exhaust seat. I wonder if there would be any mileage gain from a 3 or 5 angle valve job on the intake side? Exhaust I think I want to keep the nice fat seat contact width for cooling.
It will be a while before I have any numbers with the new engine, but will get baseline gas mileage numbers with the old one this summer.
Anyone have any experience with a do it yourself ceramic coating for piston tops?
Page 1 of 3 1 2 3
