Page 2 of 5 1 2 3 4 5
Re: Popping through the carb problem. [Re: skicker] #1401726
03/13/13 09:38 PM
03/13/13 09:38 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Sure sounds like a cam lobe...really hope it's not!! BTDT not fun(or cheap) Good luck and let us know what ya find
Re: Popping through the carb problem. [Re: Challenger 1] #1401727
03/13/13 09:56 PM
03/13/13 09:56 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
Stu, is there a reason you took down the picture of the 2 plugs?
Yes that was just a stock photo and not indicitve of the one's i have.
Here are my plugs as i just pulled them to check the condition so far.
They seem to be fine but then they only have about 100 miles on them all so far.
Re: Popping through the carb problem. [Re: MidPenMopar] #1401728
03/13/13 10:04 PM
03/13/13 10:04 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Make sure your nuts/bolts that hold the carb to the manifold are torqued to a min of 150 in lbs .
Not just tight by hand with a ratchet
sometimes the stupidest things ...
did you adjust timing this year , ?
What else did you touch / change . go backwards .
vacuum advance attached or plug fell off the port ?
You just had a little surgery with the header change , something didnt go back together right .
did it do it last year ? ..
recheck your wires , buy some firewires with teh big numbers on them ..
because you just did something , Ill bank on it not being a cam ..
Re: Popping through the carb problem. [Re: sogtx] #1401729
03/13/13 11:45 PM
03/13/13 11:45 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
Just my two cents but,
If my car was running well and I did a few things to it and it started running like crap, I would look really hard at what I did to make sure it was right and possibly start reversing things to see if it cleared up.
Arno
Re: Popping through the carb problem. [Re: B1arno] #1401730
03/14/13 12:13 AM
03/14/13 12:13 AM
Arno
You know it's not running bad it runs just fine except for that popping at low RPMs. That's why it hard to diagnose, im going to try new plugs first and see if that helps??
Re: Popping through the carb problem. [Re: dodgedon] #1401731
03/14/13 12:25 AM
03/14/13 12:25 AM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
I'm going to say its too lean. The same as when its not up to temp. I have had this problem with Eddy carbs before. More so on trucks... When under load they pop back. You can have the same effect when the choke is off and the engine has not completely warmed up. Lean pop...
I'd be looking for an intake/vacuum leak and then start going through the carb.
Re: Popping through the carb problem. [Re: MidPenMopar] #1401732
03/14/13 12:47 AM
03/14/13 12:47 AM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
Arno
Thats what I would do. Change back one at a time what you can to see if that makes the difference.
Re: Popping through the carb problem. [Re: B1arno] #1401733
03/14/13 02:00 AM
03/14/13 02:00 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Sorta unrelated but here goes:
Last year I installed a Gear Vendors overdrive unit. To get it to fit, I had to cut out the exhaust crossover pipe. The engine sits in the car a bit out of level, so I tried to clock it after loosening the motor mount nuts. I laid a 2 foot level across the valve covers, but I had to spin the distributor a few degrees because the vacuum can was in the way....After the GV was in, I drove to the exhaust/muffler shop. The car ran terrible and was really slow turning over. It pinged & detonated even at light throttle. I pulled over about a mile after leaving and clocked the distributor until the car ran like before. That wasn't all though. I had also removed the valve cover breather. I noticed a CLANG then saw a chrome ball rolling behind me as I was rolling at about 50 mph. (What the heck was tha..... Oh, I know what it was)
The point is, it was good advice from the guy who suggested to try looking at the changes you made.
Re: Popping through the carb problem. [Re: MidPenMopar] #1401734
03/14/13 07:54 AM
03/14/13 07:54 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Are you sure those are the correct style plugs for your heads, they look awfully short to me? My 440 heads take a long reach plug.
Then use just a drop or two of motor oil on the the threads, no anti seize, imo. Good luck to you!
Re: Popping through the carb problem. [Re: Challenger 1] #1401735
03/14/13 09:00 AM
03/14/13 09:00 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Stock heads like Stu runs take short reach plugs, Edelbrock's take long reach plugs.. Small blocks take long reach... For Stu's car those look Ok but I'd still screw in a set of NGK's just to see were it puts him..
Re: Popping through the carb problem. [Re: 1_WILD_RT] #1401736
03/14/13 09:28 AM
03/14/13 09:28 AM
Cincinnati, Ohio
Cincinnati, Ohio
Re: Popping through the carb problem. [Re: MidPenMopar] #1401737
03/14/13 10:14 AM
03/14/13 10:14 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
The 70 383 Mag in my Power Wagon did the same thing. Eddy 600 AFB, larger, high 400's cam & not much torque to get the beast rolling.
I added a 1" four hole phenolic spacer & that helped the carb signal, but it would still pop off idle at a light if I wasn't careful. Leak down test revealed two dead cylinders & my hands would get wet with fuel when I held them over the tail pipes. I suspected a blown head gasket between cylinders, but when disassembled to install new heads & smaller cam, turns out the orig heads did not have hardened seats & the exhaust valves were sunk into the head so far, they weren't sealing at all, allowing the intake charge to go right out the exhaust & causing a lean condition. New heads with hardened seats, smaller torque cam & viola, no more popping thrut he carb. The other guys like Randy, who're a lot more mechanic savy than me, might chime in about burnt valves causing the popping.
Re: Popping through the carb problem. [Re: Triggerfish] #1401738
03/14/13 10:27 AM
03/14/13 10:27 AM
I will get a new set of regular plugs and see what happens when i install them without the anti sieze on the theads. Maybe these shortie plugs are to blame for the problem??
Personally i think it's an issue with fuel loading up in the carb due to the transmission getting into overdrive too quickly. I say this as if i shift manually and stay out of overdrive untill over 2500 RPM the problem does not happen.
I can stand on it and let the transmission shift automaticly and no popping issue all the way to redline....
Re: Popping through the carb problem. [Re: 1_WILD_RT] #1401739
03/14/13 02:23 PM
03/14/13 02:23 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Try a set of NGK plugs.they are cheap and work.I run them in my aluminum headed 440 with 12.5 domes on the street.I also dont care for Accel wires.I run Taylors on everything.Mine with 2 inch TTIS have been on at least 12 years.My kids 413 with 2 1/8 tubes have been on 5 years with no problems.He runs my old worked 516s with NGK plugs.You migh also have a valve thats just barely burnt.Compression test would tell.Also to check timing chain.Turn crank to zero.Then while someone watches manually turn it back till the dist moves moves.I like to see less than 10 degrees on an old chain.Rocky
Chrysler Firepower
Re: Popping through the carb problem. [Re: MidPenMopar] #1401740
03/14/13 03:52 PM
03/14/13 03:52 PM
God's Country Maryland
GODSCOUNTRY340 Online content
GODSCOUNTRY340  Online Content
A burnt valve wouldn't cause popping through the carb. You'd have a dead cylinder and/or popping out the exhaust with a burnt valve. Exhaust valves are the ones that get burnt. I've NEVER seen a burnt intake valve.
Re: Popping through the carb problem. [Re: GODSCOUNTRY340] #1401741
03/14/13 04:36 PM
03/14/13 04:36 PM
P
Paul_Fancsali Offline
P
Replace the accel plugs J-12Y or RJ12-Y the accell are too cold period
Re: Popping through the carb problem. [Re: GODSCOUNTRY340] #1401742
03/14/13 06:14 PM
03/14/13 06:14 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
You're right & it was popping thru the carb, but that must've
been because of a lean condition. The cam was way to big for
the truck & I read in the Eddy manual that big cams can cause a lean
condition off idle? It only backfired thru the tail pipe a couple of
times when first starting up.
Re: Popping through the carb problem. [Re: Paul_Fancsali] #1401743
03/14/13 07:35 PM
03/14/13 07:35 PM
I just got a set of Ac Delco R435 plugs to try this time.
Re: Popping through the carb problem. [Re: MidPenMopar] #1401744
03/15/13 08:46 PM
03/15/13 08:46 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I had A 360 and it did that because it rounded a cam lobe off
Re: Popping through the carb problem. [Re: 500ciDuster] #1401745
03/15/13 09:37 PM
03/15/13 09:37 PM
Put in the new plugs and it fired up nicely and sounds a little better. I will take a test run tomorrow and see if the new plugs did any good?
