1971 Plymouth 'Cuda wire diagram needed for elec window #1401696
03/13/13 12:05 AM
03/13/13 12:05 AM
Oklahoma
TinCuda Offline OP
TinCuda  Offline OP
Oklahoma
I am trying to get my (P31) electric windows working. The motors are good because I can get them to run up and down when I jumper 12 volts straight to the motor leads. I really need a good wire diagram to sort this out. Thanks.
1971 'Cuda, Standard instrument (non-rallye) dash, No A01 light package.
Re: 1971 Plymouth 'Cuda wire diagram needed for elec window [Re: TinCuda] #1401697
03/13/13 12:23 AM
03/13/13 12:23 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
This is the best I can do for you, some prints are 70 E body, but should cover the 71 application, while not an actual schematical print, you can still locate the wire color code using the color chart in the block print, and the pin/connector/terminal letters/numbers associated with the assorted terminal pics in the prints
Mike
Re: 1971 Plymouth 'Cuda wire diagram needed for elec window [Re: DAYCLONA] #1401698
03/13/13 12:23 AM
03/13/13 12:23 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: 1971 Plymouth 'Cuda wire diagram needed for elec window [Re: DAYCLONA] #1401699
03/13/13 12:24 AM
03/13/13 12:24 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: 1971 Plymouth 'Cuda wire diagram needed for elec window [Re: DAYCLONA] #1401700
03/13/13 12:29 AM
03/13/13 12:29 AM
Oklahoma
TinCuda Offline OP
TinCuda  Offline OP
Oklahoma
Thank you very much. That will get me started.
(O O {]{]{]||[}[}[} O O) 1971 Plymouth 'Cuda 440-6 {||O||} 2000 Yamaha V-Max (O O [========= SRT] O O) 2011 Dodge Challenger SRT 392 . Making as big as a carbon footprint as I can!!!
Re: 1971 Plymouth 'Cuda wire diagram needed for elec window [Re: TinCuda] #1401701
03/13/13 12:36 AM
03/13/13 12:36 AM
Oklahoma
TinCuda Offline OP
TinCuda  Offline OP
Oklahoma
I would still like to find a wire schematic so I can ring out the wires.
Re: 1971 Plymouth 'Cuda wire diagram needed for elec window [Re: TinCuda] #1401702
03/13/13 12:45 AM
03/13/13 12:45 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Ken,...here's 2 more
Mike
Re: 1971 Plymouth 'Cuda wire diagram needed for elec window [Re: DAYCLONA] #1401703
03/13/13 12:46 AM
03/13/13 12:46 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: 1971 Plymouth 'Cuda wire diagram needed for elec window [Re: DAYCLONA] #1401704
03/13/13 12:53 AM
03/13/13 12:53 AM
Oklahoma
TinCuda Offline OP
TinCuda  Offline OP
Oklahoma
Very nice! That is great. You are the man!
Re: 1971 Plymouth 'Cuda wire diagram needed for elec window [Re: TinCuda] #1401705
03/13/13 12:58 AM
03/13/13 12:58 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Glad to help...
Mike
