Re: Best intake for a 440 [Re: BSB67] #1400985
03/12/13 10:48 AM
03/12/13 10:48 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
The indy dual plane is a Max wedge manifold with big MW plenum chambers but (as delivered) the runners are tapered down to 440 size ports, they are very easy to open up if you go max wedge and will support a 700+ HP motor.
The SD used to be my favorite 440 street/strip manifold and it is a great "default" 500" stroker manifold in cases where a dual plane could give you more torque than you can put to the ground. But the 440 2-D is now because it's the most versitile and will produce broader and higher average torque up to ~700 hp than any single plane with an Automatic and moderate street gears/stall. The Performer RPM is a great piece but it is more limited internally in terms of how much you can port it, the 2-D does everything an RPM can do and has potential (room to grow) to do more.
Allegedly the 2D is based on the 426 Max Wedge NASCAR intake, In well-ported form it pulls up past 6800 on a 12:1 517" low deck motor with some of the very best flowing MW heads out there, Chapman Stage VI maxies.
WIZE
In Car:
Re: Best intake for a 440 [Re: Streetwize] #1400986
03/12/13 01:13 PM
03/12/13 01:13 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Aren't there a lot of people that make the case for the Weiand tunnel ram being the best intake for a 440?
Re: Best intake for a 440 [Re: Streetwize] #1400987
03/12/13 05:44 PM
03/12/13 05:44 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
This man knows what he is talking about.
I use the Indy Dual plane and Dwayne Porter told me the same thing as Streetwize said. It comes with Max Wedge runners that size down to standard ports. But all you have to do is open the ports to max wedge size maybe a 1/2" deep and you have a max wedge ports and runners sizes. Dwayne reccomnded the Indy dual plane for me and so far I love it. But on a stock 440 with basic heads it may not be needed as the RPM should handle that. A stroker with some heads that flow should like the Indy dual plane better. Ron
Re: Best intake for a 440 [Re: 383man] #1400988
03/13/13 01:12 PM
03/13/13 01:12 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Yep, the tunnel ram is best, but too many people are afraid of tuning 2 carbs even though in reality it's easy.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Best intake for a 440 [Re: Slingshot383] #1400989
03/13/13 05:03 PM
03/13/13 05:03 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Nothing wrong with a TR and yeah they're fairly easy to tune, it's more just the "Oh yeah, I got to cut a hole in the hood" thing I'll bet
And if I'm gonna go through the trouble to cut a hole in the hood....it's probably gonna be for a blower
WIZE
In Car:
Re: Best intake for a 440 [Re: Slingshot383] #1400990
03/13/13 10:36 PM
03/13/13 10:36 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree the tunnel ram makes great power but no way would I ever cut a hole in the hood of my 63 to run a tunnel ram. Now my brother runs a tunnel ram on his 64 and he likes it alot but he uses the 64 Hemi scoop thats way taller then the stock one as his looks to be about a 5" scoop to fit the tunnel ram under it. But I dont care so much for the taller then stock Max Wedge and Hemi scoops so what I use needs to fit under my stock max wedge scoop. Here is my brothers 64 with the tunnel ram and scoop. I am just not a big fan of the taller scoops like his. Just dont tell my brother ! Ron
Re: Best intake for a 440 [Re: Streetwize] #1400991
03/13/13 11:09 PM
03/13/13 11:09 PM
richmond indiana
I
ichsam Offline
ichsam  Offline
I
richmond indiana
Well said. &. Hands down this mans best choice in intakes.
