Re: Best intake for a 440
[Re: BSB67]
#1400985
03/12/13 10:48 AM
03/12/13 10:48 AM
Posts: 9,881 Weddington, N.C.
Streetwize
Weddington, N.C.
The indy dual plane is a Max wedge manifold with big MW plenum chambers but (as delivered) the runners are tapered down to 440 size ports, they are very easy to open up if you go max wedge and will support a 700+ HP motor.
The SD used to be my favorite 440 street/strip manifold and it is a great "default" 500" stroker manifold in cases where a dual plane could give you more torque than you can put to the ground. But the 440 2-D is now because it's the most versitile and will produce broader and higher average torque up to ~700 hp than any single plane with an Automatic and moderate street gears/stall. The Performer RPM is a great piece but it is more limited internally in terms of how much you can port it, the 2-D does everything an RPM can do and has potential (room to grow) to do more.
Allegedly the 2D is based on the 426 Max Wedge NASCAR intake, In well-ported form it pulls up past 6800 on a 12:1 517" low deck motor with some of the very best flowing MW heads out there, Chapman Stage VI maxies.
[Re: Streetwize]
#1400987
03/12/13 05:44 PM
03/12/13 05:44 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
This man knows what he is talking about. I use the Indy Dual plane and Dwayne Porter told me the same thing as Streetwize said. It comes with Max Wedge runners that size down to standard ports. But all you have to do is open the ports to max wedge size maybe a 1/2" deep and you have a max wedge ports and runners sizes. Dwayne reccomnded the Indy dual plane for me and so far I love it. But on a stock 440 with basic heads it may not be needed as the RPM should handle that. A stroker with some heads that flow should like the Indy dual plane better. Ron
[Re: 383man]
#1400988
03/13/13 01:12 PM
03/13/13 01:12 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Yep, the tunnel ram is best, but too many people are afraid of tuning 2 carbs even though in reality it's easy.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
