Page 2 of 5 1 2 3 4 5
Re: Ran the 440 small block Dakota - Thoughts? [Re: Adobedude] #1399998
03/10/13 07:38 PM
03/10/13 07:38 PM
MD
ADakotaRTGuy Offline OP
MD
Truck is the wrong color...
We will agree to disagree, haha.
Re: Ran the 440 small block Dakota - Thoughts? [Re: ADakotaRTGuy] #1399999
03/10/13 07:50 PM
03/10/13 07:50 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Nice passes for being able to run on 87 gas. Lol I think if you changed a few thing it would really pick up.( more gear, some nitrous, bigger conv)
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Ran the 440 small block Dakota - Thoughts? [Re: 1967dartgt] #1400000
03/10/13 07:52 PM
03/10/13 07:52 PM
MD
MD
Have the Nitrous system installed, think we had a solenoid fail or would of had some times with that yesterday.
Re: Ran the 440 small block Dakota - Thoughts? [Re: ADakotaRTGuy] #1400001
03/10/13 08:46 PM
03/10/13 08:46 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Is this carbed or FI?
Re: Ran the 440 small block Dakota - Thoughts? [Re: 1967dartgt] #1400002
03/10/13 08:51 PM
03/10/13 08:51 PM
MD
MD
Fuel Injected
Re: Ran the 440 small block Dakota - Thoughts? [Re: ADakotaRTGuy] #1400003
03/10/13 08:59 PM
03/10/13 08:59 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Looks good, want to sell your valve covers? Plate or fogger?
Re: Ran the 440 small block Dakota - Thoughts? [Re: 1967dartgt] #1400004
03/10/13 09:01 PM
03/10/13 09:01 PM
MD
MD
Na, I like the valve covers, they are heavy though. Wasn't someone on here selling a set?
I am using a perimeter plate.
Re: Ran the 440 small block Dakota - Thoughts? [Re: 1967dartgt] #1400005
03/10/13 09:07 PM
03/10/13 09:07 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Your heads are misleading. Guys hear W9 and start thinking of heads that flow a minimum of 350. Problem arrives when you are porting and having to allow for the pushrod on a 59 degree block.
Those dakotas are heavy no doubt. 11.25 is probably a decent number for that combo.
If I can help you with your nitrous problems let me know. That is what it needs.
Leon
Re: Ran the 440 small block Dakota - Thoughts? [Re: Leon441] #1400006
03/10/13 09:11 PM
03/10/13 09:11 PM
MD
MD
Thanks Leon. We attempted to run the nitrous, but when we looked at the log it was really lean, so we just put it back on the trailer, going to test the fuel solenoid and make sure its spraying. On the dyno it was working fine.
Re: Ran the 440 small block Dakota - Thoughts? [Re: ADakotaRTGuy] #1400007
03/10/13 09:16 PM
03/10/13 09:16 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
Went and ran my 440 Dakota for the first time today. 59 Degree 4.125 bore/stroke, W9 heads worked by Ryan at SDSS. CR is only 9:1, was supposed to be a turbo motor, but was stationed in Italy so went away from that. Took it to Cecil today and went 11.25 at 118. 60 ft was 1.578, and 1.589 on the good runs. Running 26x10x16 slicks.
A video.
http://www.youtube.com/watch?v=1AZEXKCcUDQ
No credit to Chris at PIE?
Re: Ran the 440 small block Dakota - Thoughts? [Re: biff426] #1400008
03/10/13 09:18 PM
03/10/13 09:18 PM
MD
MD
A video.
I did on the other site. But yea, Chris at Performance Injection Equipment built it and brought it to the track for me. Good builder to work with.
Re: Ran the 440 small block Dakota - Thoughts? [Re: biff426] #1400009
03/10/13 09:39 PM
03/10/13 09:39 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I would ditch the perimeter plate. Spray bars work much better.
Re: Ran the 440 small block Dakota - Thoughts? [Re: 1967dartgt] #1400010
03/11/13 10:43 AM
03/11/13 10:43 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
A 4000 pound truck with a 9-1 small block and a 3500 converter running 11.20s is pretty good to me. Than going though the traps at 6000 rpm.my w8 goes though at 8000 with 4.56 gears.just think if your truck weigh 3000 pounds if the rule of thumb is right that's a 10.20 truck.i think if you want to make this truck fast you can but you have a light set up for nos or turbo.are you running a nos or turbo camshaft?
Re: Ran the 440 small block Dakota - Thoughts? [Re: Otherlane] #1400011
03/11/13 11:16 AM
03/11/13 11:16 AM
MD
MD
Yea dont get me wrong for what it is I am really happy. Chris did a great job after I changed the setup on him part way through. He did get a NA cam in there. 256 or so with .668 lift on a 110.
Re: Ran the 440 small block Dakota - Thoughts? [Re: ADakotaRTGuy] #1400012
03/11/13 04:34 PM
03/11/13 04:34 PM
MD
MD
Head flow numbers from Ryan.
.100"--76.5/N/A
.200"--145.0/113.1
.300"--204.8/167.6
.400"--261.1/215.7
.450"--283.3/227.9
.500"--306.8/236.1
.550"--319.4/240.9
.600"--337.4/245.3
.650"--348.2/248.4
.700"--353.1/251.2
Re: Ran the 440 small block Dakota - Thoughts? [Re: ADakotaRTGuy] #1400013
03/11/13 05:09 PM
03/11/13 05:09 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Lower compression might want higher RPM to squeeze some cylinder pressure out of it. You have the head flow to support it
Looks like a good app for spray if your not gonna spool it or pull the heads for more CR.
WIZE
In Car:
Re: Ran the 440 small block Dakota - Thoughts? [Re: Streetwize] #1400014
03/11/13 05:17 PM
03/11/13 05:17 PM
MD
MD
Already have the system in there.
Re: Ran the 440 small block Dakota - Thoughts? [Re: 1967dartgt] #1400015
03/11/13 05:30 PM
03/11/13 05:30 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
My thought exactly. That combo is the definition of mild and heavy. I think it works pretty good for not being ironed out yet.
Re: Ran the 440 small block Dakota - Thoughts? [Re: Adobedude] #1400016
03/11/13 06:06 PM
03/11/13 06:06 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Nothing wrong with the color... and it will absolutely fly with a turbo on it to double the power! LOL
Re: Ran the 440 small block Dakota - Thoughts? [Re: Duner] #1400017
03/11/13 06:10 PM
03/11/13 06:10 PM
MD
MD
You build it and pay for it Duner, I will put it on, haha. I will even give you a set of W9 Dakota headers in return.
