Re: 2.5 or 3" exhaust? 68 dart 360
[Re: pinkduster]
#1398722
03/08/13 09:54 PM
03/08/13 09:54 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
When I bought my 1974 360 Challenger it had 3" pipe and flowmasters off the headers. It was loud, and gutless. I bought one of the Jegs $200 mandrel bent exhaust kits with mufflers in the 2.5" size. The car picked up quite a bit and sounded better out of the exhaust tips.
I am lowering the car, removing the headers, and putting '70-'71 high flow factory exhaust manifolds on it. I will make up the required pipe to join up to the Jegs setup and will likely add a set of electic cutouts for fun (that might exit something like the T/A pipe).
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: GTSDart340]
#1398726
03/09/13 11:25 AM
03/09/13 11:25 AM
Posts: 4,957 WI
Dcuda69
WI
[Re: Challenger 1]
#1398727
03/09/13 11:39 AM
03/09/13 11:39 AM
Posts: 11,685 W. Kentucky
justinp61
W. Kentucky
3" is just silly for a 408, even more stupid for a 360 in a dart!!
You guys are a riot.
Call me silly. I get a kick out of some of your stuff too .
My 340 was about 450 hp, hydraulic cam and pump gas. It had 2 1/2" with flowmaster 40s with turn downs at the rear end. I bracket race the car some and had always run it with the exhaust off and deciced to leave it on one night to see what it would do. It was late in the fall and the air was great, in the first round of open time trials all of my friends ran near their best times. I went out and the car ran 7.45 when it should've been in the 7.20s. When I pulled into my pit I put the ramps on tha trailer and pulled the car on them and took the exhaust off. Went right back out and ran 7.26, the best it had ever ran was 7.24. Now keep in mind that my exhaust turned down before the rear end, no bends over the rear end. This was real back to back runs 10 minutes apart, not some keyboard B.S.
The 408 in my car now is around 550 hp on pump 93 and has 3" exhaust turned down at the rear end, it has gone 6.70 with the exhaust and 6.57 without. Not on the same night so I can't say it's holding it back. I drive this car a lot in the summer, there is no resonance at any rpm and it's only loud inside when I gouge on it.
[Re: justinp61]
#1398728
03/09/13 11:51 AM
03/09/13 11:51 AM
Challenger 1
Cincinnati, Ohio
He said his was street car, not a race car. 3" system is heavier than a 2.5" pipe. A dart is a smaller car than my challenger with 3" and it's tight under my E body. I don't care for my 3" X pipe TTI system and my 2.5" H pipe TTI pipes sound way better than the 3" X pipe, way better. I have BB in my 3" car, not a little wimpy 408.
Bigger is not always better is my point, especially for street car. Been there, done it.
[Re: Challenger 1]
#1398729
03/09/13 12:07 PM
03/09/13 12:07 PM
justinp61
W. Kentucky
[He said his was street car, not a race car. 3" system is heavier than a 2.5" pipe. A dart is a smaller car than my challenger with 3" and it's tight under my E body. I don't care for my 3" X pipe TTI system and my 2.5" H pipe TTI pipes sound way better than the 3" X pipe, way better. I have BB in my 3" car, not a little wimpy 408.
Mines a street car too. What does the bad big block Challenger run? 8.20?
[Re: justinp61]
#1398730
03/09/13 12:18 PM
03/09/13 12:18 PM
Challenger 1
Cincinnati, Ohio
I have no idea what it runs because I have never taken it to the drag strip. Even a 10 second ride is not exciting to me anymore on the track. On the street is totally different story. Now it's about cruising in a reliable muscle car for me. My 440 has eddie heads on it and a 6 pak. It'll smoke my 12" wide mickeys at 35 MPH roll.
I just got a go pro camera for Xmas and wanted to use it today but it is still too salty on the streets. I've been downtown and to work already today on separate trips checking out the streets because it's going to be 55 today and the rest of the snow will melt. It's gonna have to wait. My cars are no slouches but I'm not claiming to have the fastest car.
[Re: JohnRR]
#1398732
03/09/13 04:54 PM
03/09/13 04:54 PM
Posts: 6,653 Near Reading PA USA
pinkduster
Near Reading PA USA
you should have stayed with this post only ...
YEAH, I know! All this talk about pea-shooter sized exhaust is quite entertaining though.
[Re: justinp61]
#1398734
03/11/13 04:47 PM
03/11/13 04:47 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
I bet those crappy flowing Flowmasters cost you far more restriction than the 2.5" pipe does/did
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: Dr-Dave2]
#1398737
03/12/13 10:07 AM
03/12/13 10:07 AM
Posts: 338 Montreal Quebec
STROKIE
Montreal Quebec
The DynoMax tech section has some good information about calculating exhaust diameter based on C.I,D. and horse power seems like muffler selection is also a factor in their calculations http://www.dynomax.com/assets/2012catalog_pdf/2012_Dynomax_techsection.pdf
As per DynoMax tech piping chart about horsepower. It is brake horsepower or rear wheel horsepower. Big difference... My engine is a 451 with 373 RWH and I use 3.00 may be It's too big.
