Bucket seat bracket reinforcements plates
#1396876
03/03/13 07:56 PM
03/03/13 07:56 PM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
Friend is re doing a '67 Cuda. It has a bench seat in it now. He wants to go to buckets. I'm trying to find the person that makes and sells the bucket seat bracket reinvorcements plates for thr floor pan to make this trade possable. A little help, anyone? Some one know who this is, or where I can get/or make them? PM me, or duster@surewest.netThanks
Re: Bucket seat bracket reinforcements plates
[Re: dart1962_440]
#1396879
03/03/13 10:12 PM
03/03/13 10:12 PM
bigblock340power
Elk Grove, Calif.
There a set of B Body ones in the B Body parts for sale section if you think you may be able to get them to work.
I guess we could too. But what are the dementions?
[Re: bigblock340power]
#1396880
03/04/13 01:50 AM
03/04/13 01:50 AM
Posts: 1,069 Washington State
70Duster440
Washington State
I made mine from 2"x3" plate. Don't know what the actual, factory dimensions were.
Here's AMD's image:
[Re: Ramrod39]
#1396884
03/05/13 01:51 AM
03/05/13 01:51 AM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
Help me to understand here. These 4 piece sets go on the inboard seat studs, one plate on top and one on bottom?
If you don't use them when you switch to buckets what happens? Does the floor tear? Really? Am I missing something?
Plates go on top of floor only, inboard holes only, and are tack welded in. Yes the floor will eventually fatigue crack and the bolts/nuts will pull through the floor.
I made mine from some scrap plate.
[Re: nomore65BelvJim]
#1396885
03/05/13 10:52 PM
03/05/13 10:52 PM
Posts: 9,165 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
Thanks. The pics make it clear. Wish I would of thought of this before I put the Dynomax and carpet in.....
Maybe some big washers on the bottom side...?
[Re: demon440]
#1396887
03/06/13 02:02 AM
03/06/13 02:02 AM
nomore65BelvJim
Ok where are the experts ? Or people with original plates. Do they mount on top or bottom ?
Every bucket seat mopar I have owned had them on the top. Its stronger when mounted on the top.
[Re: demon440]
#1396888
03/06/13 02:08 AM
03/06/13 02:08 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
depends... E body are under the floor... B body is above the floor... I don't have a photo of the E body reinforcements but here's the B body..
[Re: Ramrod39]
#1396889
03/06/13 02:09 AM
03/06/13 02:09 AM
nomore65BelvJim
I'd pull the carpet, cut the mat and add them on the top Kevin. A washer on the underside is better than nothing, but not by much.
I have a few extras cut if you want them. Oversized but they fit a stock A body.(the plate pic was of a 72 Demon) You'll have to drill the holes yourself
[Re: 1_WILD_RT]
#1396890
03/06/13 02:13 AM
03/06/13 02:13 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Ok I just walked out & snapped a photo.. E body..
[Re: 1_WILD_RT]
#1396891
03/06/13 02:26 AM
03/06/13 02:26 AM
nomore65BelvJim
Randy is that a formed plate? Is it just spotwelded? Is there anything on the top side? Never noticed that on an E never owned one though...thats probably why Every A, B and F body I've had that was a factory bucket car had them on the top.
#1396892
03/06/13 02:33 AM
03/06/13 02:33 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Yup, welded to the ribs on the bottom of the car, the cupped area goes up & sandwiches with the high area of the floor.. I don't believe there is anything on the inside.. It's been years & I could be wrong but I don't think so.... I need to clean the bottom of the car, hasn't been done in a few years.... I use to stay on that stuff, now I just drive it...
#1396894
03/06/13 02:48 AM
03/06/13 02:48 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I am ashamed.... Not!! I don't honestly know if the cupped area is welded, it's bolted tight by the seat studs so I don't see it mattering much...
