Page 2 of 3 1 2 3
Re: 67 440 GTX Air Cleaner [Re: MoparABE] #1396179
03/06/13 05:42 PM
03/06/13 05:42 PM
Bristol, CT
RalphsRapidTrnst Offline
Bristol, CT
Coolest thing about a 67 4spd GTX & R/T with a 440 mill was Chrysler gave you everything that came with the Hemi but the Hemi. Unsilenced Air Cleaner, Dana, Dual point dist, Clutch fan. ETC. Very cool for the first model year.
A Collection Of All Things Chrysler
www.RalphsRapidTransit.com
Stock Appearing MuscleCar Racing
www.SuperCarRaces.com
Re: 67 440 GTX Air Cleaner [Re: mccannix] #1396180
03/25/13 09:22 PM
03/25/13 09:22 PM
Danville, NH
Mopar_Mike Offline
Mopar_Mike  Offline
Danville, NH
What is the difference in a 67 GTX / R/T air cleaner and one used on a 67 C body 440 ??. The one I have the lid measures about 3 1/2 inches. I have had if about 30 years and was kinda thinking it came off of a C body wagon that I pulled a 440 from.
Dan
Easy way to distinguise for reference, is that you'll find that on a C-body you cannot use the pie pan...center dome area is too tall.
Actually incorrect again... The only C-body dual snorkel air cleaner came on the TNT package, which had a pie tin. The diameter is the same.
As stated above the only difference between the B and C body is the height. C body is higher.
Also, no unsilenced air cleaners on 67 440 GTX's or R/Ts.. Ever.. lol..
RS23L7 4-Speed
Re: 67 440 GTX Air Cleaner [Re: Mopar_Mike] #1396181
03/26/13 01:16 PM
03/26/13 01:16 PM
AZ.
696pack Offline
696pack  Offline
AZ.
Dan
I had a similar discussion regarding air cleaners over at FBBO regarding the original one that came off my 66 Charger and you may want to take a look at the thread there. According to some original owners they were using the unsilenced air cleaner on big blocks earlier than 1967 models. See link below and you have to read into the thread for a ways as it started as a for sale ad.
http://www.forbbodiesonly.com/moparforum/showthread.php?40277-1966-up-Mopar-383-4-air-cleaner
Re: 67 440 GTX Air Cleaner [Re: 696pack] #1396182
03/26/13 01:29 PM
03/26/13 01:29 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Dan
The orignal question was for R/T's and GTX's... NOT big blocks or chargers.....
Re: 67 440 GTX Air Cleaner [Re: floridian] #1396183
03/26/13 09:35 PM
03/26/13 09:35 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Thought this might fit in well here.....
Re: 67 440 GTX Air Cleaner [Re: floridian] #1396184
04/01/13 03:11 AM
04/01/13 03:11 AM
AZ.
696pack Offline
696pack  Offline
AZ.
Dan
The orignal question was for R/T's and GTX's... NOT big blocks or chargers .....
Yeah, well, understand this. The point is that things happened back in the day and they did not stop the production line because they were out of the air cleaner that was USUALLY installed so it would get what would fit. They could care less if it is making you scratch your head 40+ years later.
This is why there are always arguements from original owners about what was right and what is wrong because they never changed anything on their cars, but people think it is wrong because it does not match the norm. If it came from the factory that way then it is "as delivered." That doesn't necessarily mean that is the way the factory "intended" to send it out.
AND, if they were using the small un-silenced air cleaner in 66 what makes you think they didn't pop a few of them on the 67 GTX/R/Ts?
My comments ARE relative to this subject.
Re: 67 440 GTX Air Cleaner [Re: 696pack] #1396185
04/01/13 01:41 PM
04/01/13 01:41 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
I have one of each. The shorter of the two uses a 5 inch carb hole on its base. I have owned one other short type dual snorkel and it too had the 5 inch carb hole in its base. In 67 some c bodies ran holly carbs which had the larger dia. The taller of the two 67 dual snorkels i have uses the smaller 4 1/8 carb hole in its base for AFB which is what the R/T's ran
Re: 67 440 GTX Air Cleaner [Re: 70mopes] #1396186
04/01/13 02:07 PM
04/01/13 02:07 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have owned 4-67 Dart GTS 383 cars with the 17" unsilenced air cleaner and currently have one with the AFB base AND the AVS base. The AVS base came off of a 68 Charger with a 440. I have helped restore one 67 440 GTX 4-speed and the original owner still had the air cleaner, which was the 17" unsilensed. I have also helped restore a couple 67 440 GTX's with automatics and they had the dual snorkel air cleaners, so my guess is that Daryl is right...
JB Rhinehart, Realist
A-Body's RULE!
Re: 67 440 GTX Air Cleaner [Re: Rhinodart] #1396187
04/01/13 02:57 PM
04/01/13 02:57 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
67 GTX's had 2 style Air Cleaners, both were dual snorkel and niether was unsilenced. They were not transmission specific. One was spec'd for CAP (California emissions) and one was not. The only difference being that the CAP version had a small nipple protruding from the drivers side to allow a hose connection to the breather, the 49 state version did not have it. BTW, not all CAP versions were sold on California cars, some other states required CAP as well. If a 67 GTX has an unsilenced base plate (the smaller diameter unit that leaves a gap between the lid outer diameter and the base plate outer diameter) it was either swapped after the plant built it or it was a (very unlikely) production line mistake.
Re: 67 440 GTX Air Cleaner [Re: ScottSmith_Harms] #1396188
04/01/13 07:20 PM
04/01/13 07:20 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
C'mon Scott, what you are saying is that Chrysler used 100% the right parts no matter what, you know better...
A-Body's RULE!
Re: 67 440 GTX Air Cleaner [Re: ScottSmith_Harms] #1396189
04/01/13 07:57 PM
04/01/13 07:57 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Missed the my last part of my comment did ya?
Re: 67 440 GTX Air Cleaner [Re: Rhinodart] #1396190
04/02/13 08:57 PM
04/02/13 08:57 PM
Bristol, CT
Bristol, CT
The great thing about owning the car and not the t-shirt is you get to do what ever you want with it. If you believe a 440 4spd did not come with an unsilenced air cleaner in 1967 on the GTX then you have the choice to do as you wish.
Re: 67 440 GTX Air Cleaner [Re: RalphsRapidTrnst] #1396191
04/02/13 10:12 PM
04/02/13 10:12 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
I know there are mistakes in the parts books. Is this one of them?
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 67 440 GTX Air Cleaner [Re: 69CoronetRT] #1396192
04/02/13 10:24 PM
04/02/13 10:24 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
I also know there are mistakes in the data books. Is this one of them?
Seeking:
Re: 67 440 GTX Air Cleaner [Re: 69CoronetRT] #1396193
04/03/13 12:01 AM
04/03/13 12:01 AM
Bristol, CT
Bristol, CT
There is much more out there that validates 4Spd cars came unsilenced. I didn't believe it 23 years ago till I reserched the differences in the Auto and 4Spd. I am sure some came from the factory with a dual snorkel but that was not the way they were to be delivered.
Re: 67 440 GTX Air Cleaner [Re: RalphsRapidTrnst] #1396194
04/03/13 02:52 PM
04/03/13 02:52 PM
PNW
Beebuzzn Offline
Beebuzzn  Offline
PNW
I'll just add my and that is I had 2 1967 GTX's bought from original owners in 1975 & 1976 both 4spd. Both had dual snorkel air cleaners.
Re: 67 440 GTX Air Cleaner [Re: Beebuzzn] #1396195
04/03/13 03:14 PM
04/03/13 03:14 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
And another . I've owned/parted quite a few of these back in the day. All had dual snorkles and never have found one yet with a windage tray as the above publication announced for 4 speed cars. 67's are a breed apart.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 67 440 GTX Air Cleaner [Re: sixpackbee] #1396196
04/03/13 03:45 PM
04/03/13 03:45 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
While I would normally agree with Scott, I'm going to go ahead and agree with Ralph on this one. The first time someone told me they had the "4 speed air cleaner" on their '67 GTX I thought they were mistaken. However after hearing from several others that 4 speed cars came with unsilenced air cleaners with no snorkels I began to wonder.
My buddy Phil bought his '67 GTX brand new. PP1 red, black stripes, convertible, 4 speed, and it came with an un-silenced air cleaner. Could he be lying to me? Of course, but he has no reason to. I'll see if he has a picture of the engine when it was new lying around anywhere.
Not an early car either, he ordered it around February or March of '67. Pretty rare car too with the 4 speed being a vert.
Early on it was advertised that 4 speed cars were supposed to come with a special cam, same lift but 276/292 duration (sound familiar? If not read the early A12 adds) and was supposed to be rated at 390 horsepower. I didn't believe that either but Phil showed me the ad he had that was clearly advertising so.
Re: 67 440 GTX Air Cleaner [Re: GTX MATT] #1396197
04/03/13 10:13 PM
04/03/13 10:13 PM
Bristol, CT
Bristol, CT
My GTX's original drive train is in my basement. From air cleaner to windage trayed oil pan. When I pulled the original bearings out of it they were date coded 1967 I still have a couple of them.
Also the Unsilenced Air Cleaner was similar to my old Barracuda Formula S 383 4Spd but was different. They were not the same air cleaners.
Re: 67 440 GTX Air Cleaner [Re: RalphsRapidTrnst] #1396198
04/03/13 10:26 PM
04/03/13 10:26 PM
Bristol, CT
Bristol, CT
Page 2 of 3 1 2 3
