Big block intake pan gasket
#139462
10/20/08 11:58 PM
10/20/08 11:58 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
Has anybody ever had the valley pan on a big block "balloon" if the fiberglassish material pad isn't installed- plugged PCV or? I've seen quite a few back in the day, I just wonder if it was excess blowby, a plugged PCV, or? Was it common, or did I just see a few more than most...?
CrAzYMoPaRGuY
Re: Big block intake pan gasket
[Re: CrAzYMoPaRGuY]
#139463
10/21/08 12:56 AM
10/21/08 12:56 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
I had that happen when I had a clogged breather...
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: CrAzYMoPaRGuY]
#139464
10/21/08 06:13 AM
10/21/08 06:13 AM
Posts: 1,526 North Carolina
cjskotni
North Carolina
It has nothing to do with the pad under the intake. The valley van will ballon if you don't have some type of breather/PCV valve.
I had this happen the first day I broke my engine in. In my excitement, I forgot to install a PCV, and with all the blowby of a newly-rebuilt motor, it popped that valley pan like a piece of popcorn!
When, it happened, I'd thought I thrown a pushrod or something ...sounded like a gunshot!
[Re: CrAzYMoPaRGuY]
#139465
10/21/08 09:09 AM
10/21/08 09:09 AM
Posts: 30,537 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
To BALLOON up a valley pan ..... is way WAY more than just a plugged-up PCV ..... there are MAJOR piston or piston ring probs going on. The last one I saw was a MH 440 that a guy had gotten out of a JY. The VP was almost "molded" to the bottom of the intake. There was a hole in one of the pistons the size of a quarter !
A plugged-up PCV ? ... you CrAzY CaNaDiAnS ! ![](/ubbthreads/images/graemlins/haha.gif)
[Re: R/T1968R/T]
#139468
10/21/08 04:14 PM
10/21/08 04:14 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
I dont know we run no PCVs on 3 motors 1 SB and 2 BBs.My 12.5 440 has 2 breathers and is new under 5K miles but is street and strip.The kids almost 50 year old 413 ses tons of satreet miles and has never been apart.2 breathers on it too.He runs the snot out of it and has for 9 years.If you balloon a valley pan you need a rebuild period.If its a new motor and does it you have problems.Rocky
Chrysler Firepower
[Re: 1970440RT]
#139470
10/21/08 05:56 PM
10/21/08 05:56 PM
dOc !
Florida STAYcation
My motor did it when new. I forgot the pcv and breather when breaking it in. Not only ballooned valley, also leaking gaskets. I replaced the pan and added a breather. 6 years later the same motor is still running strong.
Well - how you define "running strong" is way diff than mine. If you have enough pressure to "inflate" the VP gasket ..... your motor is a leaker- big-time. And piston-ring-seal is probably the most important factor of a good running internal combustion engine.
To the guy who had the stuck-floats and the oil was diluted with gas .... you probably hurt the rings badly. It is a well-known-fact that you can damage the rings with an excessively rich A/F mixture. What happens is that rich-mixture "washes" the oil off the rings and cyl walls. NOT good.
[Re: CrAzYMoPaRGuY]
#139473
10/21/08 10:36 PM
10/21/08 10:36 PM
dOc !
Florida STAYcation
I think you would be surprised how a good running engine WITHOUT a breather or PCV valve can pop a valley pan gasket. Regular blowby running at highway speeds, I've seen it.
I'm not sure your motorhome could make it up to such speeds, being fiberglass and all.
Mind you- MY motorhome was a STEEL shell, and could SUSTAIN "highway speeds"....
You CrAzY cAnAdIaNs ! ... ![](/ubbthreads/images/graemlins/boogie.gif)
BLOWby equals lost power ! ....and fuel econ.
And as far as fiberglass vs steel ? ....with your AERO equal to a barn-door ...and mine same-same to the Space-Shuttle ...we will see who will do what .... at a 100 mph "roll" !
..... ..... ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: stumpy]
#139479
10/21/08 11:02 PM
10/21/08 11:02 PM
dOc !
Florida STAYcation
Please read the above posts and you will find the other opinions on different causes.
I was asking YOU your opinion.
[Re: NITROUSN]
#139480
10/21/08 11:14 PM
10/21/08 11:14 PM
dOc !
Florida STAYcation
The motor needs to be vented or where else does the pressure go? Seems like the dipstick should lift up. I wonder how much pressure it takes to belly a pan? Maybe some pans are thinner and belly easier.
Good points ..... and all engines have some degree of less than 100% ring-seal.
How much pressure would it take? ...I would think it would be EVERY BIT of the compression and ignition process of one cylinder !!
