Re: a 500/a518 or 545re [Re: cudadan] #1393544
02/27/13 11:01 PM
02/27/13 11:01 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
It came out of a 91 350 van. You just hook the pwr wire up to keyed on.
Can u use a 727 converter in the 518?
Yes if its the non-lockup type. If its the lock-up type, you need to swap the front pump out and the input shaft. Then your good.
Re: a 500/a518 or 545re [Re: Dragula] #1393545
02/27/13 11:17 PM
02/27/13 11:17 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
cool, but how do i know if its a lock up or not?,,
Re: a 500/a518 or 545re [Re: cudadan] #1393546
02/28/13 01:20 AM
02/28/13 01:20 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
lockup/od has a 3 pin connector-- 2 pin is od only---this pin connector is to the rear of the neutral switch....bob
Re: a 500/a518 or 545re [Re: savoy64] #1393547
02/28/13 09:48 AM
02/28/13 09:48 AM
GA
roadrunninMark Offline
GA
The lock up will give you a little better mpg and is not that much harder to wire in. PATC has kits and other items (http://www.transmissioncenter.net/) for the swap. The newer trans 93-95 are definitely lock up and have all the up to date fixes in them (up to that year at least) before they went to the electronic version.
Re: a 500/a518 or 545re [Re: roadrunninMark] #1393548
02/28/13 02:18 PM
02/28/13 02:18 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
used this type of setup to run the 42RH (A500) in my 5th ave...worked good....
but if you're planning on installing a 5.7 and keeping the OEM EFI, from a transmission control/drivability standpoint, you'd probably be miles ahead sticking with the 545RE that came behind the 5.7....
2017 Grand Cherokee Overland
Re: a 500/a518 or 545re [Re: patrick] #1393549
02/28/13 02:51 PM
02/28/13 02:51 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
im gonna have the compute . Flashed and can eliminate the trans from it. So it wont know what trans is in there.. The 545 seems like its gonna take alot of work to the trans tunnel
Re: a 500/a518 or 545re [Re: cudadan] #1393550
03/01/13 02:17 AM
03/01/13 02:17 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
In the link posted above, to the FABO thread....that pic of the 545RFE is my transmission that's going in my Duster with a 5.7 Hemi. I had to take the sawzall to the floorpan and torsion bar crossmember to make it fit. I'm making a new transmission mount that will attach to my subframe connectors. It's a lot of floorpan surgery, but to me, it will be worth it in the end. It's not a swap that's for everybody, but it didn't bother me a bit to lay the to an old 6 cylinder 70 Duster. Good luck with your swap.
Re: a 500/a518 or 545re [Re: JDMopar] #1393551
03/01/13 11:34 AM
03/01/13 11:34 AM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
nice ill have to check it out. I sure the e body has much more room but still wouldnt wanna cut to much of the floor. I still have a ways to go for everything. So ill keep reading up and askn questions. Hahah. Thx everyone for the input it really helps
Re: a 500/a518 or 545re [Re: cudadan] #1393552
03/01/13 12:07 PM
03/01/13 12:07 PM
JDMopar Offline
JDMopar  Offline
I have a 74 Cuda 360 that is triple black, like the one in your pic. I wouldn't ever consider cutting the floor and crossmember of that car like I have the Duster. I'm going to use a 518 in my Cuda, because there will be no hacking if I go that route.
Re: a 500/a518 or 545re [Re: cudadan] #1393553
03/01/13 12:40 PM
03/01/13 12:40 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
yeah, you can get your hemi's computer flashed to a manual tranny flash to eliminate the transmission out of the equation, I think you'll still need a vehicle speed sensor to get everything on the engine to work right, but don't quote me on that....
I have a feeling the 518's kickdown/throttle cable or linkage will be a real PITA to try fabricate and get working properly, and you are somewhat limited on control options/flexibility using the vacuum and pressure switches like I did. drivability won't be as nice running a jerry rigged, non-electronic tranny vs. the 545 which is integrated into the control of the engine...up to you if it's worth doing to save cutting up your floorpan/crossmember....
another option that I bet would work well with the 5.7 without floorpan mods would be an A833OD....the 5.7 in my '11 charger has an extremely wide powerband, and the A833OD in my duster (behind a slant6) has somewhat wide gear spacing, but I think would work quite well with a stock/near stock 5.7's HP and torque curve.
Re: a 500/a518 or 545re [Re: patrick] #1393554
03/01/13 08:29 PM
03/01/13 08:29 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
They do make kits for the kickdown.. Theres a few guys running the 518 with good luck. Best part is its one less thing tk run on the computer hahab
