Got a nasty surprise when we took the front seat backs apart for my 65 Fury I 2 door cop car. The upholstery was pretty decent, but the springs were toast! Looks like major condensation got to them, which is interesting because all of the other seats had no issues and looked great. With the the erosion on the springs, I hate to reuse them, but if I can't find replacements I may have to.
Had a spare set of of a 67 Coronet 2 door sedan seat frames, and I was able to use some of the springs for the Fury seats, but the rest did not fit. There are 5 different springs in one seat back. Seems the Coronet seats are normal duty and the Fury are heavy duty.
I need the following:
(qnty 12) 7 coil 5 1/2 inch tall 4 inch large coil doiameter 1 7/8 on small end 0.119" (+/- 0.002") diameter
(qnty 2) 7 coil 5 1/2 inch tall 4 inch large coil diameter 1 7/8 on small end 0.132" (+/- 0.002") diameter
(qnty 4) 6 coil 4 1/2 inch tall 4 inch large coil diameter 1 7/8 on small end 0.104" (+/- 0.002") diameter
(qnty 4) 6 coil 4 1/2 inch tall 4 inch large coil diameter 1 7/8 on small end 0.119" (+/- 0.002") diameter
Any ideas?
![](http://home.fuse.net/markz440/spring.jpg)
