Page 2 of 4 1 2 3 4
Re: 4 speed bell housing alignment questions [Re: moparmedic] #1392801
02/25/13 11:52 AM
02/25/13 11:52 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I needed several other transmission related items so I just ordered a set of offset pins from Brewers.
Hopefully get this thing all lined up and back in the car. It has not been on the road since the early '80s!
Looks like the RobbMC dowels ,I'd put loctite on the set screws for the final assembly.
Re: 4 speed bell housing alignment questions [Re: JohnRR] #1392802
02/25/13 12:10 PM
02/25/13 12:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I just noticed that Mancini's dowels are all Lakewood's. They used to carry the MP dowels that were the correct .496 o.d.. Guess there's no choice but to shell out crazy money for the McRobb's now.
Re: 4 speed bell housing alignment questions [Re: Stanton] #1392803
02/25/13 02:10 PM
02/25/13 02:10 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I would check the parallel of the mating surface of the bellhousing first, I had mine dead nuts at .002 tir and found my bell was not parallel so I had to put in a shim between the block and bell. When I did that, it totally screwed my number and I had to start over again. I tried the lakewoods and wound up drilling and slide hammering them out. I finally just ordered the Robbmc ones and within a short period of time after I got them it was within book spec.
Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 4 speed bell housing alignment questions [Re: astjp2] #1392804
02/25/13 02:30 PM
02/25/13 02:30 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I would check the parallel of the mating surface of the bellhousing first, I had mine dead nuts at .002 tir and found my bell was not parallel so I had to put in a shim between the block and bell. When I did that, it totally screwed my number and I had to start over again. ....Tim
Excellent point.
Re: 4 speed bell housing alignment questions [Re: astjp2] #1392805
02/25/13 02:42 PM
02/25/13 02:42 PM
JohnRR Offline
JohnRR  Offline
Tim
I would have run it up to the machine shop and had them surface it .
Also that brings up a good point , the picture the OP put up shows his dial indicator is not inside the bore of the bellhousing ... at least it looks that way ??? but the picture is small ... if that is the case he isn't really getting an accurate reading...
but probably close enough for a caveman ...
Re: 4 speed bell housing alignment questions [Re: Stanton] #1392806
02/25/13 05:39 PM
02/25/13 05:39 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Because you will be measuring closer to the center of the circle,not .008 off center.It will still be centered l to r the same but the number will be a few thou different
Re: 4 speed bell housing alignment questions [Re: 67_Satellite] #1392807
02/25/13 06:20 PM
02/25/13 06:20 PM
PA
70HemiGTX Online content
70HemiGTX  Online Content
PA
I used the Lakewood's to get my new one lined up. I put them in a drill press and used a straight flat piece of metal to hold some very fine sandpaper against it and sanded it down very lightly. Using a caliper to check to see that I didn't remove too much material. Got it down to the size of the factory dowels I took out and with the holes COMPLETELY CLEANED OUT, I greased them a little and slid them in. No problem turning them with a screwdriver.
I didn't have time to wait for others to be shipped here so I worked with what I had. I'm sure there are better out there, but I didn't work too hard to make these do the job.
Re: 4 speed bell housing alignment questions [Re: 67_Satellite] #1392808
02/25/13 07:54 PM
02/25/13 07:54 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Hmmm ... you're measuring at the widest point and then shifting it up .007". Do you really think the number will be "a few thou" different? I'll bet you the change doesn't show up on the dial indicator!
As for John having it surfaced ... another instance of him needlessly spending someone else's money. Yes, by all means check the runout, but if it is out of whack its easily resolved with shims cut from feeler gauges or pop cans instead of dishing out $100 to have it surfaced.
Re: 4 speed bell housing alignment questions [Re: Stanton] #1392809
02/25/13 08:01 PM
02/25/13 08:01 PM
JohnRR Offline
JohnRR  Offline
I never suggested anyone spend their money needlessly, I just said how I would spend MY. I doubt it would cost $100 to surface the bellhousing, even in the part of the country with high per hr labor charges ...
Re: 4 speed bell housing alignment questions [Re: JohnRR] #1392810
02/25/13 08:29 PM
02/25/13 08:29 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Pop can, beer can, piece of steel roofing , what does it matter if it works. My question as I have never heard of machining the bell housing to be parallel with the block, which surface gets re-surfaced ? the block side or the transmission side. I think a person can micro a project to death trying to get something perfect when there is tolerance that is acceptable .
Re: 4 speed bell housing alignment questions [Re: rowin4] #1392811
02/25/13 09:13 PM
02/25/13 09:13 PM
JohnRR Offline
JohnRR  Offline
EDIT .. I've had a chance to think about this , it's completely possible that the block could be the cause of the bell being out of parallel and shimming , as much as a half ass way of doing it in my mind is probably the best way to go .
Re: 4 speed bell housing alignment questions [Re: JohnRR] #1392812
02/25/13 11:45 PM
02/25/13 11:45 PM
moparmedic Offline OP
I could not get my set up adjusted so that the indicator was fully centered in the bore but it is inside the bore. The picture was taken looking slightly down and from the left. The part that contacts the bore is as close to dead center as I could get it. Does the set up not look right?
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: 4 speed bell housing alignment questions [Re: moparmedic] #1392813
02/26/13 12:07 AM
02/26/13 12:07 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I could not get my set up adjusted so that the indicator was fully inside the bore but the part that contacts the bore is as close to dead center as I could get it. Does the set up not look right?
Your setup is fine. Maybe one in 50 people will have a dial indicator and stand that will actually fit inside that hole! So the indicator is at a slight angle ... big deal, as long as it stays that way throughout the entire travel around the hole it doesn't matter.
And John, the proper surface to machine would be the trans mounting face, not the block face. The main reason being that less material would have to come off but also there would be a good chance of cracking an iron housing if it is taken off the block face.
Re: 4 speed bell housing alignment questions [Re: Stanton] #1392814
02/26/13 12:15 AM
02/26/13 12:15 AM
Ok, good,that is kind of what I thought, thanks.
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: 4 speed bell housing alignment questions [Re: Stanton] #1392815
02/26/13 12:20 AM
02/26/13 12:20 AM
rowin4 Offline
rowin4  Offline
Yes his set up is correct. A standard size indicator will not fit inside the hole straight up. The surfacing of the bell housing would be easier to do the transmission face only if the block face was flat.
Re: 4 speed bell housing alignment questions [Re: moparmedic] #1392816
02/26/13 12:22 AM
02/26/13 12:22 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
How can you be plus on both the left and right? Did you zero the dial indicator? I checked mine every 45* and could watch it go from - to + back to - or 0 depending on the position. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 4 speed bell housing alignment questions [Re: astjp2] #1392817
02/26/13 01:19 AM
02/26/13 01:19 AM
It depends on Ma Mopar to make them that way I've seen them like that, it depends on where you start your readings at to what readings comes off of the indicator
Re: 4 speed bell housing alignment questions [Re: Cab_Burge] #1392818
02/26/13 01:59 AM
02/26/13 01:59 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
To be - on both sides just means that he zeroed it at the top and that the bell is pretty much centered side to side. When he puts in the proper dowels and does it again it should only be off by .001 side to side and .001 up and down.
Re: 4 speed bell housing alignment questions [Re: Cab_Burge] #1392819
02/26/13 02:00 AM
02/26/13 02:00 AM
The results I got were surprisingly similar to the you tube video link that was attached earlier in this thread. Yes, I zeroed the dial indicator at 12 o-clock and called that zero then took a reading at 3, 6, and 9 o-clock. The you tube video showed taking readings more frequently.
http://www.youtube.com/watch?v=tS4H4oImDhE
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: 4 speed bell housing alignment questions [Re: moparmedic] #1392820
02/26/13 02:11 AM
02/26/13 02:11 AM
rowin4 Offline
rowin4  Offline
I have always set the indicator to zero at the lowest reading, by doing that you don't have the + and - readings confusing you. I do the 45 degree, use a marker on the bell housing face, take a 360 reading , do a adjustment , do it again and again and again. wish I had a friend to do the wrench cranking
Page 2 of 4 1 2 3 4
