Re: '70 Challenger (Hood / Trunk Latch, Lever, Striker)
[Re: JulesdaWiperman]
#1392174
02/24/13 04:17 AM
02/24/13 04:17 AM
Posts: 1,557 Sweden
71redcuda
Sweden
I will say yes. You will notice that there is no date code stamped on the left hand side bolt area. See sample picture below. Jules
Jules,VERY intresting,thanks for showing the samples..
[Re: Mastershake340]
#1392175
02/24/13 06:50 PM
02/24/13 06:50 PM
Posts: 28,730 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I guess I should have said "closer to original appearance than 90+% of the Mopars you see at shows and cruises". Again, if you are restoring a car to national show standards, than you have little choice but to either beat the bushes for NOS parts or feel fortunate that there are a few artisans like Jules who can restore them to perfection for you. But for a car being built for local shows and cruises, and you don't have 6 figures to invest in your ride, you are fortunate that companies like Eastwood sell an inexpensive product that looks close enough to original that your components look better than the 65-75% of the other Mopars out there that have had these components either painted body color or spray bombed silver etc. There are guys I see around here locally at cruises who belittle us Mopar guys (some of whom are Mopar guys even)constantly about how anal we get about things on our cars. Seriously, if they heard about this discussion about whether a product is "brown enough" to satisfy the 30-50 people in North America who have the expertise about what finish is perfect for a hood catch, I'd never hear the end of it and have to stay home and never take my cars out! Chicago area guys, please, I beg you, don't share this thread with the area cruise and show crowd, I don't want to spend this summer hiding in my garage from their laughter!
I am with you on this. If i had a 60K plus car I would get the best. In my case I did a derusting in a tank. Glass beaded mine for both the Dart Sport {hey it is a lowly 1973 A body} And the 70 Challenger Vert. Had a friend do a tripple plate that came out looking close to silver cad. As this pic will show I was lucky on having a Mint Jack for the 73 as things can add up fast! Was also lucky getting mint jack from friend {Mark Nixon} for the 70 Challneger
And here is another part but put a very light / little polish before
He screwed me up though when one of may parts ended up getting polished as it ended up with someone else's parts. It is well hidden so left it as is shiny spring
As far as 100% right Jules is the man
[Re: filmsurgeon]
#1392178
02/25/13 11:17 PM
02/25/13 11:17 PM
Posts: 7,198 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
What can be done to prevent the safety hook/lever from scratching the paint where it's received in the top plate (see attached photo)? Quote:
After you've owned a few mopars you learn the ancient art of holding the safety hook in the unlatched position as you close the hood...This keeps the hook from scratching the paint...Simple but effective...
[Re: screamindriver]
#1392180
02/26/13 04:36 AM
02/26/13 04:36 AM
Posts: 401 California, USA
filmsurgeon
California, USA
Thanks for the advice. I guess I'll just get it repainted, and do as you suggest.
[Re: Mr D21]
#1392181
02/26/13 05:08 AM
02/26/13 05:08 AM
filmsurgeon
California, USA
You should buy one of these e-body restoration manuals - very well worth it !!!!
http://www.mmcdetroit.com/Market_Place/
Thank you. It's been so long, I forgot about David and MMC Detroit Services. I'll definitely consider getting the manuals. BTW - It was David that did the appraisal on my Challenger back in mid 2006, shortly before I received it from the seller. Thought I'd share his (3) page appraisal just for kicks.
[Re: filmsurgeon]
#1392184
01/30/14 04:06 AM
01/30/14 04:06 AM
Posts: 27,598 So Cal
autoxcuda
So Cal
I'm finally getting around to dealing with my hood/trunk latches, and the hood safety hook. Sadly, I won't be able to get them done by Jules. Has anyone had theirs powder-coated? If so, how did that turn out? I'd really rather NOT just spray paint them, as that would result in not very durable results, but it would be the cheapest alternative. I seriously feel that re-plating them assembled is out of the question. Thanks for the advice.
You can replate then assembled. Won't look at perfect as the ones jules did, but will look a lot better and last longer than painting.
There are plating places around So Cal that will do them. Just haven't got it done in years. But others have.
[Re: autoxcuda]
#1392186
01/30/14 02:57 PM
01/30/14 02:57 PM
filmsurgeon
California, USA
I considered getting them plated assembled, but after seeing the photo that Jules posted earlier in this thread of one that was done that way, I pretty much decided against it. Also, I understand that the plating process is not good for springs. I could remove the hood latch springs, but not the trunk latch or safety hook springs w/o disassembly. Just the other day, I took a small box of parts over to Burbank Plating in Pacoima for plating. I brought the latches and safety hook with me to show to them. I was told that if I got them plated, I would need to bake them in my oven in order to re-harden the springs.
[Re: 1972CudaV21]
#1392188
01/31/14 02:48 PM
01/31/14 02:48 PM
filmsurgeon
California, USA
I need to do something before putting the latches and safety hook back on the car because they are bare metal right now. I really don't want to get them plated because of how it might negatively affect the springs that I cannot remove without disassembly. So, it's either powder-coating, or spray paint. I have a few other parts that I will be getting powder-coated, so I could get the latches and safety hook done at the same time. My local powder-coating shop has a minimum charge of $85.00. Spray painting would be my least desirable option, as the paint will surely chip and scratch off in the areas where there will be metal-to-metal contact. So, has anyone had their latches and/or safety hook powder-coated? Something I'm concerned about: Will the internal moving parts still move freely after powder-coating, or will they bind and/or freeze up? Thanks.
[Re: filmsurgeon]
#1392189
01/31/14 03:21 PM
01/31/14 03:21 PM
Posts: 2,418 White Plains, NY
VCODE
White Plains, NY
Try using RPM, It works great.If you can't plate them. Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: VCODE]
#1392190
01/31/14 04:30 PM
01/31/14 04:30 PM
filmsurgeon
California, USA
What is RPM?
