Shooting for .040ish Quench
#1392105
02/22/13 05:03 PM
02/22/13 05:03 PM
Posts: 3,396 Pa
Hot 340
Pa
When measuring deck height, how do you accomodate for piston rock? The pistons are KB 107's (flattops) and sit below the deck around .020 while measuring above the pins. (*Ill get a better reading when I bring my depth mics home from work*) But the pistons are alot closer to the deck on the lifter valley side and/or outer block edge as the piston can rock in the bore. Trying to decide on a head gasket with closed chamber heads..
Re: Shooting for .040ish Quench
[Re: Stanton]
#1392109
02/23/13 12:43 AM
02/23/13 12:43 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
FWIW I don't want to argue about "my" quench. It is what it is and I ain't changing it now. If someone doesn't particularly like my tight quench, keep it to yourself. Let's stay focused on the OP's issue.
But it would appear that you are arguing about it though ????
I see nothing wrong with it being that tight ...
[Re: b1dartsport]
#1392111
02/23/13 11:36 AM
02/23/13 11:36 AM
Posts: 3,396 Pa
Hot 340
Pa
good info guys...very helpful.. It looks like the piston sits .012 beneath the deck above the pins just using feeler guages (not .020 like my og post--brainfart ).. and looking at that speedtalk post it looks like an "average" reading from the rocking will be real close to an above the pins measurement. Ill get better readings with good tools on Monday.. So, if I have .012 reading in the hole...and run a MP gasket which has a compressed thickness of .024 to .028, that will give me between .036 and .039. Or run the felpros (.039 compressed) and get a .051. I seriously doubt this will be a pump gas engine with a 55cc head, but which gasket will make it more pump freindly? Ive heard the larger the piston to head clearance is the MORE chance of detonation is, which seems backward to me.
[Re: Stanton]
#1392112
02/23/13 12:37 PM
02/23/13 12:37 PM
Posts: 20,665 in a cattle trailer down by th...
Guitar Jones
The quench number is usually a static number - in your case .040 - which allows for piston rock. In other words, If you rock the piston and take the highest point and add .040 to it, you will have too little quench. If your goal is .040 and your slugs are .020 in the hole, you want a head gasket as close to .020 as you can get.
i.e. my slugs are .016 above the deck. I use a .051 gasket to yield .035 quench. Piston rock is not considered in the equation, its expected that the .035 will accommodate the rock.
I have run as tight as .027 with a hyper piston.
[Re: Hot 340]
#1392115
02/23/13 05:09 PM
02/23/13 05:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Your shooting for .035 - .045 on it... so get it close and call it good.... most are putting WAY TO MUCH into it... take a reading over the pin centerline and call it good
[Re: MR_P_BODY]
#1392116
02/23/13 11:05 PM
02/23/13 11:05 PM
Posts: 3,396 Pa
Hot 340
Pa
Gotcha. After a few good measurements Ill probably run the MP .028 gasket.
