Re: Qiuck release fastners..................(zues)
[Re: Thumperdart]
#1391536
02/22/13 03:35 PM
02/22/13 03:35 PM
dartman366
Mt. Vernon, Ohio
Thumper I don't know you personally but I know one way or another you WILL make it work. You are not the type of guy that is easily defeated. Most guys would have dropped the car off at someones shop with the hood still in a cardboard box and tell them to install it and come back in a few days to pick up THEIR car. I know for a fact it feels a lot better at least for me knowing I did it, not someone else. Keep up the great work and keep doin what your doin.
Thankxxxx.............You`re right and I will get this thing to work soon enuff and may just get some different fastners and go a few more rounds w/this thing................
what size dzus fasteners did you use? there are at least 2 different sizes,,#5 and #6 I believe,, #5 being the lighter ones and usually use the 1" spring and mount,, the #6 uses the larger body with heavier 1.5 (i think) spring and mount
[Re: b1dartsport]
#1391539
02/22/13 06:48 PM
02/22/13 06:48 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I have been using the MOROSO Dzus fasterners for years. I do have the #6 long fastener. I bought the medium height spring and an adjusting tool.
Make the hood fit with perfect gaps etc. etc. Then figure where the spring mount will fit along the fender. Lay the hood back in place and masking tape a line down each side of the hood. Measure off the fender edge and mark the masking tape. Then you can drill the hood for the fastener. I never broke the fastener but, have bent the spring. WD40 is a good freind of DZUS.
I'll bet you need at least 10 dzus fasteners maybe more. My hood has a Three down each side along the fender. One on each side the cowl. Two on the front corners of the cowl. That aint enough. My hood has small cracks where the cowl begins. And the cowl hood handles wind a lot better than the forward facing scoop hoods.
