Re: Milodon Alum pump & cover
[Re: Bishop]
#1391479
02/24/13 10:59 AM
02/24/13 10:59 AM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
I'm using that pump with the stock cover and a 1/2" internal pick-up. It's sweet, takes less power to drive at a given rpm than a stock pump and with the stock cover, and fits just like the stock HV pump body.
The lobes on the gearator are much more pointed than the factory lobes. Be sure to port match the pump to the block etc and do the rest of the recommended internal oiling system mods.
It's a nice upgrade to your oiling system.
[Re: jbc426]
#1391480
02/24/13 11:15 AM
02/24/13 11:15 AM
Posts: 2,938 A shed in England
Tig
A shed in England
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: astjp2]
#1391481
02/24/13 12:46 PM
02/24/13 12:46 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
Anyone ever use one of these Milodon Alum oil pumps or is there a better one on the Market? This will be going on a all Alum. 572 street HEMI 10.5:1 pump gas motor wit a HP performance Alum. block #23
Thanks Brian
http://chucker54.stores.yahoo.net/newbimioilpu.html
We've got one on the car right now, Couldn't tighten the mounting bolts to the stock iron torque specs without it binding. I was told 15ft lbs was OK and it seems to work on the drill. Never found out what Milodon recommended ![](/ubbthreads/images/graemlins/shruggy.gif) Haven't got round to running the motor yet either.
What mounts are you using? Which block? Which K-member? The OP was asking about a Hemi block and K-member with the new cover and others post pics of their 440 setup or of some other cover. Tim
Years ago I cracked the housing of a cast iron version of that oil pump. It was at the narrowest wall. That motor would have been toast if I didn't constantly check and recheck things. I torqued it to stock specs and it bound up to the point I could not spin the motor. That lower torque spec sounds very familiar.
I have a hand written tag on a new cast iron one that is still on the shelf that says 25 ft lbs.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: jbc426]
#1391482
02/26/13 12:47 AM
02/26/13 12:47 AM
Posts: 1,491 Lethbridge, AB, Canada
dangina
I have to port match the block? thanks I did not know this and will do so before I goto install it. As for the rest of the internal oil system mods what can I do to improve? building a 470ci stroker (400 block) running the milodon oil pump and milodon road race pan with windage tray and 3/8" pickup
[Re: dangina]
#1391486
02/26/13 09:34 PM
02/26/13 09:34 PM
jbc426
West Coast, USA
There's a very wise bunch of experienced engine builders on this site that can point you in the right direction regarding preparing and improving the blocks oil passages etc.
Just be careful, take your time and follow the generally accepted practices of the guys who've been there done that.
One of the most critical things you can do is clean everything, and I mean everything several times.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
