Re: Milodon Alum pump & cover [Re: Tig] #1391477
02/24/13 04:14 AM
02/24/13 04:14 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
can you use the stock oil pump drive if your using the stock cast cover or do you have to buy the longer one anyways running this pump?
Re: Milodon Alum pump & cover [Re: dangina] #1391478
02/24/13 10:46 AM
02/24/13 10:46 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
the pump im running takes a longer shaft. any of these pump you'd want to have a hardened tipped shaft.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Milodon Alum pump & cover [Re: Bishop] #1391479
02/24/13 10:59 AM
02/24/13 10:59 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I'm using that pump with the stock cover and a 1/2" internal pick-up. It's sweet, takes less power to drive at a given rpm than a stock pump and with the stock cover, and fits just like the stock HV pump body.
The lobes on the gearator are much more pointed than the factory lobes. Be sure to port match the pump to the block etc and do the rest of the recommended internal oiling system mods.
It's a nice upgrade to your oiling system.
Re: Milodon Alum pump & cover [Re: jbc426] #1391480
02/24/13 11:15 AM
02/24/13 11:15 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Did it torque up OK?
Re: Milodon Alum pump & cover [Re: astjp2] #1391481
02/24/13 12:46 PM
02/24/13 12:46 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
Anyone ever use one of these Milodon Alum oil pumps or is there a better one on the Market? This will be going on a all Alum. 572 street HEMI 10.5:1 pump gas motor wit a HP performance Alum. block #23
Thanks Brian
http://chucker54.stores.yahoo.net/newbimioilpu.html
We've got one on the car right now, Couldn't tighten the mounting bolts to the stock iron torque specs without it binding.
I was told 15ft lbs was OK and it seems to work on the drill.
Never found out what Milodon recommended
Haven't got round to running the motor yet either.
What mounts are you using? Which block? Which K-member? The OP was asking about a Hemi block and K-member with the new cover and others post pics of their 440 setup or of some other cover. Tim
Years ago I cracked the housing of a cast iron version of that oil pump. It was at the narrowest wall. That motor would have been toast if I didn't constantly check and recheck things. I torqued it to stock specs and it bound up to the point I could not spin the motor. That lower torque spec sounds very familiar.
I have a hand written tag on a new cast iron one that is still on the shelf that says 25 ft lbs.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Milodon Alum pump & cover [Re: jbc426] #1391482
02/26/13 12:47 AM
02/26/13 12:47 AM
dangina Offline
dangina  Offline
I have to port match the block? thanks I did not know this and will do so before I goto install it. As for the rest of the internal oil system mods what can I do to improve? building a 470ci stroker (400 block) running the milodon oil pump and milodon road race pan with windage tray and 3/8" pickup
Re: Milodon Alum pump & cover [Re: dangina] #1391483
02/26/13 02:08 AM
02/26/13 02:08 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Don't grind the block, grind the pump to match the block. You don't want to have to mess with the block again if you ever need to change pumps.
Re: Milodon Alum pump & cover [Re: Bishop] #1391484
02/26/13 08:41 AM
02/26/13 08:41 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Thanks Brian
I gots me one...Just the cover though. I used a Melling pump. Seals up good.
Re: Milodon Alum pump & cover [Re: Dragula] #1391485
02/26/13 04:46 PM
02/26/13 04:46 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Thanks Brian
Wait until you try putting on the motor mounts...Take some pics when you do so we can see how well it fits. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Milodon Alum pump & cover [Re: dangina] #1391486
02/26/13 09:34 PM
02/26/13 09:34 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
There's a very wise bunch of experienced engine builders on this site that can point you in the right direction regarding preparing and improving the blocks oil passages etc.
Just be careful, take your time and follow the generally accepted practices of the guys who've been there done that.
One of the most critical things you can do is clean everything, and I mean everything several times.
