Page 2 of 5 1 2 3 4 5
Re: 904 trans died behind 390 stroker, time for 727???? [Re: JohnRR] #139066
10/21/08 08:03 PM
10/21/08 08:03 PM
If the front pump failed would it be a relatively easy fix to get at the pump from the front of the trans or does everthing need to come out??? TBF
if the pump failed it usually breaks the tangs off the rotor and/or breaks the snout of the convertor , metal particles go everywhere ...
yes JohnRR is correct there would be (metal)crap throughout. I can't believe that I am actually agreeing with JohnRR
Re: 904 trans died behind 390 stroker, time for 727???? [Re: RapidRobert] #139067
10/21/08 08:18 PM
10/21/08 08:18 PM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
wow. come on guys. there's a reason MA MOPAR put 727's behind all the 340's. they needed a reliable tranny behind the horsepower. I myself have seen enough cracked torque converter hubs, and front seal leaks on 904 tranny's to just want something bigger and better. just my
Re: 904 trans died behind 390 stroker, time for 727???? [Re: 1965_PLYMOUTH] #139068
10/22/08 08:32 PM
10/22/08 08:32 PM
5thAve Offline
5thAve  Offline
Get a 727 it has more of a chance of lasting longer.
Re: 904 trans died behind 390 stroker, time for 727???? [Re: 5thAve] #139069
10/22/08 11:20 PM
10/22/08 11:20 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 904 trans died behind 390 stroker, time for 727???? [Re: Locomotion] #139070
10/23/08 09:23 AM
10/23/08 09:23 AM
Tampa, FL
tpabayflyer Offline OP
Tampa, FL
When I had the trans rebuilt I did use a heavy duty red band... The valve body is original with a transgo shift kit and the trans always would freewheel in 1st gear, even before the rebuild so that must be how it works.......
I did not get a chance to pull the trans yet and it will have to wait until the weekend. I wanted to take this car up to the garlits show next week but I am glad the trans broke close to home...... Keep munchin the popcorn as I will have the autopsy results soon...... TBF
Re: 904 trans died behind 390 stroker, time for 727???? [Re: tpabayflyer] #139071
10/23/08 09:53 AM
10/23/08 09:53 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I have installed a lot of transgo shift kits tf1 and tf2s in factory VBs and never had one free wheel in 1st.Factory Vb has low band apply in manual 1st. Unless you used a tf3 that is full manual and I dont remember if they free wheel in manual 1st or not its been to long on that one.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 904 trans died behind 390 stroker, time for 727???? [Re: tpabayflyer] #139072
10/23/08 08:44 PM
10/23/08 08:44 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I always use the transgo kits and have never had one that would frere wheel. I set up the one in my 904 in my cuda with a TF1 with all the biggest shift valve holes and if you manually hit 1st at a high enough speed the rpms go way high your forehead hits the steering wheel and the back end starts sliding around, my engine makes a lot of vaccume
Re: 904 trans died behind 390 stroker, time for 727???? [Re: HotRodDave] #139073
10/23/08 11:19 PM
10/23/08 11:19 PM
littlestown pa
dustpan man Offline
dustpan man  Offline
littlestown pa
sounds like a vavle body problem
Re: 904 trans died behind 390 stroker, time for 727???? [Re: dusturbd340W5] #139074
10/23/08 11:49 PM
10/23/08 11:49 PM
Tampa, FL
Tampa, FL
I think it was the TF-1 kit but remember this is a lockup converter valve body.......It has an S-bend tube on the top..... Even before I messed with anything drove the car with the stock 318 2bbl the trans would freewheel in 1 st gear. I remember it would not provide engine breaking in 1st gear but I thin it would if i held it down in first... it would freewheel when left in drive???? TBF
Re: 904 trans died behind 390 stroker, time for 727???? [Re: dustpan man] #139075
10/24/08 06:50 AM
10/24/08 06:50 AM
thats what I thought of too. the valves can wear out over many many miles. Or some crap got in there and is blocking something.
I put aB&M shift kit in mine many years ago and it performed great. then the car sat for several years. I just put together a motor and started driving it again and after a few hundred miles, mine started freewheeling when I downshifted to first.
I changed out the valve body for a Turbo Action Cheetah manual/automatic valve body and everything is GOOD, and I mean real GOOD, now. shifting is tight, and problems went away
Re: 904 trans died behind 390 stroker, time for 727???? [Re: tpabayflyer] #139076
10/24/08 08:00 AM
10/24/08 08:00 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
stock, the tranny won't downshift to first until under 5mph when coasting.
2017 Grand Cherokee Overland
Re: 904 trans died behind 390 stroker, time for 727???? [Re: patrick] #139077
10/24/08 08:42 AM
10/24/08 08:42 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
904 + 450+ hp =
Re: 904 trans died behind 390 stroker, time for 727???? [Re: tpabayflyer] #139078
10/24/08 11:14 AM
10/24/08 11:14 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Might be an issue with the over running clutch ? The lockup convertor and it's fluid path should have ZERO effect on first gear operation .
Re: 904 trans died behind 390 stroker, time for 727???? [Re: JohnRR] #139079
10/24/08 07:22 PM
10/24/08 07:22 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Gonna have to agree with JohnRR on this, my trans is a lock up 904 and I got no freewheeling.
I think the free wheeling is from the low reverse band not applying in manual low and it should be applying with a TF 1 2 or 3 kit in manual and auto low. If reverse is fine then the band is functional and you need to figure out why it is not applying.
BTW I really like LU in a street car especially with a high stall converter
Re: 904 trans died behind 390 stroker, time for 727???? [Re: AdamR] #139080
10/24/08 07:27 PM
10/24/08 07:27 PM
CT
turbocolt2.4L Offline
CT
904 + 450+ hp =
OUCH I have 480 hp to the rear wheels with a 4cyl turbo car and run a 904 w/brake with no major problems,just took out the sprag but had over 130 pulls on the chassis dyno and 4 hard passes at the track 904's can take a beatin.........
Re: 904 trans died behind 390 stroker, time for 727???? [Re: turbocolt2.4L] #139081
10/24/08 07:33 PM
10/24/08 07:33 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Yes, 904's can take beatings...those lockup torque convertors can't. Most likely that is the cause of your no-drive condition. Been there on my 88 Diplomat ofter installing a nice 360.
Re: 904 trans died behind 390 stroker, time for 727???? [Re: turbocolt2.4L] #139082
10/25/08 09:29 AM
10/25/08 09:29 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
904 + 450+ hp =
and that colt weighs HOW MUCH ??? 904 will live just fine bolted to a ROLLER SKATE ...
Re: 904 trans died behind 390 stroker, time for 727???? [Re: JohnRR] #139083
10/25/08 09:45 AM
10/25/08 09:45 AM
I am fixing to find out as I am putting a 904(& a /6 one at that)behind a 451 going into a 65 dart) with a JW ultrabell. I am not going to romp on it too much
Re: 904 trans died behind 390 stroker, time for 727???? [Re: RapidRobert] #139084
10/25/08 10:35 AM
10/25/08 10:35 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I have had 904's since 93 with everything from a 275HP 318 to a 500 HP race 360. A lock up converter is weak. I am so sick of 727 gurus hailing them when they have no practical experience with 904's. I sold my engine and trans to a guy in 2002 and he is still running the trans. Talk to John Cope at CRT. I think the biggest problem is the lockup trans, not being a 904.
Tune in for my next sermon " too big a cam will make a good street motor a dog"
Re: 904 trans died behind 390 stroker, time for 727???? [Re: babarracuda] #139085
10/25/08 03:18 PM
10/25/08 03:18 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
My tow vehicle is a '89 3/4 ton van with the 999 with lock up (hd 904). I've had it for 11 years and towed locally and made a few trips towing out of town. It was still towing fine but started leaking bad out the front seal and it stopped locking up. Had it rebuilt while it was out for the front seal fix and put in a new converter.
Last week we towed to Elk Creek Dragway, about 70 miles one way and up and down a couple of steep mountains. No problems. It towed like a champ.
Race car and open trailer weighs about 4900 lbs.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
