Pushrod oiling with EDM lifters
#1390773
02/20/13 10:53 AM
02/20/13 10:53 AM
Posts: 302 Middle of the US
Verga
Middle of the US
Ive read that the EDM lifters (AMC lifters) will pushrod oil. Does the block have to be bushed in order to do this or not?
"Im supercharged, might explode in your face"
Re: Pushrod oiling with EDM lifters
[Re: Verga]
#1390774
02/20/13 11:20 AM
02/20/13 11:20 AM
Posts: 52,972 Romeo MI
MR_P_BODY
It isnt necessary but I did one block with bushings and the one in my Rampage isnt bushed... if your talking the EDM hole to feed the roller, the AMC ones dont have that hole but they are PR oiling... the bushed bores will help if you bend a PR and the lifter pops out
[Re: 383man]
#1390777
02/20/13 11:57 AM
02/20/13 11:57 AM
MR_P_BODY
I am pretty sure my EDM lifters had the pushrod oil hole in the cup and I know they had the cam lobe oiling hole. I do remember thinking to myself it could be made to pushrod oiling real easy. Ron
They werent the AMC lifters were they... the AMC lifter doesnt have the bottom EDM hole for the roller/cam but they are PR oiling
[Re: MR_P_BODY]
#1390781
02/20/13 03:35 PM
02/20/13 03:35 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I got mine from Dwayne Porter and they are definetly EDM. They are from Comp and they have the oil hole in the bottom of the lifter plus they have the small hole in lifter cup and these are solid flat tappet lifters. They look to me if I had hollow pusrods they would oil up thru them. But I have solid pushrods and oil the shafts the normal way with my little EZ heads. Course they are in the eng now but I am 99% sure I remeber it that way. Ron
[Re: 383man]
#1390782
02/20/13 05:39 PM
02/20/13 05:39 PM
MR_P_BODY
Ok... you didnt get them too long ago... those are the ones Brian did the design on.... same ones I have but I bought mine direct from Brian ... before Comp got the design for their production
[Re: Verga]
#1390783
02/20/13 07:14 PM
02/20/13 07:14 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I am assuming your talking about a solid cam lifter? If so......
The block does not have to be bushed.
The EDM is for the cam lobes and lifter face lubrication.
The pushrod oiling is totally seperate issue from the EDM portion. The pushrod oiling is pressurized from the clearance in the lifter bore, thru the lifter, and up into the pushrod, if you have that type of rocker system.
Youi can use the AMC lifters with standard ball/cup type Mopar pushrods, or with oil thru Chevy type pushrods. The solid ball in a Mopar type pushrod will just restrict the flow out of the lifter.
RIP Monte Smith
[Re: 383man]
#1390784
02/20/13 07:18 PM
02/20/13 07:18 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
I agree, Ron. I have those same lifters in my bushed 383 block. They oil the lobe and the PR.
[Re: MR_P_BODY]
#1390789
02/21/13 12:56 AM
02/21/13 12:56 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I'm not clear if you guys are talking solid or solid roller I've used the comp 848 AMC style roller lifter in my hemi and my friends 440.I sent oil up the exhaust only on the hemi and all 16 on the wedge with a 15 lb loss in OP when hot.I had restrictors installed in the hemi pushrods and that brought the OP back to where it was.
[Re: Verga]
#1390790
02/21/13 01:27 AM
02/21/13 01:27 AM
Posts: 75,134 A Banana Republic near you.
JohnRR
Yeah, I know none of the stock lifters came with the EDM hole.
My point is that I have read that at least some of the BB mopar lifters that have EDM holes are AMC lifters,(taller cup height, meaning a shorter pushrod is needed) due to the height of the oil band, in order to oil the EDM hole.
What I didnt know was that these same lifters would push rod oil.
You are making this question very confusing ... An EDM hole is in the BOTTOM of the lifter , the hole in the pushrod cup of an AMC lifter is STANDARD issue , is it EDM'd in it ?? I have no clue .
When EDM lifters are talked about it's lifters with ADDED holes in the bottom of the lifter ...
Then Raff throws in about roller lifters and the OP still hasn't even stated the type of lifter he is asking about other than an AMC style lifter .
Not that it matters at this point I guess
[Re: hemi-itis]
#1390791
02/21/13 01:43 AM
02/21/13 01:43 AM
MR_P_BODY
I am talking ROLLER lifters... the AMC roller lifter had PR oiling for years... but they NEVER offered the EDM hole to oil the roller face... that EDM hole never accrued until the last few years (and AMC NEVER had it in a stock roller lifter)so I hope I cleared up what I was talking about... but the EDM hole only started about 3 years ago in MOST lifter weather its a flat tappet or roller lifter
