Re: E-Body Convertible Interior A-Pillar Trim
[Re: cudaized]
#1390713
02/20/13 12:52 PM
02/20/13 12:52 PM
Posts: 401 California, USA
filmsurgeon
California, USA
It's an easy job. Any saw will cut the plastic. The top, cut portion will be covered under the metal 90 degree corner piece. The bottom screw does not even need to be installed. The plastic piece is held firmly in place. But, if you would like the hole to be filled with a screw, you could just drill a new hole in the new location of the later model modified piece. Just an option. Otherwise you will have the original later model screw hole that will be unused. I personally would look for a 1970-71 piece, if I was going to modify it.
Actual convertible pieces are still out there for sale.
Thanks guys. I'm going to go ahead and use the later model trim pieces I already have since they're in such nice condition (they are literally mint), and although I'm sure there are original 1970-71 pieces out there, I don't want to spend the time (and $$$) looking for good ones. I have lots of other things I need to focus my time and energy on with regard to changes/improvements on the car. I definitely want to use the existing screw hole in the later model trim to ensure a more secure install to the A-Pillar, and to fill in the hole. I assume that you mean "drill an new hole" in the A-Pillar, not the later model trim itself. I just hope that the windshield will not be an obstruction from me drilling the A-Pillar hole.
[Re: YYZ]
#1390714
02/20/13 01:02 PM
02/20/13 01:02 PM
filmsurgeon
California, USA
And to build on Ola's post - the original convertible pillar trim has the same moulded part number as the 70-1 hardtop trim so you will have a point of reference when you go shopping
I guess that's another indication that the hardtop trim was likely cut at the factory for the convertibles. Interesting though that the moulded part number is the same on both of my pieces (the original 70-71 piece that I took out of the car, and the later model hardtop piece that I'm going to cut/use), even though the lower screw holes are in different locations.
[Re: mccannix]
#1390716
02/20/13 06:05 PM
02/20/13 06:05 PM
filmsurgeon
California, USA
Not to be picky and I may be wrong but I believe it is 70 only, not 70 and 71 that has the lower hole real close to the bottom. Also if drilling another hole in the plastic try to have the hole countersunk like original so the screw tightens in and the head is not above the surface thus making it appear factory original.
You might be correct about the year versions. I'm not sure if the info I read somewhere else was 100% accurate. I would not be drilling a new hole in the plastic trim. That would leave me with two holes to fill with screws. My plan is to drill the A-pillar itself to match the existing screw hole in the later model trim.
[Re: filmsurgeon]
#1390717
02/20/13 08:50 PM
02/20/13 08:50 PM
Posts: 406 California City, CA
dart440
California City, CA
I used a die grinder/cutoff wheel to cut mine. Made a perfect cut. Not sure on what the break point is for the the different screw hole locations. I was lucky and had a early style one that was broken at the top, so it was the perfect candidate to make a convertible one out of.
When you work on Spaceships for a living, how bad can a workday be?
