Re: 904 trans died behind 390 stroker, time for 727????
[Re: fasteddie]
#139086
10/25/08 04:56 PM
10/25/08 04:56 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Being a lock up does not make it a bad tranny. The only thing different is the converter has a clutch to lock up at cruising speed. If you want to run a lock up behind a high-po mill just drill the releif passages in the VB out so it locks up faster (buy the Trans-go TF 12 or 3 kit of your choice for details) drill the holes to max diameter or even one size bigger to really firm it up so it don't slip and burn. Also install the stiff spring to delay engagement untill a higher speed. I have built several for my various cars and a couple were race cars, all were strong street cars at the least and the only one that I ever had fail was one where my cooler line blew on the way to the track and I kept driving it, it wouldn't hardly move when I got there, I raced that night after fixing it at the track. And the next day the forward clutches gave out, I rebuilt it and used the same converter and never had another problem racing that trans till I sold the car. If you build the trans right the 904 is not a problem and LU is not a problem. PS ask Andy Mayes about the LU 904 in his roofing truck I built with a TF3 kit. He still cusses at me for building a manual shift trans for a work truck, I just did it to see if I liked it and then he bought the truck from me and is still driving it years later, says hes going to put a 727 in if he can ever kill it
[Re: JohnRR]
#139089
10/25/08 07:09 PM
10/25/08 07:09 PM
Posts: 296 CT
turbocolt2.4L
CT
904 + 450+ hp =
OUCH I have 480 hp to the rear wheels with a 4cyl turbo car and run a 904 w/brake with no major problems,just took out the sprag but had over 130 pulls on the chassis dyno and 4 hard passes at the track 904's can take a beatin.........
and that colt weighs HOW MUCH ??? 904 will live just fine bolted to a ROLLER SKATE ...
2495 with me. BTW i leave with 29psi of boost on the brake at 7500rpm so we'll see if the 8.75 holds........... :
[Re: slantzilla]
#139092
10/25/08 11:28 PM
10/25/08 11:28 PM
RapidRobert
what truck apps had the 5 clutch drums? & I do have a 904 from a 318 laying around. If I end up really beefing this thing I'm going to have to romp on it just to check out my handiwork.
[Re: slantzilla]
#139096
10/26/08 01:34 PM
10/26/08 01:34 PM
HotRodDave
Kalispell Mt.
the late 70s 360 4bbl motors and mabey even the 2bbl motors in cars had 5 clutch front drums with non LU trannys. They were called A-999s. They were a heavy duty 904 non-lu. Later LU 904s from trucks in the early 80s and later had 5 clutch front drums and low 1st and 2nd gears. The low ratio gears are the toughest stock gear sets also, 4 pinions and steel cages. I know there is some way to put these drums in a non-lu 904 but I don't remember exactly what needs to be done.
[Re: tpabayflyer]
#139098
10/27/08 09:23 AM
10/27/08 09:23 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
A&A sells a special thin disk with grooves to install in a 4 clutch drum so you end up with 5 disks. The grooves evacuate the fluid fast when applied since its a shifting clutch.
The parts needed out of the A-999 are the front pump, Front drum (deeper) and rear drum (has a wider hub to engage all 5 disks).
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: CJK440]
#139099
10/29/08 02:52 PM
10/29/08 02:52 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
Well.. I don't who the lucky winner is but it looks like the input shaft snapped in half...... The remaining threads show some evidence of twisting before failing.....
Now, If I put a new input shaft in can I expect the same problem to happen again?? I would think so... Is this problem associated with the lockup converter system?? Does a non-lockup have a solid style input shaft that is thicker and stronger??? If so can I install a non-lockup input shaft in this trans and just get a different converter???? Or should I just dump this whole mess and build a nice 727????? TIA TBF
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
[Re: tpabayflyer]
#139101
10/29/08 02:55 PM
10/29/08 02:55 PM
tpabayflyer
Tampa, FL
threads are twisted a bit... kinda blurry.. TBF
[Re: tpabayflyer]
#139102
10/29/08 03:07 PM
10/29/08 03:07 PM
Posts: 15,487 Florida
scratchnfotraction
way to go!!! a 390 with 3.73 gears done killed flight 904 wonder if anything else was damaged? full of shavings? pan still clean? in the long run..I would go 727 IMO dont guess your gonna get to drive up to big daddys this weekend do you have a 727 core yet? may find one quick at the clearwater u-pull it,holler if ya need a hand with it,may take friday off and be over there looking for one myself turkey day weekend sale is a comin also
