Re: four wheel disc don't stop car [Re: BigBlockMopar] #1389440
02/18/13 07:16 AM
02/18/13 07:16 AM
The Netherlands, OV
dickdale Offline
dickdale  Offline
The Netherlands, OV
Change the bore size of the master cylinder...
Re: four wheel disc don't stop car [Re: JimDiesel] #1389441
02/18/13 10:39 AM
02/18/13 10:39 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Smaller master cylinder. That will get you going until you're ready to do some upgrades.
Take care of those lines like the others suggested.
If the pedal isn't spongy there is no reason to bleed the rears.
If you do need to bleed upside down calipers it's easier than you think.
Open the master cylinder cap.
Unbolt the caliper from the axle.
Hold the caliper at a funky angle so the bleeder is the highest point.
Open the bleed screw and let it gravity bleed for a few seconds.
Reinstall.
I had to do that on my TSM rear brake calipers.
- Stu Harmon
Re: four wheel disc don't stop car [Re: feets] #1389442
02/18/13 11:51 AM
02/18/13 11:51 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I just wanted to add that those GM calipers go bad frequently and if the pads aren't adjusted tight they'll never work-in addition to everything else put out here. The parts store "rebuilt" units are hit-miss on working out of the box, get them with a lifetime warranty, or try to get new ones on ebay.
Re: four wheel disc don't stop car [Re: Skeptic] #1389443
02/18/13 01:46 PM
02/18/13 01:46 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
the picture shows the hose going in the top and the bleeder is at the bottom---cant bleed it unless you put the car on its top---the other problem is chevy masters work the opposite of mopars--on the mopar the back line goes to the front brakes--on a chevy the front line goes to the front brakes----i would go back to mopar stuff---yeah yeah yeah--chevy gave us the sbc---ford gave us the 9 inch--mopar was the leader in brakes---mopar was so superior that wilwood copied it....bob
Re: four wheel disc don't stop car [Re: savoy64] #1389444
02/18/13 06:06 PM
02/18/13 06:06 PM
Petaluma, CA
JimDiesel Offline OP
Petaluma, CA
Thanks for all the replies.
I appreciate the help.
Since the car can’t be driven as is, I am committed to spending some money to fix/upgrade.
I am ok with switching the rear calipers side to side and buying a new MC. I just don’t want to throw good money after bad, if this setup is always going to be sub-par, then I think I would be better off replacing the whole thing. I guess the rears need to be switched or replaced either way. The front rotors seem pretty small for a 4,000-pound car.
At some point I want to be able to take my little girls for a Sunday drive, and it needs to be able to stop.
The wheels are 16x8 torque thrust style aluminum wheels. The tires need to be replaced, and with the lack of appropriate 16-inch tires, I will likely be going to back to 15-inch steels that I have in the garage.
68 Road Runner
67 Coronet
Re: four wheel disc don't stop car [Re: Skeptic] #1389445
02/18/13 11:46 PM
02/18/13 11:46 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You are talking about he rear calipers with the built in E brake I assume? That would be correct. If the E brake isn't functioning properly and used regularly slack builds up between the pads and rotor causing a lower amount of braking to occur. This could very well be the issue here, along with the other ones mentioned.
Don't be the exception.
Re: four wheel disc don't stop car [Re: Supercuda] #1389446
02/19/13 12:02 AM
02/19/13 12:02 AM
Petaluma, CA
Petaluma, CA
The E brake doesn't do anything.
The pedal goes to the floor with no effect.
I havent looked into it yet.
I was focusing on getting the car to stop first, not knowing that could be a symptom of other issues.
68 Road Runner
67 Coronet
Re: four wheel disc don't stop car [Re: savoy64] #1389447
02/19/13 02:09 AM
02/19/13 02:09 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Wrong. You pull the calipers off, hold them at a funky angle where the bleeder is highest, and gravity bleed for a few seconds.
I did that using the exact same calipers on the hot rod (before the AMG conversion)
You realize that the master cylinder has the same size bore all the way through, right? It makes no difference which bore leads to which brakes. When you push on the pedal the exact same fluid movement and pressure is found in both lines.
The only difference will be if one reservoir is larger than the other. The larger reservoir needs to feed the larger caliper. That way you don't get too low on fluid as the pads wear.
- Stu Harmon
Re: four wheel disc don't stop car [Re: feets] #1389448
02/19/13 11:04 AM
02/19/13 11:04 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I am not sure about anything, but that master cly looks like it's for drum brakes??
I used to work at Hader Industries here in Cincinnati, they made master cylinders and pistons. I ran a screw machine making those pistons inside the master cylinders.
Re: four wheel disc don't stop car [Re: Challenger 1] #1389449
02/19/13 12:52 PM
02/19/13 12:52 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If the bore is the proper size and there are not residual valves it doesn't matter what the original application was.
However, if it doesn't meet that criteria there will be problems.
- Stu Harmon
Re: four wheel disc don't stop car [Re: Challenger 1] #1389450
02/19/13 12:52 PM
02/19/13 12:52 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
http://www.rockauto.com/catalog/moreinfo.php?pk=309131&cc=1232020
RAYBESTOS Part # MC36439
Looks like this is what you have a 1 1/32" bore Drum Brake M/C. Definetly the wrong set-up for your combo.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: four wheel disc don't stop car [Re: JimDiesel] #1389451
02/20/13 12:06 AM
02/20/13 12:06 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The rear GM calipers are designed to use the Ebrake as a method to take up sack as the pad wears. The lever the ebrake cable attaches to mechanically applies the piston via a one way ratchet mechanism. If the ebrake isn't used or isn't functional the pads will have a larger and larger gap between the pad and rotor. This will affect the feel at the pedal, to the point of being ineffectual if it the gap grows larger enough. Here's an interesting link
http://classicbroncos.com/tech/rear-disc-brakes-cadillacgm-calipers
Re: four wheel disc don't stop car [Re: Supercuda] #1389452
02/21/13 12:29 AM
02/21/13 12:29 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Have you tried adjusting the prop valve??
Those GM rear calipers NEVER worked well.I've seen that alot especially on Eldorados
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: four wheel disc don't stop car [Re: hemi-itis] #1389453
02/21/13 01:42 PM
02/21/13 01:42 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
See the first post from the OP. His pedal feel ok. If you have never run these GM Calipers, the first thing you notice when they are out of adjustment is you get excessive pedal travel.....this is not the case. Granted, they may need adjustment but this is not the root of the problem.
He has the wrong combination M/C to Calipers. Simple fix.
I also run these aluminum rear Wilwood Metric Calipers in place of the Stock GM calipers. Much better for track use and competition.
http://www.summitracing.com/parts/WIL-120-7197/
Re: four wheel disc don't stop car [Re: Viol8r] #1389454
02/21/13 02:07 PM
02/21/13 02:07 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
This is an SSBC front and rear brake kit.
It uses late '60s Mustang front calipers and late '80s Thunderbird rear calipers. The bleeder valve is located in the banjo bolt at the top of the caliper.
The least expensive remedy is a 15/16" bore master cylinder and aggressive front brake pads (ie EBC Yellow).
Re: four wheel disc don't stop car [Re: DoctorDiff] #1389455
02/21/13 03:01 PM
02/21/13 03:01 PM
Petaluma, CA
Petaluma, CA
sorry, i have been down with stomach flu.
I did play with the prop valve and it didnt seem to have much effect. It defintely didn't improve things. I need to check the plumbing to see if it is even installed correctly.
I will try to get some better pics of the master.
68 Road Runner
67 Coronet
Re: four wheel disc don't stop car [Re: JimDiesel] #1389456
02/21/13 03:04 PM
02/21/13 03:04 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Save yourself the trouble and go with Dr. Diff's advice..... get a different Master Cylinder. We saw the earlier picture....it looks to be a earlier A-body M/C.
