restoring lower control arm
#1386694
02/13/13 12:45 AM
02/13/13 12:45 AM
Posts: 738 Oh Canada
EV2CUDA
Oh Canada
I believe it was cosmoline dipped? Not sure on that but anyway I would like to get my lower control arms to look somewhat factory with something out of a rattle can. Its on a 71 Barracuda. I have the lowers off right now and want to clean them up. Thanks.
71 Barracuda 383 4spd (500ci) 69 camaro 598, NOS 69 barracuda bbc procharger 77 t/a 6.0 turbo project 78 t/a 400 77 corvette 1983 hurst/olds 03 Viper 79 360 macho 71 demon 360 78 Warlock 5.7 hemi project
Re: restoring lower control arm
[Re: 1_WILD_RT]
#1386696
02/13/13 07:28 AM
02/13/13 07:28 AM
People have mentioned the Krylon battery terminal protector and then using a satin clear over the top of it. I just ended up using the spray can from eastwood, rust proof inhibitor.
[Re: ]
#1386698
02/13/13 10:18 AM
02/13/13 10:18 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
No matter what coating you decide on using, this is the result you are after. This is an NOS example. They were (partially) dipped in Cosmoline and partially bare metal (they were not completely dipped). If you want the ultimate in originallity/correctness you can still buy Cosmoline Buy It Here Linky . After the part is cleaned of all rust treat it with a metal prep like Ospho, rinse it with Acetone or thinner (not water) warm it with a heat gun and apply RPM to the entire arm, this will protect it from future rust (even under the Cosmoline should it wear off) and then re-dip it in Cosmoline up to the hole shown in my pic.
[Re: ScottSmith_Harms]
#1386699
02/13/13 10:32 AM
02/13/13 10:32 AM
Posts: 579 Wattsburg, Pa
Dr V
Wattsburg, Pa
Good pic Scott.. I knew they stopped that dip line somewhere but I chose to take it all the way up to not see any rust potential at all in the future...
69 1/2 A12 BEE 4 spd 1968 Charger 383 1970 Roadrunner 440+6 Survivor 2019 Redeye 2005 FORD GT Red/White 2017 Viper ACR Extreme Red/White 1979 Branco Red/Red 2018 Porsche GT3 Miami 1971 440+6 Cuda 4 speed V2 2020 Sebring Orange Vette 1979 Chevy Boogie Hippie Van
[Re: Dr V]
#1386700
02/13/13 10:39 AM
02/13/13 10:39 AM
Posts: 1,177 Woodbridge
Tommy The Chryco
Woodbridge
so I'm assuming you dip the arm in two separate pieces insert the new bushing then reassemble?
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
[Re: Dr V]
#1386701
02/13/13 11:56 AM
02/13/13 11:56 AM
Posts: 18,160 Mass
DAYCLONA
Mass
The vendor for Chrysler making the lower control arms was IIRC, a division of AO Smith, a railcar axle manufacturer at the time, the LCA's; after the two halves were rivited together had the ball joint end placed on a hook conveyor that ran the parts thru a molten cosmoline bath, the ball joint end was not covered as Chrysler wanted no spinning ball joints, or assy problems on the line...I'm sure the bath height varied some, due to the number of arms running thru the bath, as well as the level being maintained by the workers...so the dip line, I'm sure varied on the finished project, although I'm sure engineering supplied some specs to be maintained, it's also been documented that excess stock/dealer inventory was to be coated in Black enamel, and the arms were to be completely submerged to prevent storage wear/rust.
The interview with the manufacturer and employees is avaiable on the Winged Warriors Club site
[Re: DAYCLONA]
#1386702
02/13/13 02:14 PM
02/13/13 02:14 PM
Posts: 27,485 So Cal
autoxcuda
So Cal
Here another NOS LCA that's been sitting on a shelf for 30+ years with the dip line in a slightly different place.
![](https://board.moparts.org/ubbthreads/upload2/2678622-NOSlowercontrolarm.JPG)
[Re: ]
#1386703
02/13/13 02:22 PM
02/13/13 02:22 PM
autoxcuda
So Cal
That's what Troy did here with Krylon battery protector and clear satin on top:
[Re: autoxcuda]
#1386704
02/13/13 03:57 PM
02/13/13 03:57 PM
Posts: 683 Northern NJ
68 Sat
Northern NJ
THIS IS THE CORRECT WAY.....100%
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor
1969 Dodge Coronet 500
1956 Desoto Hemi
1955 Chrysler C300
[Re: JohnRR]
#1386706
02/13/13 07:33 PM
02/13/13 07:33 PM
EV2CUDA
Oh Canada
Found out someone installed an a body lower control arm on the passenger side, isnt that nice. They also did some creative welding on the pivot. Glad I wanted to change the bushing to find this mess.
Ill be using the krylon spray cans. It is not to be 100% correct. Not copper paint either?
[Re: TX9H6E4CUDA]
#1386710
02/13/13 11:12 PM
02/13/13 11:12 PM
Posts: 2,304 WI
RestoRick
WI
In production they were most commonly the cosmoline coating, but black is possible. One of my customers who worked & retired from AO Smith, told me that they also manufactured parts for railroad cars. When the cosmoline dip line was being used for that, the control arms would be done in the black paint dip. He had detailed stories explaining how the different pieces were formed and assembled... should've recorded him. ![](/ubbthreads/images/graemlins/smile.gif)
[Re: autoxcuda]
#1386712
02/14/13 12:54 AM
02/14/13 12:54 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Yeap, just make sure the job isn't too neat, you need to have runs... And, the arm needs to be hanging...... Would be funny looking with run marks going in the wrong direction....
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#1386713
02/14/13 01:45 AM
02/14/13 01:45 AM
kinda like horizontal drip lines in the primer on the inside of a fender that was in another thread. Now THAT was funny!
