Page 6 of 9 1 2 3 4 5 6 7 8 9
Re: QA1 Suspension R & D [Re: TC@HP2] #1386448
08/21/13 09:20 PM
08/21/13 09:20 PM
the house on the left.
cogen80 Offline
cogen80  Offline
and you have a tubular K set up for a hair under $3200, or about $1200 less than an AlterK.
WOW! that close in price.. kinda be nuts not to go with the alter-k at that point.
Re: QA1 Suspension R & D [Re: TC@HP2] #1386449
08/21/13 09:56 PM
08/21/13 09:56 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
This set up will not be for everyone, but it will probably be a popular conversion for a lot of poeple. Looking at my recently received Mancini flyer, the K is being offered at $594, lower arms are $395, upper arms are $304. Add some "dynamic struts for $192, Bilstein shocks for $400, a new Delphi box set up for $1000, and some new t-bars for $300 and you have a tubular K set up for a hair under $3200, or about $1200 less than an AlterK.
Mx and match parts you already have and you can save a few
bucks off of that. I predict these will be pretty popular.
mixing and matching is key to that comparison... alterk cant exactly be done a piece at a time while still driving the car. a firm feel box and stock boxed lower arms are acceptable for lots of folks and dont forget 700 for a brake kit for altrk. point being that 1200 disparity could double pretty easy.
Re: QA1 Suspension R & D [Re: Pool Fixer] #1386450
08/22/13 01:04 PM
08/22/13 01:04 PM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
when will the b body version be available? (68-70) [/quhipote]
We just mocked it up a few days ago and did a tech article photoshoot for Popular Hot Rodding. Everything went on very nice. We have some revisions that need to be made to the Lower Control Arms, so I think this will delay the availability of the unit for a short while.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: QA1 Suspension R & D [Re: Viol8r] #1386451
08/22/13 06:19 PM
08/22/13 06:19 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
do you have to use their lower arms?
Re: QA1 Suspension R & D [Re: Pool Fixer] #1386452
08/23/13 04:24 PM
08/23/13 04:24 PM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
Not necessarily. But to the common buyer I would suggest it, because they have relocated the sway bar mounts to accept a '70 E or B body type bar.
If you were willing to do a little homework you could easily adapt a spline bar to the supplied mounts and have a bit more stability in the front end if need be. This would give you to option to run whatever LCA you desire.
Re: QA1 Suspension R & D [Re: Viol8r] #1386453
08/25/13 10:53 PM
08/25/13 10:53 PM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
looks like pretty good quality control at qa1
http://www.youtube.com/watch?v=TwhpIkmi5LE
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: QA1 Suspension R & D [Re: sublimehemi] #1386454
10/26/13 11:46 PM
10/26/13 11:46 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
any sort of timeframe for the release of the B body K member?
Re: QA1 Suspension R & D [Re: Pool Fixer] #1386455
10/27/13 01:29 AM
10/27/13 01:29 AM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
Its out... part number at summit is 52315...I bought one a few weeks ago a d love
Re: QA1 Suspension R & D [Re: sublimehemi] #1386456
10/27/13 09:32 AM
10/27/13 09:32 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
summit and mancini still only list A and E body.
Re: QA1 Suspension R & D [Re: sublimehemi] #1386457
10/27/13 10:29 AM
10/27/13 10:29 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
That part # doesn't come up as a QA1 part on the Summit website
Re: QA1 Suspension R & D [Re: Skeptic] #1386458
10/28/13 10:54 AM
10/28/13 10:54 AM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
I suggest you call QA1 direct and make sure you are getting the correct information. The K-Member we R&D'd for them went on without any issues. There were a few adjustments needed for the LCA's which, to my knowledge, were being taken care of. We made the adjustments in house and have not received the new pieces yet so I can't comment on their availability. All the more reason to call and make sure that you get their blessing if you are looking for the complete set-up.
I will see if I can talk to the guys in engineering and see where things are at.
Re: QA1 Suspension R & D [Re: Viol8r] #1386459
10/28/13 09:53 PM
10/28/13 09:53 PM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
i used hotchkis sway for 70 ebody and worked perfect with qa1 tube lowers...hope this helps
Re: QA1 Suspension R & D [Re: Viol8r] #1386460
10/29/13 10:51 AM
10/29/13 10:51 AM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
I spoke with Engineering. They are still finalizing the B-body LCA for production. They did let me know that they sent me the the first 1 3/8" Sway bar (70 E-body for the application) to test out. Great news for us B-body guys! I believe they are ramping up to supply bars with the set-up, so you can have a complete front end.
Re: QA1 Suspension R & D [Re: Viol8r] #1386461
10/29/13 08:36 PM
10/29/13 08:36 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I'd guess that the issue is with the Summit website. I've got an A body, so I was just commenting on the availability/PN @ Summit. Regardless it's good to see new options for our old cars. Keep up the good work.
Re: QA1 Suspension R & D [Re: Skeptic] #1386462
10/29/13 09:44 PM
10/29/13 09:44 PM
moparAL Offline
moparAL  Offline
MS68EFTI please post a picture of that 1 3/8 bar when you receive it.
Thanks,
MoparAL
Re: QA1 Suspension R & D [Re: Viol8r] #1386463
11/11/13 05:43 PM
11/11/13 05:43 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
I went to SEMA last week and recieved some good information on the k-frames and lower arms. Both are being made with 1020 mild steel which I like as you won't have the cracking and work hardening issues down the road like you do with moly. 2nd thing was what happens if you put a floor jack to it like you do with the stock frame to jack the front of the car up. The gent I talked to said just make sure you catch both tubes with the jack and you will be fine. I would not like one that is too lite weight to be of use on a car for normal maintenance and useage. When I can swing it, they will be on my list of buys.
Carl Kessel
Re: QA1 Suspension R & D [Re: moparAL] #1386464
11/11/13 05:55 PM
11/11/13 05:55 PM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
Thanks,
MoparAL
I have the new QA1 1 3/8" R&D bar in my shop now. This is a 70 B/E body version that fits the K-Members. I have been asking for the heavier bar for track applications and so they made me one. Only one in existence now, but I imagine if all goes well it will be an afforable option with the K-member.
Re: QA1 Suspension R & D [Re: Viol8r] #1386465
11/11/13 07:18 PM
11/11/13 07:18 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Thanks,
MoparAL
Nice , is it solid or hollow?
Re: QA1 Suspension R & D [Re: brads70] #1386466
11/12/13 01:22 AM
11/12/13 01:22 AM
Woodinville, WA
Viol8r Offline OP
Viol8r  Offline OP
Woodinville, WA
Thanks,
Hi
MoparAL
This is hollow.
Re: QA1 Suspension R & D [Re: Viol8r] #1386467
11/12/13 02:09 AM
11/12/13 02:09 AM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
When you get a chance, can you weigh the new bar? Looks like a quality piece!
