checking intake gasket thickness needed?
#1385972
02/12/13 12:14 AM
02/12/13 12:14 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
how should I check for the correct thickness intake gasket needed?feeler gages under the intake? how would you do it?
Re: checking intake gasket thickness needed?
[Re: Clanton]
#1385974
02/12/13 03:53 PM
02/12/13 03:53 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
I use a feeler gauge to check the intake manifold to head sealing surfaces and misalignment on the corners by setting the intake on the motor and use the feeler gauges on each corner at the top and bottom, IE left rear bottom might be .035, top rear left might be .003, LF top.060, LF bottom .000 and so on and then do same on the passenger side. I write the numbers on the intake manifold at each location and then have the manifold cut at a good Hi Po machine shop to make it fit square I like to have around .002 to .004 tapered to the top of the manifold so the manifold will pinch the intake gaskets tight at the bottom to help seal the intake pan fron the lifter galley As far as raising or lowering the intake mainifold for alignment to the ports your on your own, I do use the thin Fel Pro intake gasket (or thicker other brands )to help raise it as needed when needed. It is far better to have the intake port on the heads a little bit (.030+ per side)bigger than the intake manifold ports are Good luck
[Re: roadhazard]
#1385978
02/12/13 08:07 PM
02/12/13 08:07 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I used slotted roll pins pressed in the heads to locate the plate to the head (Red) then I port matched it. The (Blue) circles are the holes I drilled through the intake manifold into the plate to locate the manifold alignment with 1/16" solid pins that are removed when I snug the intake down. Whenever I have to pull the intake I know that when it's reinstalled everything goes back in EXACTLY the same position
