Re: Valve train question
[Re: jbc426]
#1385424
02/15/13 01:34 PM
02/15/13 01:34 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Thanks for all the reply's. Plan on putting a new set of lifters in it and give it a go. Might buy a new set of heads for it this summer and if I do I will go with an adjustable roller rocker setup.
How many miles do you have on this motor since this all happened?
It's kind of surprising you don't have a flat/ damaged cam lobe already from running those used lifters, and you'll be taking another chance when installing that new set.
A lot of people on this board aren't so lucky even with all new parts.
I hope this all works out for you and you've Dodged a bullet.
Over ther years Ihave seen people that put the lifters in a box and reused them when reassembling. Making sure that the lifters and cam are clean and well lubricated and they end result was no problem. Granted it isn't a good idea but if you have run it for even a relatively short time with no problem I would not worry about it and run it. Save your money for later up grades. The damage would have been virtually immediate.
[Re: Dodgeguy101]
#1385425
02/16/13 12:53 AM
02/16/13 12:53 AM
Posts: 35 Dallas, Texas
bigcountry
Dallas, Texas
I would be asking why did it only happen on one? If all these assumptions were correct, you would have 16 pushrod problems, not one. IMO.
That is why I asked this question. Most people say it just happens sometimes BUT I want to know the cause. These lifters have less than 15 miles on them plus 10-15 min idle time after installing them.
[Re: Dodgeguy101]
#1385428
02/17/13 12:36 AM
02/17/13 12:36 AM
Posts: 1,902 MYRTLE BEACH SOUTH CAROLINA
ek3
it can not be put more simply than that. lifters dont just get holes sometimes. post a photo of dammaged parts.......
[Re: bigcountry]
#1385430
02/17/13 08:13 PM
02/17/13 08:13 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
one way is to leave I want to preview my post and/or attach a file checked then it will have a place to choose file to attach file must be resized small enough to be allowed. Other is to go to Photobucket.com join upload your photo there click the photo and there will be a links box to the right click the IMG line (second from bottom) the come hear and paste in your post Ctrl V or use paste in browser and line shows up and will show as a picture after you post
