Page 3 of 3 1 2 3
Re: .528 purple shaft street-able? [Re: OhioMopar] #1385362
02/13/13 10:36 PM
02/13/13 10:36 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
Not to hijack the thread or anything...
but this thread reminds me of my '69 300
C body convertible I owned 25 years ago.
Installed a similar MP .509 hydraulic cam (straight up) in the stone stock 440 short block (original engine,10:1 comp.350 hp version)factory stock 906 heads,used an old CH4B Eddy intake,ootb untouched Holley 750 3310 vac.secondary carb, MP ignition, Hooker 1-7/8 headers I believe...full 2-1/2 in. exhaust, with cheap turbo mufflers, 3.91 sure-grip with rock hard radial 60 series tires out back...
Best Quarter mile time? 14.19 @ 99mph Milan Dragway MI. around late summer 1987...in a
4600 pound boat!!!
used to street race it some, and whupped
a (brand new at the time) '87 Grand National
very badly on Gratiot Ave. one memorable summer night! wish I still had that car.
Plymouth Makes It!
Re: .528 purple shaft street-able? [Re: RoadRunnerLuva] #1385363
02/13/13 11:14 PM
02/13/13 11:14 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
the .509 is a larger cam then the .528 solid. I like the .528 but I still think a more modern grind can be better depending on the package.
Re: .528 purple shaft street-able? [Re: moper] #1385364
02/13/13 11:44 PM
02/13/13 11:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I agree but the engine I am going to try it on is for someone that doesn't need the fear of using a cam ground to take advantage of the .904 lifter. I have an Engle KV-1 that I think is similar to the .528 that I want to put in a stockish 383 to see how it runs , I had it ground up for a 432 F.A.S.T. stroker and had the lobe sep spread to 112 to bring up the idle vac, but I need to put that in something with bushed lifter bores ...
Re: .528 purple shaft street-able? [Re: JohnRR] #1385365
02/26/13 01:48 PM
02/26/13 01:48 PM
central Florida
titan Offline
titan  Offline
central Florida
Does anyone have the valve opening/closing stats so one can run the .528 on a dyno simulation program?
Re: .528 purple shaft street-able? [Re: titan] #1385366
02/26/13 06:50 PM
02/26/13 06:50 PM
FastOne Offline
FastOne  Offline
intake opens 32 BTDC, intake closes 72 ABDC, exhaust opens 76 BBDC, exhaust closes 28 ATDC
Sounds like a decent profile for a Ski boat?
Re: .528 purple shaft street-able? [Re: AndyF] #1385367
04/28/13 04:57 PM
04/28/13 04:57 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
The .528 works great with HP manifolds. Worked better than any other cam that I tested. I did tons of dyno testing and never found anything that worked better than the .528 cam.
Andy's done all the work, and I see no need to re-invent the wheel, so I'll be swapping to the .528 cam in my 496 stroker with manifolds, MP452 heads, and six pack. 4 speed trans. Should I advance it a couple of degrees? My compression is purposely low at 8.82 (measured).
This is the land of the free because of the brave
Re: .528 purple shaft street-able? [Re: GTXbound] #1385368
04/28/13 05:04 PM
04/28/13 05:04 PM
Cape Coral
65 DODGE POST Offline
Cape Coral
Cam is definitely street able... I had one in a 360 with ported x heads when I was 21...(16 years ago Damn!) I drove it everyday It was in a 3500 lb challenger.... with a 4500 stall 3.55 gears car ran 12:37 at 108MPH...That cam in a big block would be on the mild side....Just my opinion..my motor made about 390-400 horse
65 DODGE CORONET 440 INDY EZ HEADS STRANGE S60
Re: .528 purple shaft street-able? [Re: rbstroker] #1385369
04/28/13 05:08 PM
04/28/13 05:08 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
The suggested install is at 110. IIRC, it's cut on a 112 LSA
I put mine in a 340 at 107 and it's a pretty good runner.
Re: .528 purple shaft street-able? [Re: rbstroker] #1385370
04/28/13 08:34 PM
04/28/13 08:34 PM
AndyF Offline
AndyF  Offline
You probably want that cam installed at 108. That should be a good combo. Tell us how it works. The .528 is mild enough that the six pack tuning shouldn't be too hard. You'll need to recurve the distributor a little but that should be about it.
Page 3 of 3 1 2 3
