Page 2 of 3 1 2 3
Re: .528 purple shaft street-able? [Re: GTXbound] #1385342
02/11/13 11:49 PM
02/11/13 11:49 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
I guess i'll get this motor ready to go as follows
zero decked block
2355 pitons & 6 pack rods
.040 cometic head gaskets
Edelbrock RPM's milled to 78cc & gasket matched
Compression works out to about 10.6
.528 Purple shaft 4 degrees advance it the ptv checks out.
But i got another question .......
How will advancing the cam 4 degrees affect the compression (now is 10.6) for pump gas on the street ????
I'd rethink the 6pak rods if it's not too late.
Kevin
Re: .528 purple shaft street-able? [Re: domingo] #1385343
02/12/13 12:02 AM
02/12/13 12:02 AM
AndyF Offline
AndyF  Offline
Andy,
Did you try thr .557 too thru the manifolds? How did it compare to the ,528???
The .557 wouldn't work well with manifolds so I never even bothered to try it.
Re: .528 purple shaft street-able? [Re: Jeremiah] #1385344
02/12/13 12:04 AM
02/12/13 12:04 AM
AndyF Offline
AndyF  Offline
Refresh my memory - did you try any roller cams in that engine? I am slowly working on a 511 low deck that will have manifolds so this thread has my attention.
I did a bunch of dyno testing with other flat tappet cams. Mostly solid flat tappet but also a hyd flat tappet. A couple of years later I did another stroker motor which was slightly bigger and with better heads. I used a hyd roller in the second motor but it didn't really make a lot more power than the .528 flat tappet.
The FAST guys have spent a lot more time and money on this subject than me. I'm sure that Dwayne could find a cam that would make more power than the .528 these days and it would probably be a roller cam.
Back when I did my testing I worked with a couple of different cam mfgs and they sent me their best designs. So it wasn't like I was just picking cams out of the catalog and testing them. I ran exactly what the engineers told me to run and nothing worked better than the .528 cam.
Very good info. Thank you Andy. I am looking for a low maintenance combination that will idle like a stocker with the A/C on. It sounds like the .528 could be a very good place to save a little coin too. Adding a hydraulic roller adds a significant amount to the budget once you price out lifters, a roller cam that can drive a mechanical fuel pump, etc.
Yes,a hyd roller does add a lot of money. If the budget is tight that is one of the first places to save money. For a street engine you won't see much difference.
Re: .528 purple shaft street-able? [Re: GTXbound] #1385345
02/12/13 12:08 AM
02/12/13 12:08 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would install it at 106 maybe as far as 104!
Re: .528 purple shaft street-able? [Re: Dodgem] #1385346
02/12/13 01:13 AM
02/12/13 01:13 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Andy,
Could you go into a little detail about the the testing you did? I bought your book and have read in other posts that you tested other cams with the manifolds,etc. I have never seen any results as far as power made,other cams tried,etc.
I think it would really help some guys to see dyno sheets or graphs.
Was the 528 the best average torque and horsepower ? Or was the power better down low for a street car only? Thanks for your input!
Keith
Re: .528 purple shaft street-able? [Re: Twostick] #1385347
02/12/13 01:38 AM
02/12/13 01:38 AM
NY VA USA
GTXbound Offline OP
GTXbound  Offline OP
NY VA USA
zero decked block
Kevin
Too late the rotating assembly was balanced long ago and just sitting on the shelf....
How bad can the 6 pack rods be beside the weight?
It is realy just a street car with hopefully 500++HP ...lol
Re: .528 purple shaft street-able? [Re: GTXbound] #1385348
02/12/13 02:36 AM
02/12/13 02:36 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
back in 1990 i had a 67 dart 340 and used the .528 purple lashed at .026 .028 it was real strong so then i thot the .557 would be better and a weekend later the .557 was out and .528 was back in,it had great street manners and pulled hard to 7200 but best was to shift at 6800 i still have it on the shelf made great racing memories with it.
Re: .528 purple shaft street-able? [Re: GTXbound] #1385349
02/12/13 09:25 AM
02/12/13 09:25 AM
Sweet5ltr Offline
Sweet5ltr  Offline
Hey Guys
Just wanted some advice on the .528 purple shaft
would you guys run it straight up or advance it 4 degrees ?
Projected spec's looking for 500+ HP
comp 10:25 need's to live on pump gas.
Edelbrock aluminum RPM's 82cc
Edelbrock rpm intake gasket matched
Its going in a 4 speed 70 Dart .
Rear is 4:10's currently but i have a pumkin with 3:91's and 28 X 10.5 tire
I use nearly the same combination (RPM heads, Victor intake, 4.10 gears, 4-speed, etc). Except, I run the .590 solid from Mopar, widely stated by Mopar to be completely un-streetable. I run the camshaft EVERY DAY on the street, and it is aggressive, but no where near un-streetable. .528 would be a kitten, I would either go with the .557 or .590 at a MINIMUM if you want to build serious power and have a ridiculous idle sound to match..
1969 Plymouth Road Runner (440 w/ Boost! RIP) now a low-deck 470 with hotchkis suspension, nascar boom tube exhaust, & big brakes.
Re: .528 purple shaft street-able? [Re: Sweet5ltr] #1385350
02/12/13 11:38 AM
02/12/13 11:38 AM
Netherlands
72Challenger Offline
Netherlands
I guess I would install the cam straigh up, no advance. I mean it's a 4-speed, just up the revs when you have lack of trq.
Re: .528 purple shaft street-able? [Re: 72Challenger] #1385351
02/12/13 12:06 PM
02/12/13 12:06 PM
fullmetaljacket Offline
That cam likes a little squeeze on the compression. When I ran it, I had maybe 9.8 -10.0 compression at best and it ran out the door at low 12's driving it every where and to and from the track. At the time my ride was weighing in at 3500 Lbs.
Put the same stick into a friends 3900 lb car and it went 12.90's with out good tuning.
He was lazy behind the wheel as well.
Re: .528 purple shaft street-able? [Re: fullmetaljacket] #1385352
02/12/13 01:19 PM
02/12/13 01:19 PM
sweden
carter Offline
carter  Offline
sweden
I planning to run the MPīs 0.528 in my 440.I have Eddy RPM`s heads... Can somone recommend a valve spring for this setup?
Tnx
Re: .528 purple shaft street-able? [Re: carter] #1385353
02/12/13 01:20 PM
02/12/13 01:20 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Tnx
The springs that come on the E-heads will be fine.
Re: .528 purple shaft street-able? [Re: GTXbound] #1385354
02/12/13 01:26 PM
02/12/13 01:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
the rods are heavy , the mistake mopar made was not upping the bolt size to 7/16 for the LY 3/8 . Just make sure they have a GOOD set of bolts in them , ARP Wavelocks ...
Re: .528 purple shaft street-able? [Re: Sweet5ltr] #1385355
02/12/13 01:49 PM
02/12/13 01:49 PM
Minnesota
72blubird Offline
72blubird  Offline
Minnesota
The .528 seems to be a very strong cam. I guess my thought was running a four speed like you I could go with a bit more cam. Not sure if I left something or not, but it seems strong and it has a great sound at idle. I am also running it through manifolds Will have to wait until this summer to get it at the track for the first time and see how it performs. The one I chose was an off the shelf comp cams extreme energy hydraulic flat tappet. Rpm range 2,500-6,200/Advertised Duration .285 int .297 ex/Dur @.050; .241 in .247 ex/ Lift .545 in. 545 ex with 1.5 rockers. Lobe Separation Angle 110.
You are getting good advice from experts I am not one. Just thought I would offer my choice on a mostly street driven car that is a blast to drive.
What was I thinking....
Re: .528 purple shaft street-able? [Re: 72blubird] #1385356
02/12/13 04:06 PM
02/12/13 04:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
All this .528 talk has me thinking about running one in a stockish 383 with a 4 speed and advancing it 4 degrees , the car is question has 3.23 gears though .
the 02 MP catalog has it listed in it's cam recommendation chart in a 383 with a 4 spd ...
Re: .528 purple shaft street-able? [Re: JohnRR] #1385357
02/12/13 09:01 PM
02/12/13 09:01 PM
By the way, I ran mine straight up with an old measly TM7 manifold. Low 12's after all tuning was exhausted in a 3500 Lb. B-body.
Re: .528 purple shaft street-able? [Re: fullmetaljacket] #1385358
02/12/13 11:51 PM
02/12/13 11:51 PM
Frederick, MD
moparguy1967 Offline
Frederick, MD
http://www.youtube.com/watch?v=n5NweB9PyhU
Just a little video of my car with the 284/528 solid cam.
My 446 was built by Andy Jensen. It has forged flat top piston, scat H-beam rods, and forged crank. The compression ratio is just over 10 to 1. The heads are 906 cut for larger SS valves and the bowls are blended. Its topped off with a RPM Performer intake and Pro Systems 4150 carb. The cam was installed straight up, but Andy did tighten up the lash. He dyno'd the engine with headers and it made 520 HP and 560 lbs torque. I picked this cam because of an article I had read a few years back and it made good power for a street car. I run HP manifolds, not header in my car, so Im sure I loss a little power.
Hope this helps.
http://www.youtube.com/watch?v=OOIgewNRCxk
dyno pull
Re: .528 purple shaft street-able? [Re: Mr.Yuck] #1385359
02/13/13 01:05 PM
02/13/13 01:05 PM
sweden
carter Offline
carter  Offline
sweden
Tnx
Mr.Yuck
Re: .528 purple shaft street-able? [Re: AndyF] #1385360
02/13/13 04:35 PM
02/13/13 04:35 PM
NC
440Jim Offline
440Jim  Offline
NC
The .528 works great with HP manifolds.
If you are going to run factory cast iron exhaust manifolds, then the 0.528" is a good choice. If you are running headers with the heads, CR, etc. of that engine... then I would move up to the MP 0.557" or something similar.
Re: .528 purple shaft street-able? [Re: JohnRR] #1385361
02/13/13 09:41 PM
02/13/13 09:41 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
What he said. I've been following this thread. Going to build a stockish 383 with a couple upgrades. 4-speed as well. Initially it will be a 3.23, but will probably go to a 3.55 or even a 3.91 once I get some miles on it.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Page 2 of 3 1 2 3
