Page 1 of 3 1 2 3
.528 purple shaft street-able? #1385322
02/11/13 12:21 AM
02/11/13 12:21 AM
NY VA USA
GTXbound Offline OP
GTXbound  Offline OP
NY VA USA
Hey Guys
Just wanted some advice on the .528 purple shaft
would you guys run it straight up or advance it 4 degrees ?
Projected spec's looking for 500+ HP
comp 10:25 need's to live on pump gas.
Edelbrock aluminum RPM's 82cc
Edelbrock rpm intake gasket matched
Its going in a 4 speed 70 Dart .
Rear is 4:10's currently but i have a pumkin with 3:91's and 28 X 10.5 tire
Re: .528 purple shaft street-able? [Re: GTXbound] #1385323
02/11/13 12:32 AM
02/11/13 12:32 AM
fullmetaljacket Offline
Very.
Re: .528 purple shaft street-able? [Re: fullmetaljacket] #1385324
02/11/13 01:00 AM
02/11/13 01:00 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
OH Yeah
Re: .528 purple shaft street-able? [Re: scatpacktom] #1385325
02/11/13 01:04 AM
02/11/13 01:04 AM
NY VA USA
GTXbound Offline OP
GTXbound  Offline OP
NY VA USA
The cam degreed straight up or run it 4 degrees advanced?
what did you guys do?
Re: .528 purple shaft street-able? [Re: GTXbound] #1385326
02/11/13 01:26 AM
02/11/13 01:26 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
4 advanced. its plenty streetable and i believe even has enough vacuum for power brakes. i run the .557 purple cam and its streetable with a little choppier idle. what engine are you putting it in?
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: .528 purple shaft street-able? [Re: Jerry] #1385327
02/11/13 02:29 AM
02/11/13 02:29 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
PLENTY streetable. Maybe TOO streetable. If you don't have it yet, I'd look to the .557! I run a similar 451 motor with an Engle mechanical cam thats similar in duration with a little more aggressive profile than the .557 and the same gears.... A downright street bully!, and still plenty streetable.
Re: .528 purple shaft street-able? [Re: StealthWedge67] #1385328
02/11/13 07:45 AM
02/11/13 07:45 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Advance it 2-4 degrees. It's a great street cam with tremendous low end torque. I had one in my truck in the last 440 that was in it and before I had to put a bar in. On launch my chassis was twisting so hard the drivers door was popping open.Dave
Re: .528 purple shaft street-able? [Re: quickd100] #1385329
02/11/13 10:02 AM
02/11/13 10:02 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yes, it's a good cam. I found that if you tighten the lash a hair it runs even better. I went from the recommended .032/.028 to .028/.024. Seemed to pull harder and longer.
Coming soon!!!!
Re: .528 purple shaft street-able? [Re: Mr.Yuck] #1385330
02/11/13 12:53 PM
02/11/13 12:53 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i concurr i think the lash specs are too loose. especially if your running aluminum heads as they grow a few thousandths as well.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: .528 purple shaft street-able? [Re: GTXbound] #1385331
02/11/13 12:59 PM
02/11/13 12:59 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Hey Guys
Why not, my .680-.660 solid roller w/275-280 dur. @ .050 has been driven to hell and back for years and is plenty streetable. I`ve been "over camming" for years and I just keep going faster.............enjoy.
Re: .528 purple shaft street-able? [Re: Thumperdart] #1385332
02/11/13 01:55 PM
02/11/13 01:55 PM
Norwalk Ohio
cudasteve68 Offline
cudasteve68  Offline
Norwalk Ohio
Hey Guys
I ran a 528 in my '71 drove it almost everyday during the summer to work. 3:91 & 4:10 gears on a 14 tire. 904 & 3800 stall. Car ran 12.0's That 528 has lumpy at all. Perfect for a "sleeper"
Re: .528 purple shaft street-able? [Re: cudasteve68] #1385333
02/11/13 02:20 PM
02/11/13 02:20 PM
dogdays Offline
dogdays  Offline
AndyF sure liked it, especially through stock exhaust manifolds.
R.
Re: .528 purple shaft street-able? [Re: dogdays] #1385334
02/11/13 02:45 PM
02/11/13 02:45 PM
AndyF Online content
AndyF  Online Content
The .528 works great with HP manifolds. Worked better than any other cam that I tested. I did tons of dyno testing and never found anything that worked better than the .528 cam.
Re: .528 purple shaft street-able? [Re: AndyF] #1385335
02/11/13 05:02 PM
02/11/13 05:02 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Refresh my memory - did you try any roller cams in that engine? I am slowly working on a 511 low deck that will have manifolds so this thread has my attention.
Re: .528 purple shaft street-able? [Re: Jeremiah] #1385336
02/11/13 07:07 PM
02/11/13 07:07 PM
NY VA USA
GTXbound Offline OP
GTXbound  Offline OP
NY VA USA
I guess i'll get this motor ready to go as follows
zero decked block
2355 pitons & 6 pack rods
.040 cometic head gaskets
Edelbrock RPM's milled to 78cc & gasket matched
Compression works out to about 10.6
.528 Purple shaft 4 degrees advance it the ptv checks out.
But i got another question .......
How will advancing the cam 4 degrees affect the compression (now is 10.6) for pump gas on the street ????
Re: .528 purple shaft street-able? [Re: GTXbound] #1385337
02/11/13 07:49 PM
02/11/13 07:49 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Its a very good cam and works well for what it is. But I had a buddy who was unhappy with it because he said it idled and sounded to smooth ! He wanted somthing much lumpier. But I told him who cares how wicked it sounds it made great power for his combo. Ron
Re: .528 purple shaft street-able? [Re: Jeremiah] #1385338
02/11/13 09:24 PM
02/11/13 09:24 PM
I did a bunch of dyno testing with other flat tappet cams. Mostly solid flat tappet but also a hyd flat tappet. A couple of years later I did another stroker motor which was slightly bigger and with better heads. I used a hyd roller in the second motor but it didn't really make a lot more power than the .528 flat tappet.
The FAST guys have spent a lot more time and money on this subject than me. I'm sure that Dwayne could find a cam that would make more power than the .528 these days and it would probably be a roller cam.
Back when I did my testing I worked with a couple of different cam mfgs and they sent me their best designs. So it wasn't like I was just picking cams out of the catalog and testing them. I ran exactly what the engineers told me to run and nothing worked better than the .528 cam.
Re: .528 purple shaft street-able? [Re: GTXbound] #1385339
02/11/13 09:30 PM
02/11/13 09:30 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
It's a very good cam.I really wish I hadn't sold the one I had years ago.Anyway,we ran it in a very mild 440,9.0 compression,452 heads,and the usual bolt ons.Didn't even degree it in and it ran 11.60's all day in the 71 Demon I have now.
Nautilus Racing-
Re: .528 purple shaft street-able? [Re: AndyF] #1385340
02/11/13 11:02 PM
02/11/13 11:02 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Very good info. Thank you Andy. I am looking for a low maintenance combination that will idle like a stocker with the A/C on. It sounds like the .528 could be a very good place to save a little coin too. Adding a hydraulic roller adds a significant amount to the budget once you price out lifters, a roller cam that can drive a mechanical fuel pump, etc.
Re: .528 purple shaft street-able? [Re: Jeremiah] #1385341
02/11/13 11:31 PM
02/11/13 11:31 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Andy,
Did you try thr .557 too thru the manifolds? How did it compare to the ,528???
Page 1 of 3 1 2 3
