Re: can an old mopar be built 2 outrun this on a racecourse
[Re: Supercuda]
#1384508
02/10/13 10:13 PM
02/10/13 10:13 PM
Posts: 40 new jersey browns mills
animal8324
Put a 90 yr old with clacoma (sp?) Behind the whell of the stang and it'll be buried in the forst corner.
Put a 90 year old with glaucoma behind the wheel of the Stang and it'll be buried in the first corner.
Translation provided free of charge.
[Re: domingo]
#1384511
02/10/13 11:52 PM
02/10/13 11:52 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
for that kind money you could just buy a new nissan GTR that would spank that mustang
if I wanted to beat it cheaper, probably a modified EVO or STI should do it for less than half that
all the modified mustangs that come out to autox never seem to be in the top 10, more like around the middle of the pack - have never been impressed with them handling wise...
as for our mopars, that is my goal! don't know if it'll happen
the owner of that mustang drives a 2012 gtr on the street!
here is his car....my original 440.6 4 speed shaker cuda beside it.
sweet! probably the car I'd buy when I retire...30 years from now, by then i could probably afford it lol
[Re: Jim_Lusk]
#1384515
02/11/13 03:02 AM
02/11/13 03:02 AM
Posts: 494 IL
EchoSixMike
IL
[Re: domingo]
#1384516
02/11/13 10:10 AM
02/11/13 10:10 AM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
The mustang continental spec tire is a 275/35/18. I don't know how much hp they run in that series, but I doubt it's over 600.
To beat him: Put 335/30/18's on all 4 corners get the center of gravity as low as possible while still maintaining a minimum travel Ensure your suspension maintains a good contact patch in the corners Beat his weight to power ratio across the rpm band you'll be working in Upgrade your braking system to ensure no fade at threshold braking lap after lap
I have a similar yet lesser goal. Keep up with a C6 Z06 & a porsche GT3. I'll be running 275/35/18's on all 4, factory suspension geometry, a 3G Hemi, and 14x1.25 with viper calipers on all 4. I should be running in a few weeks and racing in a few months, so that should give you a baseline on what to improve on. Shoot, Tim's valiant and Peter's dart are both good cars to base a build off of with your goal in mind.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: domingo]
#1384517
02/11/13 01:46 PM
02/11/13 01:46 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=11545
what would it take?
One of these.... http://glennbunch.com/ inside is the 40 year history of what it takes to make one of these cars a world beater on an international racing stage. It ain't easy, nor cheap and there are lots of pitfalls along the way.
Here is a comparable GTO doing the same; http://gtoroadracer.com/
Again, not easy or cheap, and to be honest, there is not much of the original cars that remain in either case. However, with Dodge getting out of Nascar, I'm sure there are a lot of W9/P5 race engines out there that can be had cheap. Reskin an older cup chassis with an old PLymouth and boom, instant classic car with high speed capability ala Ray Evernham's recent '64 Plymouth build.
Neat thing about doing something like this with a Charger or Road Runner is that they already have coke bottle styling to contain the wide rubber. No flares required.
[Re: PHJ426]
#1384518
02/11/13 02:18 PM
02/11/13 02:18 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Someone said they wanted to merge two Hayabusa engines together.....check it out
The Hayabusa V8
http://www.youtube.com/watch?v=5YAFMZyBPI4
That's the engine in the Atom I posted too... Neat stuff....
Agree that a cup car reskinned would be a good start. Trouble is, they only make a couple road course cars for many speedway versions, and Domingo didn't say what the course is like. If it's more like an autocross, a cup car is going to be like a bull in a china shop...
[Re: RodStRace]
#1384519
02/11/13 05:49 PM
02/11/13 05:49 PM
TC@HP2
Pikes Peak Country
It depends. The basic chassis may be built pretty symetrically since Nascar imposes rules on how much offset and bias can be built into the chassis. Changing control arms and spring rates to balance the car out for right and left turns should be a simple bolt on effort if the car is a symetrical design. Actually a Nationwide or Late Model series car may also be an alternativesince they are built on slightly shorter wheelbases to different requirement levels. For that matter, you could probably have Racefab, Alston, BMR, Howe or any other supplier put one together specifically for your requirements. Heck, Howe even offers a TA2, GTA, and GT2 chassis package if you are so inclined: http://www.howeracing.com/Adobe/HoweTA20811.pdf with a base price tag of $72.5k for an LS3. Since they will do any engine and body combo, all it takes is some more money for a change to a Hemi and a Challenger body and you should come in around the same price tag as the Mustang listed above. In the oval track chassis, they do offer symetrical or offset chassis builds in various stages of completion. Prices start at $2700 and go up from there. http://www.howeracing.com/p-7331-perimeter.aspxIf you really want to keep it mopar based and do it all yourself, there are enough reproduction parts out there that you can buy all the core pieces from an E body to reproduce the old Mopar Kit car program chassis for around $3500 and then add all the associated tubing for the cage and other structure for a few hundred more. After that, you can skin it in darn near any body you want. Run t-bars and leafs, XV L2, AlterK, or whatever suspension suits your fancy.
[Re: PHJ426]
#1384521
02/11/13 07:33 PM
02/11/13 07:33 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
Perfect! I was about to pull the trigger on the Mustang but I will get one of those Imperials and a torch instead! You just save me $134,000...
A new iron curtain drawn across the 49th parallel
[Re: amxautox]
#1384523
02/11/13 07:41 PM
02/11/13 07:41 PM
67autocross
Manitoba Canada
Well I was riding my dirt bike yesterday.....
