Re: What do you use as a sealant for fuel fittings? [Re: RapidRobert] #138460
10/19/08 04:53 PM
10/19/08 04:53 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
AN fittings don't need anything either do they?
the flare does the sealing but I clean the aluminum threads with brake clean then a light dab of 30 wt eng oil because the alum threads are delicate.
I use a light dab anti-seize compound on the threads.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: What do you use as a sealant for fuel fittings? [Re: HealthServices] #138461
10/19/08 09:13 PM
10/19/08 09:13 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Me too.
