Are all 8 lug rims the same pattern? #1383468
02/08/13 02:06 AM
02/08/13 02:06 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I want to install bigger wheels and tires on the Power Wagon. I will be looking for USED stuff.
Are all 8 lug wheels use the same bolt circle whether it is a Dodge, Ford or a Chevy? I'd use the wheels that I have but they are narrow and ugly as a mud fence.
Re: Are all 8 lug rims the same pattern? [Re: Kern Dog] #1383469
02/08/13 02:49 AM
02/08/13 02:49 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
It looks like from what I have found, Dodge 8 lug wheels share the same 6 1/2" bolt circle as the Chevy trucks do. The Ford pattern is slightly larger.
Re: Are all 8 lug rims the same pattern? [Re: Kern Dog] #1383470
02/08/13 02:57 AM
02/08/13 02:57 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Untill the late 90s or early 2000s. 8X6.5 is the pattern. Aftermarket wheels are usually universal requiring different lugnuts for installation.. ..
I am truckless..
Re: Are all 8 lug rims the same pattern? [Re: Kern Dog] #1383471
02/08/13 02:59 AM
02/08/13 02:59 AM
Ca
76440 Offline
76440  Offline
Ca
Ford 8 lug wheels of the same vintage will bolt on. Chevy wheels will not fit over the hub.
They all share the same bolt pattern but lug centric versus hub centric.
Later fords around 98ish? went to a different metric bolt pattern . Offset changed on the 94+ Dodges..
Avoid 16.5 wheels as tires are getting harder to find.
If that truck has the stock full-time dana 44 wheel bearing for 75...convert it with 80-93 knuckles or swap in a dana 60 front before going to bigger tires.
Re: Are all 8 lug rims the same pattern? [Re: 76440] #1383472
02/08/13 03:27 AM
02/08/13 03:27 AM
San Jose, Ca.
dhkennedy Offline
dhkennedy  Offline
San Jose, Ca.
Ford actually has used 3 different 8 lug patterns, so thy are a crapshoot for fit. Most steel aftermarket 8x6.5 patern will fit with the stock lugnuts and clear the axlestubs. I have run a 15x8" with 0 offset and 35's on a 79 RC with 5" lift with issues.It had Dana 60's Front and Rear FF from a 1 ton single wheel.There caliper and drums had to be milled slightly for wheel clearance.The 35's were not always avable in 16's back then.
Re: Are all 8 lug rims the same pattern? [Re: dhkennedy] #1383473
02/08/13 04:17 AM
02/08/13 04:17 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
16.5s are available but very limited on sizes unless your lifting it for pudding than Super swamper has Several.
The 94 up wheels for dodge have a different offset and can cause tires to rub. Same with ford rims offset is diff. I had ford rims with 235/85 16s and close to lock the tires rubbed
Re: Are all 8 lug rims the same pattern? [Re: 76dodgeboy] #1383474
02/08/13 07:10 PM
02/08/13 07:10 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have 94 Dodge rims on my 69 truck, all I had to get were the different lugnuts as the 94 nuts are 9/16" and the 69's were 1/2". Just use Dodge wheels and everything is good.
JB Rhinehart, Realist
A-Body's RULE!
Re: Are all 8 lug rims the same pattern? [Re: Rhinodart] #1383475
02/08/13 10:26 PM
02/08/13 10:26 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
in 1999 ford went to a metric pattern that only fits newer than 1999 fords---up until that date all 8 lug 3/4 wheels were the same (6.5) but with an alert that GM used a smaller index hole (hub) than dodge/ford/IH---so if you had a stock steel GM wheel it wouldnt go over the hub of your dodge or ford---however all aftermarket wheels used the larger index hole so anyone could mount up....bob
Re: Are all 8 lug rims the same pattern? [Re: savoy64] #1383476
02/09/13 01:50 AM
02/09/13 01:50 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Thanks everyone. I'm going junkyardin' this weekend and the info helps a bunch!
