Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!!
[Re: 72Swinger]
#1382939
04/05/13 08:13 PM
04/05/13 08:13 PM
Posts: 4,255 Canada
WO23Coronet
Canada
I think you have some serious Engine Masters stuff here Mike.
Seriously, how would this engine do? It seems pretty good, but how well (and what class) would this do? I think it would do fantastic
[Re: sixpackgut]
#1382940
04/05/13 10:05 PM
04/05/13 10:05 PM
Posts: 3,871 Smyrna, South Carolina
STEFF
what are the details on timing?
Best timing is as follows: 24 degrees from idle to 3000rpm, then drop to 20 degrees the rest of the way out.
It was a toss up between messing with the idle air bleeds and just adding timing to clean up the low rpm curve.
Adding timing was easier and worked great.
[Re: hemidup]
#1382941
04/05/13 10:30 PM
04/05/13 10:30 PM
STEFF
These numbers are just amazing. I race a lot with the LSx crowd. I haven't seen any of them making this kind of power short of a big cube LSx motor and aftermarket heads and far bigger cam. Speaking of cams, could you post the specs on it?
Tom, Steff had LSM grind him a custom camshaft which laid down at 7000 rpm. More importantly I'd like to know what improvements Steff made to the chamber of his 6.1 heads??? Port velocity vs cfm flow #'s is number 1.
Jerry, I couldn't tell you anything about the chamber other than after the engine blowed up at MMW 2011, Jeff welded the chambers up to fix the damage, eliminated those recessed pads the 6.1's had. The chamber now looks like the Eagles and Apaches. He installed new seats, guides, re-CNC'd the chambers due to all the welding, installed bigger 2.100 and 1.62 S/S valves. I then had the heads cut to get chambers to 67cc's. Before cutting, they were 73cc's. I don't even think they were re-flowed with the new larger valves. I guess they are what they are.
Cam from LSM was totally their call. I told them what characteristics etc.. I wanted and they made what they thought would do it.
244/250, 112 in at 108, .400 lobe.
[Re: Vintage]
#1382943
04/05/13 11:27 PM
04/05/13 11:27 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
holy smokes....can you image what bolting on a supercharger would do....? im still looking at all the progressives on your sheet... looks pretty good...should show up on the track..IMHO..
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: cheapstreetdustr]
#1382944
04/06/13 01:15 AM
04/06/13 01:15 AM
Posts: 1,845 Tampa
DusterDave
Tampa
STEFF, scfm at max HP? Should be on the dyno printout.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: STEFF]
#1382946
04/06/13 11:23 PM
04/06/13 11:23 PM
Posts: 833 MN
hemidup
MN
Sweet info Steff Kinda figured your cam was in the 240ish range.
After welding up my quench pads on my 5.7 heads and using Ferrea 2.08"/1.62" valves I ended up with a 82cc chamber. I only picked up 2cc from the stock chamber that use 2.00"/1.55" valves, however reduced my quench by .050".
Jerry Williams.
[Re: Jerry]
#1382949
04/08/13 10:18 PM
04/08/13 10:18 PM
STEFF
Jerry,
I don't like the idea of flipping the shafts for the reason Jerry explained, the hole on the bottom of the shaft provides the oil bearing for the rocker where the load is on the pivot. And then the two holes for lifter feed should stay where they need to be, which coincides with the feed in the rocker arm and it's pivot rotation. I don't really want to restrict the oil to the lifters in fear of them not staying pumped. Unless you shim them, then it most likely dont matter. Maybe tap the oil feed holes in the block. and insert a couple set screws with small holes in them, if you want to restrict the oil to the heads.
Personally, the oil in the heads don't bother me. My oil pan holds 12 qts and then the filter and lines. I will never run out of oil for the lower end if too much ends up in the heads. When I did take the valve covers off to inspect the valvetrain during the dyno sessions, there wasn't much oil resting in the heads. The drains appear to be very efficient.
[Re: Moparmal]
#1382951
04/09/13 09:45 AM
04/09/13 09:45 AM
Posts: 226 lino lakes,MN
onebaddakota
lino lakes,MN
So now we have data on 3 recent gen 3 builds: Steff,340 rick, and Mopar Muscle. All three of them are north of 700HP. All run on pump gas. It would be interesting to compare the three. It seems like Steff's hemi had the best induction and compression of the three, but the smallest cubes. I'm not sure on the cams. IMO, I think these motors are going to knock the LS motors off the pedestal as the finest factory based push rod performance motor ever produced. I also think there are going to be some real bargains on 340,360 and 440 stuff.
10.56 at 125.6, with a 1.43 60 ft.
E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
[Re: onebaddakota]
#1382952
04/09/13 01:37 PM
04/09/13 01:37 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
When I sold my B/RB stuff for Hemi, I felt like I was getting away with murder. They thought I was crazy for getting rid of old stuff, and I thought they were crazy for taking it.
[Re: Moparmal]
#1382956
04/13/13 10:29 PM
04/13/13 10:29 PM
STEFF
Steff....are you saying you set the timing at 24 locked in from idle to 3000?
Any cooling or cranking issues with that much timing at static?
Yes, timing 24, idle to 3000. Nope, no cranking or cooling issues yet.
[Re: STEFF]
#1382957
04/14/13 01:41 AM
04/14/13 01:41 AM
Posts: 5,485 SoCal
Brian Hafliger
SoCal
Very good power! I hate the front cover of these Hemi's and would love to see somebody cast a new cover just for a water pump and an alternator with the option of a power steering pump mount.
I just hope our build makes decent power! Thanks for sharing Steff!! Brian
Brian Hafliger
[Re: Brian Hafliger]
#1382958
04/14/13 10:31 AM
04/14/13 10:31 AM
STEFF
My 6.1 motor used the stock cover. I took a sawzall and cutoff wheels to it, hacking all that B.S. off. It's a pain, but I guess that's how it goes.
