Re: My 6.4 Gen 3 Hemi - Assembly In Process!!!!!
[Re: 340RICK]
#1382839
02/16/13 05:32 PM
02/16/13 05:32 PM
Posts: 3,871 Smyrna, South Carolina
STEFF
Looks good Steff
what are you using that big fitting where I think the oil cooler lines plumb to?
That's where my Peterson R4 Belt Driven Oil Pump is going to feed the oil into the motor.
[Re: WO23Coronet]
#1382840
02/17/13 10:23 AM
02/17/13 10:23 AM
STEFF
Do up have a picture of the G4 and G3 cam side by side so we can get a visual on the differences? Or at least a pick of the G4 cam so I can compare it to my 6.1 cam I have here?
Gen 3 Cam vs. Gen 4 VCT Cam Pics
[Re: STEFF]
#1382844
02/27/13 02:50 AM
02/27/13 02:50 AM
Posts: 833 MN
hemidup
MN
Very nice STEFF. What are you using for a front cover?
Jerry Williams.
[Re: hemidup]
#1382845
02/27/13 03:30 AM
02/27/13 03:30 AM
STEFF
Thanx Jerry! Once I get the motor plate finished, I'm going to look at making some kind of debris cover to protect the belt drive, as this is a street motor.
On a side note, I need some rocker tie bar hold downs and collars. Just get ahold of Sharadon?
[Re: STEFF]
#1382846
02/27/13 10:24 AM
02/27/13 10:24 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Got the Oil Pan & Windage Tray on. I built this Oil Pan to replace the Milodon Oil Pan I threw away by mistake. Yes, I'm an idiot!! This Oil Pan was a learning experience, as I wanted to learn how to Tig Weld Aluminum. So, I fabbed this up. It isn't pretty, but it doesn't leak!!
A few inside pics....
-16AN Fitting for Pickup to feed Oil to Petersen R4 Belt Driven Oil Pump
STEFF is that a factory pan that you fab a bottom for it? Nice work and it does leak
[Re: STEFF]
#1382856
02/27/13 10:59 PM
02/27/13 10:59 PM
MattW
Ontario Canada
STEFF You can excusse my ignorance here but where does the oil go once it hits the cam. The VCT is contoled by oil pressure right? I'm trying to figure out how the VCT works.
[Re: MattW]
#1382857
02/27/13 11:20 PM
02/27/13 11:20 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Steff, your reward is coming. Keep it up. Are you still using our Firecore Stage2 Hemi Coils? Keeping them in the stock position? Just wondering. The coils are really catching on , now. Thank you. Our Stage3 Extreme Coils are slowly coming tomgether. Thanks for trusting us. You and Muscle Motors were the first. Thanks. See you soon. ...Lavander...lol..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: sunroofgtx]
#1382858
02/27/13 11:52 PM
02/27/13 11:52 PM
STEFF
...Lavander...lol..
Hey Rick!! Absolutely, I'm still using your Coils!! I was considering getting new valve covers that require relocated coils and your wires, but am not sure yet. I'm a Firecore Guy, don't forget it!!
