Dennis, My door bar is a straight shot from the main hoop to the front down bar just on the inside of the rocker on an outrigger from the front "frame" rail.
This straight piece of tube is about 2", 2-1/2" away from the door in the area of my upper arm/ shoulder.
Mr. P-body suggested I need to put in a tube with a bend in it to make clearance. The seat seems wide but is comfortable and I fit well in it. I am not a large guy but I rather be comfortable.
after further adjusting positions, a bent side bar is the way I will go. I wish I hadnt fully welded the straight one in. live and learn
![](/ubbthreads/images/graemlins/blush.gif)
