Re: Need the link to the latest Gen3 Hemi that made 719hp
[Re: Dragula]
#1381826
02/05/13 12:41 AM
02/05/13 12:41 AM
Posts: 3,839 Central Missouri Fort Leonard...
mopar65
are you talking about the one Dave young built in the mopar muscle mag?
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: mopar65]
#1381827
02/05/13 12:49 AM
02/05/13 12:49 AM
Posts: 12,422 Taxes & Virus's R-US, NY
Dragula
It was in one of the Mopar Mags, and it looked like it was built by Indy, I thought. I did not have time to read it...But I have time now.
[Re: Dragula]
#1381828
02/05/13 01:26 AM
02/05/13 01:26 AM
mopar65
yes you are right it was Indy cylinder head and Dave young build.the mag is Volume 26 number 04 April 2013 page 28 ( CAN YOU HEMI NOW? PART II
so far the mopar muscle web site sucks for trying to find past tech stuff.
support our troops
[Re: mopar65]
#1381829
02/05/13 08:55 AM
02/05/13 08:55 AM
The engine was pretty straight forward. It was a 6.1 block, .030 over, stroked to 426 roughly, 10.7:1 C.R, CNC ported 6.4 apache heads, fairly conservative cam, drag pack intake and a 950 HP carb. I was truly impressed with the numbers it made.
[Re: ]
#1381830
02/05/13 01:46 PM
02/05/13 01:46 PM
Dragula
Thought I saw 10.85:1 compression and didn't have time to catch head flow, cam specs, and cubes...So it was 426 cubes?
I think I gots to have me one..
[Re: Dragula]
#1381832
02/05/13 02:34 PM
02/05/13 02:34 PM
I think your right about the compression, I dont know why I was thinking 10.7, but still that is a very conservative ratio. I believe the heads had the Indy wind jammer CNC port program and they flowed 370 CFM at peak, dont remember the lift.
[Re: AlexP]
#1381835
02/05/13 05:01 PM
02/05/13 05:01 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I need to find this article.
Mopar Muscle April edition.
[Re: sixpackgut]
#1381836
02/05/13 05:02 PM
02/05/13 05:02 PM
MattW
Ontario Canada
wow, maybe I should get mine running to find out what mine makes
Yes you do!!! ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: sixpackgut]
#1381840
02/05/13 06:48 PM
02/05/13 06:48 PM
Dragula
I also need the link and cannot find it. I want the facts...not inaccurate hearsay.
...And I can always use another Hemi! As much as the newer wedge technology impress's me, they are still just a wedge. And soon, OEM blocks and such won't be that easy to find. Time to switch gears.
[Re: Dragula]
#1381841
02/05/13 07:02 PM
02/05/13 07:02 PM
Posts: 833 MN
hemidup
MN
6.1 block Bore 4.090 Callies Comstar forged crank 4.050 Callies Comstar H beam rods 6.125 Diamond forged flat-top pistons 10.85 final compression Apache heads CNC'd by Indy cyl Comp Cams 114 lobe separation .584 intake lift .579 exhaust lift 242 intake and 248 degrees duration at .050 lift Drag Pak Intake Holley 950-cfm Ultra HP carb MSD Hemi-6 ignition TTI Headers 1 7/8 in. primary stepped to 2 in. Milodon pan and pick-up Melling oil pump
Jerry Williams.
