Re: Holley question - Idle
[Re: 68Bullit]
#138200
11/19/08 09:23 PM
11/19/08 09:23 PM
whatever you dial back the light to, thats what the zero mark on the balancer is.
[Re: 68Bullit]
#138202
11/19/08 09:46 PM
11/19/08 09:46 PM
say yo want to check or set for 33 degrees advance. dial the light until it reads 33 btdc. look at the balancer and when the 0 line on the balncer lines up with the 0 mark on the timing chain cover, you are at 33 degrees advance.
if the 10 btdc mark on the balancer lines up with the 0 mark on the cover, youre at 43 degrees advance
[Re: 68Bullit]
#138203
11/19/08 10:04 PM
11/19/08 10:04 PM
Posts: 531 Virginia
JimG
Virginia
Bullit:
The timing seems about right. Sorry you had to go through all that to find out, but it had to be done.
You're sure you can't lean the idle out with the mixture screws, right? First, check that again. Just as a test, screw them in until the engine starts to stumble, then back them out ONLY until it smooths out, and no more. This isn't the preferred way to set the idle mixture, but it will determine if perhaps the idle mixture screws can fix the problem. If it can, we can work on that. If not, we know to look elsewhere.
Next, go back to post 8 or 9. CKJ440 posted a good picture of where the throttle plates are supposed to be in relation to the transfer slots at idle. Pull the carb, be sure the choke is all the way off (so the fast idle is not set) and be sure the throttle plates only leave enough of the transfer slots exposed so that what you see looks like a square. If it looks like a rectangle, that could be part of the problem. Check the secondaries for the same problem. This is usually a problem on larger/more radically cammed engines, but like the timing, the basics must be covered first.
How old is this carb? Is it fairly new, or has it been sitting around for a long time? Is it time for a rebuild?
Is the carb clean? Spray some carb cleaner down all 4 idle air bleeds. If they're blocked it can cause a rich idle. If you don't know where they are, and if no one else comes to the rescue with a good picture (hint hint), I'll find one and post it tomorrow.
[Re: CokeBottleKid]
#138205
11/20/08 12:37 AM
11/20/08 12:37 AM
Posts: 571 Western NC
68Bullit
Western NC
AED does performance fuel systems of various kinds and also custom built carbs like mine. I think they are out of Virginia. http://www.aedperformance.comHere are some pictures of the carb. It might be 2 years old now. There is no choke. This carb is a 750 dp with 71 fronts and 82 rear. Engine is mild 360 with CompCam's 224@.050, box stock eddy heads, headers, 4.30 gears behind a FMVB 904 and 2500 stall. Could this be too much carb for my application???
[Re: 68Bullit]
#138206
11/20/08 08:36 AM
11/20/08 08:36 AM
Posts: 531 Virginia
JimG
Virginia
Coke Bottle Kid:
After I had him check a couple more basics, I was going to have him pull the metering blocks off and measure the idle feed restrictions, if he's comfortable doing that and if he has/can borrow some gauge pins or a set of numbered drill bits. Like you, I had wondered what AED did to modify that Holley carb, specifically the idle circuit.
Bullit:
In your first picture, as you're looking down into the top of the carb, the idle air bleeds are the things that look like miniature jets, and the ones for idle are the 4 outboard bleeds with larger orfices. I'm pleasantly surprised that your carb has screw in air bleeds. Can you read the numbers on them? If not pull one from the front and one from the back and tell me the number on it.
[Re: 68Bullit]
#138208
11/20/08 02:15 PM
11/20/08 02:15 PM
Posts: 531 Virginia
JimG
Virginia
The outer bleeds are 75 and the openings appear to be way larger than the inner ones. Couldn't see the reading on the inner bleeds but if I need to pull them to get a better look just let me know.. BTW, I've got more jets from where I've done some rejetting on this carb. Will these jets interchange with these bleeds? I've got 70's, 72's, and 73's I believe.
Wow! Your idle air bleeds are already large at .075". I was hoping they were around .060" so an increase to .070" or .075" would lean things out. Usually, if you're running an IAB larger than you've got, there's something else going on. You MIGHT lean it it out with an even larger air bleed, but again you might run up against a wall where increased bleed size won't help. No, main jets do not interchange with air bleeds.
You still need to look at the throttle plates vs. the transition slot and make sure that's OK. In fact, I looked at the link you posted to the AED site, and it was near the top of the "troubleshooting"(?) page.
You said the float level wasn't too high, but triple check it - primary and secondary.
Assuming the carb has a defective component (as opposed to just needing tuning) it's possible that the power valve has a tiny rupture in the diaphragm, and it's possible the gasket between the main body and the metering block is leaking and engine vacuum is sucking fuel from the accelerator pump passage. There are probably other possibilities that I'm not thinking of.
Why don't you call AED and see what they have to say. They have a nice looking website - perhaps they have nice customer service to match. Also, ask them if they think your idle feed restrictions are too large for an engine as mild as yours. See if they'll tell you what size the idle feed restrictions are, and if they increase them over the standard Holley size, which will probably be somewhere between .032" and .036". See if they'll log onto this site and read this discussion.
[Re: 68Bullit]
#138210
11/20/08 03:48 PM
11/20/08 03:48 PM
Posts: 531 Virginia
JimG
Virginia
Okay, I read the tuning page there again and if I'm reading it correctly, it states to check the throttle plate relationship if you have a lean condition causing a stumble and off-idle hesitation. Then it recommends checking the float levels and then the power valve for an excessive rich idle situation. I've been wondering if that could have anything to do with my power brakes not feeling exactly right??? How do I vacuum check the power valve?.....Thanks
Bullit:
While the throttle plate/T-slot thing will certainly cause an off-idle stumble, it can also cause pig-rich idle because the the mains start flowing at idle. Most people won't complain as long as the car seems to run right, no matter how bad the exhaust stinks (and they have to clean their back bumper every time they drive, and replace the plugs...) Kudos to you for being willing to go the extra mile.
As far as checking the power valve...if you have (or know anyone who has) a Mityvac vacuum pump, you can check the power valve with a suction cup that comes with the kit, and although it's a hit-and-miss proposition, it can be done. I have a power valve tester from Moroso that is used with the Mityvac that works much better.
Just what you wanted to hear...after buying a timing light only to find out that your timing was fine, now there's something else to buy. Do you have any car buddies who might at least have a Mityvac kit you could borrow?
[Re: JimG]
#138211
11/20/08 04:36 PM
11/20/08 04:36 PM
ive used the mityvac aspter to test PVs before. it can be tricky. make sure you have a good seal to the cup or it will look like you have a leaker. maybe use a little grease around the rim to seal it better when testing
[Re: CokeBottleKid]
#138216
11/21/08 08:16 AM
11/21/08 08:16 AM
set the mixture screws to get the best vacuum at idle. 4 does seem like a lot
