Re: increasing octane? [Re: Dakota_Don] #1381140
02/04/13 11:13 AM
02/04/13 11:13 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
If you are still running a catalytic converter in your exhaust, stick with Toluene to avoid poisoning it,
and to stay safely on the rich side of full throttle air to fuel ratio.
Since your are using AKI from the gas pumps,
use a Toluene AKI of approximately 103
More AKI, RON, and MON is the table here
http://en.wikipedia.org/wiki/Octane_rating
Toluene can be bought at paint stores,
but it has been dropped from many hardware and big box stores because chemically knowledgeable terrorists can use it to create explosives.
xylene with approximate AKI of 105
is more commonly sold now
but does not burn as cleanly as Toluene.
If you are going to try to get increased detonation resistance from alcohol,
go with a
water / alcohol spray system on the intake,
as it will also cool your air
and increase oxygen content,
and boost both effective AKI
plus net horsepower.
Engineering wise
it is an extreme waste
to mix alcohols with gasoline in the tank
when those alcohols could have been
mixed 50/50 with water
and sprayed into the intake only at full throttle.
Re: increasing octane? [Re: Pacnorthcuda] #1381141
02/04/13 12:28 PM
02/04/13 12:28 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
... I've always heard gas stations get their midgrade gas, by pulling from the lower and higher grade gas tanks. Don't know that for sure, but if so you could probably find a place that sells high octane race gas and buy a couple of gallons to mix in with what you have.
That sounds like a big 'wives tale' story.
Gas is very regulated and monitored. No way of blending high and low octane at the pump.
Incorrect. Mixing the two is exactly how mid-grade is concocted.
But not at the pump. They have separate tanks in the ground.
Re: increasing octane? [Re: Dakota_Don] #1381142
02/04/13 12:37 PM
02/04/13 12:37 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm running a snow performance water/meth injection kit. It takes 93 and turns it into 110 or better. They were about $259 I think they are more like $300 now. Pretty easy install. Here's the dyno sheet from a 426 Hemi.
my set-up http://www.youtube.com/watch?v=JYw2q7igDGs
Coming soon!!!!
Re: increasing octane? [Re: Dakota_Don] #1381143
02/04/13 02:55 PM
02/04/13 02:55 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
not sure about where you live, but here in my town i can drive to the airport, pull up to the pumps, and fill up with 100 octane av-gas. it's around six bucks a gallon, six fifty for full service. cheaper than race gas, that's around eight fifty a gallon.
Re: increasing octane? [Re: Golden-Arm] #1381144
02/04/13 03:01 PM
02/04/13 03:01 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
It's illegal for fuel vendors to sell avgas to people to use in cars so you need to either find someone who plays a little fast and loose with the rules or take a can to the airport to fill and tell them it's for an aircraft engine your testing or some story like that.
I read this on an aviation site the other day, perhaps the days of leaded racing fuel are numbered?
http://www.avweb.com/avwebbiz/news/Avgas_Safe_Leaded_Car_Gas_Gone_208088-1.html?type=pf
Re: increasing octane? [Re: Mastershake340] #1381145
02/04/13 03:11 PM
02/04/13 03:11 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
my local airport opens the gate for you, and directs you to the pumps. you pay at the pump or pay cash at the office. i understand the concept of road taxes, but here at my airport it's not a big deal i guess. i bought 10 gallons a couple of weeks ago, with my next door neighbor. we're regulars there. he runs it in his truck, and fills it up at the pump. i buy it by the 5 gallon can.
Re: increasing octane? [Re: Dakota_Don] #1381146
02/04/13 04:22 PM
02/04/13 04:22 PM
maryland
74yellowduster Offline
maryland
this will help if you are stuck with too high compression but have to run street gas
http://www.quickfueltechnology.com/carbu...50-cfm-e85.html
you might have to upgrade your fuel pump or any other parts of your fuel system that cant work with E85, it all depends
Re: increasing octane? [Re: Dodgeguy101] #1381147
02/04/13 04:29 PM
02/04/13 04:29 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
They only have 3 tanks in the ground, one for diesel fuel, one for 87 gas and one for 92 gas. The dispenser blends 60% 87 and 40% 92 to give you mid grade. Been that way forever, no one that I ever saw had a mid grade tank.
Re: increasing octane? [Re: Challenger 1] #1381148
02/04/13 05:39 PM
02/04/13 05:39 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Then you never delivered gas to the stores I did.
Re: increasing octane? [Re: Dakota_Don] #1381149
02/04/13 05:52 PM
02/04/13 05:52 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
I have read about the Kemco Octane Supreme stuff but have not tried it. It's supposed to contain TETRAETHYL LEAD.
Octane Supreme 130
Re: increasing octane? [Re: Dakota_Don] #1381150
02/04/13 08:10 PM
02/04/13 08:10 PM
jersey
Spaceman Spiff Offline
jersey
Hello, if i am running lets say 93 octane, how could i raise octane to 95 or 97? Moroso octane boost? E-85? Other? and if have 5 gal of 93 how much would i add?
Why do you need more than 93? Not sarcasm, just wondering how you came to that conclusion.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: increasing octane? [Re: 360view] #1381151
02/04/13 08:59 PM
02/04/13 08:59 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
No cats
Re: increasing octane? [Re: Dakota_Don] #1381152
02/04/13 09:54 PM
02/04/13 09:54 PM
Missouri
galen Online content
galen  Online Content
Missouri
I use this chart to blend to 98 for my street driven Belvedere at 12 to 1. I blend C16 with 91. You can use any race gas but I keep C16 on hand for the drag boat. http://www.motorsportsracingfuels.com/OctaneCalculator.html
Re: increasing octane? [Re: Ply72rr] #1381153
02/05/13 01:14 AM
02/05/13 01:14 AM
Florida, US
72ls5fla Offline
72ls5fla  Offline
Florida, US
Octane Supreme 130
I buy the stuff by the case. Works excellent - real TEL.
I keep two cases around all the time. Blend about 1.5 ounces to a gallon of 93 and you will end up with fuel around 96-97 octane.
The lead content is minimal - so it is like having low lead.
Plugs stay pretty clean and you don't get the bad fouling that happended back in the day.
Kemco went out of business but another copany purchased the rights and all the TEL they had stored.
You can get it at this website - cheapest I found.
http://www.wildbillscorvette.com/OctaneSupreme01.htm
bill
Got me a NEW Project
1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior.
Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
Re: increasing octane? [Re: 72ls5fla] #1381154
02/05/13 01:05 PM
02/05/13 01:05 PM
dogdays Offline
dogdays  Offline
Re: gas stations
My wife was buying gas at our local cheap gas station. She tried the regular nozzle, but it didn't seem to work. Station attendant said, sorry, we're out of regular. So she tried the mid-grade, didn't seem to work. Station attendant said, sorry, mid-grade is a 50/50 mix of regular and premium. We still have premium, so you could try that.
So she put in a few dollars worth of premium and went off to find a different station to fill her tank with the regular stuff because she saves money wherever she can.
So, at least at that cheap gas station, midgrade is a mix of regular and premium.
R.
Re: increasing octane? [Re: dogdays] #1381155
02/05/13 01:22 PM
02/05/13 01:22 PM
Cincinnati, Ohio
Cincinnati, Ohio
Re: gas stations
R.
It is at most stations, because a third tank for mid grade is very expensive to install, maintain and pay insurance on. Plus the the 2 fuels have a different spefic gravity and the 2 products can separate because of the different gravitys of each product.
I'm sure some stations have a separate tank for mid grade, but it is not the norm because of what I said above.
I own some of the largest and newest tanks in all of Cincinnati.
I buy semi trucks loads of gas and diesel everyday, there is no mid grade sold in the Cincinnati market wholesale. it's all blended at the stations by the dispensers, the pumps are inside the tanks pushing it to the dispensers.
