adding hardened seats, should I?
#1379690
02/01/13 11:23 AM
02/01/13 11:23 AM
RapidRobert
915 iron heads going on a DD 451. No strip action at all & limited hot rodding on the street. I could add the seats now if needed or proportion in a small amt (how much?) of race gas just enough for the lead or run em as is (going from 1.60 to 1.74). I do want longevity with this build. Your thoughts please. Thank you for your time.
Re: adding hardened seats, should I?
[Re: 5spdcuda]
#1379694
02/01/13 02:21 PM
02/01/13 02:21 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
If you're going to larger valves anyway and plan to run pump fuels on the street (steady rpm, light/part throttle) and using a decent valve spring I'd call them mandatory. You may not need them. But until you need them you won't know...lol.
[Re: RapidRobert]
#1379696
02/01/13 06:34 PM
02/01/13 06:34 PM
Posts: 602 N.E.Ohio
pacifica
N.E.Ohio
Not to disagree with the majority so far but - I could have but did not replace them on my build [stock hemi]. Its been on the road since 2006 and has plenty of miles and 1/4 mile passes on it. I only use pump gas 93 octane with no additives ever. I notice no difference between intial use till now. I'm not saying there isn't wear because I've not taken it apart to check, however "so far so good"
[Re: Baxter61]
#1379697
02/01/13 08:47 PM
02/01/13 08:47 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
you can either do it now or pull it apart in 6 months and do it then. i personally would rather do it now.
Come on now as thats ridiculous. I have never worried about hardened seats and have never burnt a valve or worn out a seat. Heck the old 440 that was in my 63 since 2006 is still going strong in my buddies Duster and they were just 906 heads that I installed larger valves in. There is nothing wrong with putting the hardened seats in if you feel strongly about it but most of us dont put enough miles on our muscle cars to worry about it that much. I am sure my old 440 has a good 15,000 miles on that eng.
[Re: 383man]
#1379703
02/02/13 12:42 AM
02/02/13 12:42 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
[Re: RapidRobert]
#1379704
02/02/13 12:44 AM
02/02/13 12:44 AM
Posts: 343 S.E.Mich
drew72
S.E.Mich
Do you feel lucky? Well do ya?
not sure . He said $3-4 ea for the seats themselves & $96 labor. I forgot to tell him that the seats are 1.60" & I'm going to 1.74" valves if that changes the labor amt needed
He is quoting you for cheap iron seats. See how much more for high nickel seats. He might charge more labor if he is going to bowl blend the new seats in. That has to be done either way but you might save a few bucks if you do that yourself. Of course that would mean that you have to pick the heads up, do the blending and return them. It's best to do that before the final machining on the seats.
[Re: drew72]
#1379705
02/02/13 01:38 AM
02/02/13 01:38 AM
RapidRobert
I was going to use the MP porting templates. Will they still work with the hardened seats?
[Re: RapidRobert]
#1379706
02/02/13 01:44 AM
02/02/13 01:44 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
As long as you dont hit them while porting. Id suggest tapeing them up real good in case you have that unplanned slip. When I did mine there was a small ledge that had to be removed to get the bowls blended..
I am truckless..
[Re: 383man]
#1379708
02/02/13 03:30 AM
02/02/13 03:30 AM
Posts: 2,495 Oregon City, OR
Baxter61
Oregon City, OR
Ive seen more than 1 set of heads sink valves 4 months to a year after having them done with .500ish lift hyd cams. It can and does happen, i prefer not to take the chance.
