Re: Can somene tell me what plant this hemi block is from?
[Re: cudaized]
#1378730
02/02/13 08:26 PM
02/02/13 08:26 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
If the VIN is RM23ROA166204, I'm pretty sure it matches a known Superbird.
Scott,
If you have contact with the owner, and he would like to find the block, e-mail me.
Ola
Must be a well known numbers matching car as NO-ONE will care to elaborate....Funny how some cars have posts about them and ends up in a dog pile about fake numbers matching,fake tag,fake broadcast sheet. This collector however must be special...
[Re: ScottSmith_Harms]
#1378732
02/03/13 01:54 AM
02/03/13 01:54 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
I'm sorry. Maybe I'm not seeing it but does the fifth character really look like it could be a 6 instead of an 8?
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
#1378735
02/03/13 01:31 PM
02/03/13 01:31 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
For all of the Negative Nancies chiming in, the car matching the VIN# I posted about IS NOT being represented as a numbers matching car.
"The car matching the VIN# I posted about IS NOT being represented as a numbers matching car."
Fixed!
That's all you had to say since you apparently knew of the car... Calling names only shows a lack of "real" intelligence. Sorry you are unable to converse with-out doing so.....
[Re: QuickBpBp]
#1378736
02/03/13 02:03 PM
02/03/13 02:03 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Quote: --------------------------------------------------------------------------------
Fixed!
"Fixed"?
Fixed what exactly?
#1378737
02/03/13 02:15 PM
02/03/13 02:15 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
Fixed!
"Fixed"?
Fixed what exactly?
It's hopeless if you can not understand what I wrote....
[Re: Alaskan_TA]
#1378740
02/03/13 05:29 PM
02/03/13 05:29 PM
Posts: 2,316 South, FL
cudaized
South, FL
A direct, straight on photo would help, photos taken at an angle are not always easy to judge.
I have asked for additional photos. Hopefully there will be a better view.
Thank you everyone for helpinig.
#1378741
02/03/13 07:21 PM
02/03/13 07:21 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
Yes, apparently I'm hopless and ignorant Now that that's out of the way, do you have anything positive or helpful to add to the thread?
Yes I do and glad you asked. It's spelled hop E less Hopless? Is that a paralysed kangaroo? As far as the thread I was just curious about the car whether it was so-called numbers matching...carry on.
