Page 2 of 3 1 2 3
Re: Don't Laugh. It's No Choke! [Re: Big Bad Bee] #1378260
01/30/13 11:33 AM
01/30/13 11:33 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I've run carbs w/o a choke and choke horn, no issues here/ This 6-pack as a manual choke I use it for about 2 seconds. Makes starts a tad easier.
Coming soon!!!!
Re: Don't Laugh. It's No Choke! [Re: Big Bad Bee] #1378261
01/30/13 12:43 PM
01/30/13 12:43 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
After two years of tuning during the Spring and Summer with O2 sensors, I found that once the cold Fall air hit I started having lean cold-startup problems. Since I had leaned out the carb to idle/transition/cruise in the 14.0 range, I found that I had to richen up the electric choke to compensate for the colder air with the leaner A/F setup. I am now an electric choke fan.
I do remember that I used to run a non choke DP Street Demon on the same engine. That carb would fire right up and idle on it's own in the Fall temps with two pumps of the pedal. I now wonder how rich that carb was running at idle/transition/cruise to be able to do this.
Re: Don't Laugh. It's No Choke! [Re: YO7_A66] #1378262
01/30/13 01:05 PM
01/30/13 01:05 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
In this or any other areas of the country where you might experience cooler weather during the months you drive your car do yourself a favor and use an electric choke
Re: Don't Laugh. It's No Choke! [Re: YO7_A66] #1378263
01/30/13 01:07 PM
01/30/13 01:07 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
No choke! Two pumps of the pedal and fires right up. A little feathering of the throttle for a bit and she's ready to go even in the cold.
Re: Don't Laugh. It's No Choke! [Re: ScottSmith_Harms] #1378264
01/30/13 01:45 PM
01/30/13 01:45 PM
Shoreline, Washington
72roadrunnergtx Offline
Running a modified electrically assisted divorced choke on a cold intake. Would never run a correctly street tuned carbureted motor without a functional choke.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Don't Laugh. It's No Choke! [Re: 72roadrunnergtx] #1378265
01/30/13 02:14 PM
01/30/13 02:14 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
Neither would I. A choke on a street car is a must, especially in a cold climate like where I live. And it's a safety feature. I can just imagine an emergency where someone has to drive me somewhere, and they can't even get the car running. That'd be my luck.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: Don't Laugh. It's No Choke! [Re: VincentVega] #1378266
01/30/13 02:47 PM
01/30/13 02:47 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Hot rods being a little more work to drive is part of the fun! No choke, three on the tree, maintaining drum brakes, big cams that have personality, muscling manual brakes and steering, all that kind of stuff is part of the danger excitement and manlyness of the old car hobby.
I do also have a 318/904 swinger with a manual choke- my wife loves to drive it and I do too but it's still not a camry!
There is no reason to say you "must" have a choke on a car
Re: Don't Laugh. It's No Choke! [Re: radar] #1378267
01/30/13 03:22 PM
01/30/13 03:22 PM
London, England
Gavin Offline
Gavin  Offline
London, England
I’ve been considering no choke……….
I used to have a manual choke but it was a bit hit and miss, and also I never quite trusted that it was not fully open (and staying open) even after the engine was warm. No biggie I could have tested for sure.
Electric chokes kind of take away your control – if something goes wrong with them you can’t start the car – cold or hot. How likely is that to happen? Very unlikely I guess but I did have a bad experience decades ago with my daily driver.
However running no choke is not a no brainer either. First I’d like to be able to start and drive away quickly on the odd occasion I would leave early in the morning in my Challenger – to keep the peace with the neighbours! And presumably if you get it wrong you can flood the carb etc (can also do this on a manual choke).
For these reasons I got to thinking about a couple of block heaters instead. Most of the time would not need but for that occasional early start in very cold weather it would achieve the aim and your engine and cylinders would thank you for it too.
Maybe overkill but just another option…..
Re: Don't Laugh. It's No Choke! [Re: Gavin] #1378268
01/30/13 03:39 PM
01/30/13 03:39 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
A well-type choke can be disabled by taking the clip off. a classic electric-only choke can be taken off with a screw driver. I don't think I'd be caught dead driving around in an old car without a toolbox
You're saying having to plug in block heaters is more convenient than keeping a choke tower and utilizing it? and if you happen to drive somewhere and leave it sit for a few hours? I just can't see it
Re: Don't Laugh. It's No Choke! [Re: Gavin] #1378269
01/30/13 03:54 PM
01/30/13 03:54 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
A choke is nothing to be afraid of, expecially a manual choke. You can bolt a small piece of wire on manual choke carb to keep it from coming on like I did forever. Then it was real easy to bolt a cheap metal choke cable in place of the wire I bolted in.
That's all there is to it. No tricks or secrets and helps a ton at start up, then turn it off after it starts(push the cable in)
It's not something someone should stress over ...lol
FWIW I would not run a race carb on the street now thAT i REALLY DRIVE MY CARS.
A finely tuned muscle car on thee street impresses me way more than brut horsepower, on the street.
I'm becoming a dinosaur as it seems less and less people know how to tune a old car, or any car for that matter.
Re: Don't Laugh. It's No Choke! [Re: bigblock340power] #1378270
01/30/13 03:56 PM
01/30/13 03:56 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
My Holley 750, and Quick fuel 950 have no chokes. Been running my Duster with out a choke for almost as long as I've had it. But out here in Calif., it's not needed much. Besides, the choke horn just slowes down the air flow. Need plenty of flow for .
Same here in So. Cal. Doesn't get used much even if I had it.
Re: Don't Laugh. It's No Choke! [Re: autoxcuda] #1378271
01/30/13 04:03 PM
01/30/13 04:03 PM
Cincinnati, Ohio
Cincinnati, Ohio
I think my challenger idling in the winter with steam coming out of my pipes on cold morning is killer, just love seeing it come out behind me.
Makes me really appreciate my TTI exhaust. When I was younger all I could afford were header mufflers.
And the guy behind me is smelling grape because that's what my gas smells like.
I've driven my restored 71 in the snow...in the driveway!
Re: Don't Laugh. It's No Choke! [Re: Challenger 1] #1378272
01/30/13 04:11 PM
01/30/13 04:11 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
On a street driven car what's the disadvantage of having a choke?
Re: Don't Laugh. It's No Choke! [Re: A12] #1378273
01/30/13 04:17 PM
01/30/13 04:17 PM
Cincinnati, Ohio
Cincinnati, Ohio
None that can think of other than missing a couple horsepower at 6000 grand rpm or higher.
Re: Don't Laugh. It's No Choke! [Re: Challenger 1] #1378274
01/30/13 04:35 PM
01/30/13 04:35 PM
P
Paul_Fancsali Offline
P
Facts as I know them
DP Holleys don't need a choke period hot or cold I can start my car after sitting for weeks in cold with couple jabs of the gas.Even down to 5 degrees
TQ's will not start without a choke without a fit if at all
AVS will start provided the squirters are drilled
Q jets wiil have fit but start with no choke with backfiring and all.
If I have a holley I remove the choke and I have two electric setups but I found they run better without the choke My 10 cents
Re: Don't Laugh. It's No Choke! [Re: Paul_Fancsali] #1378275
01/30/13 05:05 PM
01/30/13 05:05 PM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
You mention Double Pumpers. Is it the same for Single Pump/Vacuum Secondary Holleys?
I’m listening.
Re: Don't Laugh. It's No Choke! [Re: Big Bad Bee] #1378276
01/30/13 06:53 PM
01/30/13 06:53 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Holley 3310 vac secondary here. As Paul said a couple of jabs and presto. I was out last week in 20 degree weather warmed right up and went. The key is having your car tuned correctly.
Re: Don't Laugh. It's No Choke! [Re: ireland383] #1378277
01/30/13 07:06 PM
01/30/13 07:06 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Sometimes a choke is a good thing. Set up properly they can make life a lot easier. I use electric on most of my stuff.
Picture taken as I was digging it out for a little road time.
Mike
Re: Don't Laugh. It's No Choke! [Re: radar] #1378278
01/30/13 08:46 PM
01/30/13 08:46 PM
scratchnfotraction Offline
this is why I drive old cars/trucks with no choke,lumpy cams,manual shift/brakes/steering.
takes more driver input to fly it straight.
the preventive maintence is something for me to do as a hobby.
no chokes needed in FL.
Re: Don't Laugh. It's No Choke! [Re: scratchnfotraction] #1378279
01/31/13 01:13 AM
01/31/13 01:13 AM
North Texas
3
360cuda Offline
360cuda  Offline
North Texas
I use an electric choke on my Holley. I would much rather hit the gas one time, and fire it up almost instantly, other than pumping the gas and grinding on the starter over and over on a cool/cold day, just to get it to fire...maybe. I like my choke.
Page 2 of 3 1 2 3
